displaying posts 26 to 43 of 43
Pages (2): 1 [2]
| Author | Subject: rust |
rec bri
Regular Location: newtownabbey Registered: 29 Nov 2009 Posts: 154 Status: Offline |
After lots of reading online about whats best and what to avoid, i intend to use the Bilt Hamber products to seal it up after i find someone to weld a section in |
rec bri wrote: so i decided to go all "coskev" Rust Bullet is my recommended paint now After doin research on Por15 I was put off by the amount of bad threads on internet about it I have used Epoxy Mastic121 before,and that is not a patch on the Rust Bullet It can be used on ANY surface,clean metal/rusty metal/wood/concrete/plastic/painted metal etc ![]() I can't say how long it will keep the rust at bay as only used it just under a year ago,although Rust Bullet quote it will last 10 years over previously rusty metal. One test I have tried out is the 'How long will it take to get off my hands' test It will still be on hands after about 5 showers and attacking with the nail brush! Other paints will peel off skin pretty easily when dry,not Rust Bullet ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
quote: quote: Other paints will peel off my foreskin pretty easily when dry,not Rust Bullet EFA Kev! ________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
matt evans wrote: quote: quote: Other paints will peel off my foreskin pretty easily when dry,not Rust Bullet EFA Kev! T osser ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
beez_neez_gt
Does it have an acid chemical inside it so it etches into the clean metal for a long lasting bond ?________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
beez_neez_gt wrote: Does it have an acid chemical inside it so it etches into the clean metal for a long lasting bond ? epic bump ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mik wrote: currently thinking about some kind of overpaintable stone chip between Electrox and enamel in vulnerable areas. Might be a bit late by now, but you may as well keep it in the family and use Dynax UB... ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Mine has a bit of the steel missing due to rust in this area, would you be interested in welding some fresh steel in there Phil? If you are, how many beer tokens would you want? ![]() ________________________________________ Goldie the track car. |
beez_neez_gt
welshpug! wrote: beez_neez_gt wrote: Does it have an acid chemical inside it so it etches into the clean metal for a long lasting bond ? epic bump ![]() it's only Sept last year, not even 6 months ago. This is what happens when you cant tell if you have read the thread or not.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #35
beez_neez_gt wrote: Does it have an acid chemical inside it so it etches into the clean metal for a long lasting bond ? Its very tough stuff How Rust Bullet works ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
beez_neez_gt
Post #36
Nice one coskev That will help with the car im currently butt welding inner wing panels etc. Its very rusty between the spot welded panels, which is one problem hard to get at with any type of stuff. Ordered already. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
beez_neez_gt
Post #37
http://www.rustbulletuk.com/faq/all_faq.php?cat_id=5Looking through the FAQ's it is acidic as is good for aluminum so it must be like what etch primer is like on bare steel. Having a ten year guarantee is what makes this paint very good, an worth buying. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
russbez
Post #38
where you buying this stuff folks?its like £34 for 0.4litre delivered? ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
rikky
Post #39
i've got loads of BH stuff in my garage from when i was sorting the 306 out. some of it is brand new unopened, dunno what it's shelf life is like though________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
beez_neez_gt
Post #40
I called them up and was told it doesn't have an etch type chemical, you have to sand key the clean steel surface using 300 or so grade, similar to the rust surface. I was also told that because its a very hard paint, when the chassis moves it will crack and let water in, so it is best for flat surfaces with no seams etc. Properly good quality applied PU sealant will sort the seams out.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Post #41
phillipm wrote: mik wrote: currently thinking about some kind of overpaintable stone chip between Electrox and enamel in vulnerable areas. Might be a bit late by now, but you may as well keep it in the family and use Dynax UB... Still going...starting the front half of the car soon. Yes, I think I'll stick to Bilt Hamber and put some Dynax UB in there. ________________________________________ Cherry Rallye SOLD |
mik
Post #42
Bit of a thread bump but after fully stripping all the rust off I've found a couple of rust holes in the cross-member behind the front wheels where jacking it up on the thin box section has resulted in water getting under the underseal. I'm going to get it properly fixed by a Pug-approved bodyshop, as there is no point spending money on the car if the structure isn't right. One side has already been fixed (see photo), but I noticed that the other (yet to be fixed) side has a drain(?) hole that is not present on the repaired side which is in addition to - and inboard of - the hole which has a 20mm bung. This is the side that has been repaired previously. ![]() Does water drain through here? ISTR a comment where someone said there is a water drain here through the chassis? Or is it OK to seal it up after welding and inject loads of cavity wax into it. EDIT: found the comment in this thread: phillipm wrote: Quite common for them to go there if the outlet gets dented/blocked, it's the drain through the chassis. Need to drill a drain hole then! ________________________________________ Cherry Rallye SOLD |
beez_neez_gt
Post #43
The holes are there for drainage, fill the cavity with the Dynax UB then leave the hole there. The UB wax will suffocate the rust from spreading, it will also stop any water getting onto the metal, even if its dirty/dusty, the wax will stick to anything. The hole will also be needed for when you need to re-apply the wax after a few years too, it doesn't last for ever if you want it to keep on working.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Pages (2): 1 [2]
