www.pugsport-racing.co.uk
displaying posts 1 to 25 of 42
| Author | Subject: Roll cage |
roberts_306
Senior User Location: Halesowen Registered: 21 Nov 2007 Posts: 789 Status: Offline |
I have a Custom Cages Club roll cage with a few extra bar added, does any one know if I can have it fia tested?________________________________________ www.pugsport-racing.co.uk |
you'll need a certificate from the cage manufacturer, they will ask for a sample of the fitters welding, plus the added pipework needs to meet the regs in the blue book.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
i need to do this. i am hoping it isn't too much aggroi sent my welders sample off (phil's) to CC and never heard back whatsoever. i think they fell out with me because i was "the first person to have problems with our cages in 15 years of making them" ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
best get on the dognbone!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
roberts_306
My intentions are to race in the Tin Tops Series maybe next year, I need to find out if my cage is up to specs I phoned CC today they said if I give them numbers from the cage which I have found they can supply me with a MSA certificate.Can anbody answer these other questions 1. Does the Seat need to be within date 2. Am I right that I need an in date harness 3. I need to install a plumbed in fire extinguisher Is there anything else I need to do? ________________________________________ www.pugsport-racing.co.uk |
make sure the plates for the cage and seat bars are up to spec.all the answers are here: http://www.msauk.org/site/cms/contentviewarticle.asp?article=1101 BUT, a lot of the time race series have teir own regs so best to check there first. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
You need in date harnesses and a plumbed in fire extinguisher that has been serviced, and in date. The seat must be FIA approved and in good condition but there is no age limit for club motorsport.________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
roberts_306
Thanks for the help what about the roll cage ________________________________________ www.pugsport-racing.co.uk |
roberts_306
Custom cages have told me because I purchased a club kit cl3 and purchased extra bars to make it look like a cl4 then it won't be to msa standards they said I need to check with officials or get the angle grinder out I am so p*ssed off with it all________________________________________ www.pugsport-racing.co.uk |
If it's made to Blue Book specs you'll be fine, however, custom cages do have a habit of putting non-blue book bits in (such as the b-pillar braces on the 306 kits), so they need a full test certificate though, if you have that piece it would need to be chopped out and replaced.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Have you got a picture of what you had and what has been added?And what tube was used for the additions? (Size, material and wall thicknesses) ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
roberts_306
This is what I purchased from Custom Cages![]() I also purchased 6 x 1.5 metres of 45 x 2.5 which gives me the same design as the CL4 kit they sell ![]() Installed looks like this ![]() They told me at the time that this would be the cheaper option which it was ________________________________________ www.pugsport-racing.co.uk |
Should be fine then tbh, so long as the rear plates are over 60cm^2 in area.I'm not certain that rear bar would though (harness bar?), I'll have to double check but I think it might fall foul of the demountable members regulations, does it bolt on top of the other tube mount or is it welded in? ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
roberts_306
Dont use the rear bar for Harnesses as I attach them to standard belt points.Its welded in just to give a bit extra strength ________________________________________ www.pugsport-racing.co.uk |
roberts_306
Okay, you should get away with that bar then. ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
roberts_306
Thanks for your help most appreciated ________________________________________ www.pugsport-racing.co.uk |
rikky
where is that going? to rear beam pickup points? can't work it out from my screen here ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
not sure those front plates are big enough...should be 120cm2 min, i.e 10x12 or 4"x5" roughly rear ones only need to be 60 sq cm. reinforcement tubes other than the roll cage structure are not allowed ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
That rear bar is allowed as a roll cage member though provided it is welded to the rest of the cage, really it should be between the bottom two legs but you could probably argue it's welded to the rear mounting plates...Got better eyes than me if you can see the front plates though! :edit: Yes, looking back through the project thread there should be a triangular piece welded between the corners on the front spreader plate to make up the area, I commented on that before though. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
I can't see them either.....![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
^ what the?!________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
indeed...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
having said that phil cable tied mine in and it's not budging________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Looks like it's welded drect to the floorpan, someone's fabricator needs their bottom smacked. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
