Ph2 Black GTI 6!EX black 6 owner
| Author | Subject: crank and bottom end |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
both of which are worn and will need work. good if you are planning on larger pistons and new larger bearings bottom end free to collect crank 20pounds________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
mikebee
Regular Location: Northampton Registered: 17 Aug 2010 Posts: 122 Status: Offline |
have you got the plate that goes on the sump at the crank pulley end with the slot in for the timing pin? some idiot has tried starting the engine on mine with the timing pin in the crank pulley and broken the slot...... |
the end that slides in yeap with the two seals yeap________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
mikebee
YHPM :-) |
pm'd back________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
