displaying posts 1 to 25 of 42
Author Subject: Roll cage
roberts_306
I have a Custom Cages Club roll cage with a few extra bar added, does any one know if I can have it fia tested?
www.pugsport-racing.co.uk
Posted 18th Sep 2011 at 21:59
you'll need a certificate from the cage manufacturer, they will ask for a sample of the fitters welding, plus the added pipework needs to meet the regs in the blue book.
Posted 19th Sep 2011 at 11:50
i need to do this. i am hoping it isn't too much aggro
i sent my welders sample off (phil's) to CC and never heard back whatsoever. i think they fell out with me because i was "the first person to have problems with our cages in 15 years of making them"
Posted 19th Sep 2011 at 12:54
best get on the dognbone!
Posted 19th Sep 2011 at 13:07
roberts_306
My intentions are to race in the Tin Tops Series maybe next year, I need to find out if my cage is up to specs I phoned CC today they said if I give them numbers from the cage which I have found they can supply me with a MSA certificate.
Can anbody answer these other questions
1. Does the Seat need to be within date
2. Am I right that I need an in date harness
3. I need to install a plumbed in fire extinguisher
Is there anything else I need to do?
Posted 19th Sep 2011 at 21:39
make sure the plates for the cage and seat bars are up to spec.
all the answers are here:
http://www.msauk.org/site/cms/contentviewarticle.asp?article=1101
BUT, a lot of the time race series have teir own regs so best to check there first.
Posted 19th Sep 2011 at 21:50
pete_rallye
You need in date harnesses and a plumbed in fire extinguisher that has been serviced, and in date. The seat must be FIA approved and in good condition but there is no age limit for club motorsport.
Lap of the 'ring
Posted 19th Sep 2011 at 23:23
roberts_306
Thanks for the help what about the roll cage
Posted 20th Sep 2011 at 07:32
roberts_306
Custom cages have told me because I purchased a club kit cl3 and purchased extra bars to make it look like a cl4 then it won't be to msa standards they said I need to check with officials or get the angle grinder out I am so p*ssed off with it all
Posted 18th Oct 2011 at 18:22
If it's made to Blue Book specs you'll be fine, however, custom cages do have a habit of putting non-blue book bits in (such as the b-pillar braces on the 306 kits), so they need a full test certificate though, if you have that piece it would need to be chopped out and replaced.
Posted 18th Oct 2011 at 18:28
Have you got a picture of what you had and what has been added?
And what tube was used for the additions? (Size, material and wall thicknesses)
Posted 18th Oct 2011 at 18:46
roberts_306
This is what I purchased from Custom Cages
I also purchased 6 x 1.5 metres of 45 x 2.5 which gives me the same design as the CL4 kit they sell
Installed looks like this
They told me at the time that this would be the cheaper option which it was
Posted 18th Oct 2011 at 21:12
Should be fine then tbh, so long as the rear plates are over 60cm^2 in area.
I'm not certain that rear bar would though (harness bar?), I'll have to double check but I think it might fall foul of the demountable members regulations, does it bolt on top of the other tube mount or is it welded in?
Posted 18th Oct 2011 at 21:25
roberts_306
Dont use the rear bar for Harnesses as I attach them to standard belt points.
Its welded in just to give a bit extra strength
Posted 18th Oct 2011 at 21:34
roberts_306
Okay, you should get away with that bar then. Yes
Posted 18th Oct 2011 at 21:53
roberts_306
Thanks for your help most appreciated Thumbs up
Posted 18th Oct 2011 at 22:05
where is that going? to rear beam pickup points? can't work it out from my screen here LOL
Posted 19th Oct 2011 at 11:06
not sure those front plates are big enough...
should be 120cm2 min, i.e 10x12 or 4"x5" roughly
rear ones only need to be 60 sq cm.
reinforcement tubes other than the roll cage structure are not allowed
Posted 19th Oct 2011 at 12:07
That rear bar is allowed as a roll cage member though provided it is welded to the rest of the cage, really it should be between the bottom two legs but you could probably argue it's welded to the rear mounting plates...
Got better eyes than me if you can see the front plates though! LOL:
edit: Yes, looking back through the project thread there should be a triangular piece welded between the corners on the front spreader plate to make up the area, I commented on that before though.
Posted 19th Oct 2011 at 14:16
I can't see them either.....
Posted 19th Oct 2011 at 14:27
^ Blink what the?!
Posted 19th Oct 2011 at 14:48
indeed...
Posted 19th Oct 2011 at 15:11
having said that phil cable tied mine in and it's not budging
Posted 19th Oct 2011 at 15:23
Looks like it's welded drect to the floorpan, someone's fabricator needs their bottom smacked.
Thumbs down
Posted 19th Oct 2011 at 16:43
