Author Subject: compression test hi comp engine
velar
What pressure should I expect on a hi compression engine (woosner pistons )
My guage measured over 290PSI on all cylinders. (nearly end stopping the meter!!) which the interweb tells me equates to around 14:1 !!!
Posted 9th Sep 2011 at 21:07
allanallen
Mine with je's (11.5:1) measured 225 psi.
Remember cams and cam timing effect your compression.
Al
Facebook
Posted 9th Sep 2011 at 21:20
seems a bit high to me ? what cams are you running ?
Posted 9th Sep 2011 at 21:23
velar
piper 285hs
Posted 9th Sep 2011 at 21:32
That's high as hell with 285's.
What does it read with a normal engine? Might just the tester is out a fair way.
My Tu on 10.8:1 with a road cam (advanced slightly) knocks about 230 across all 4 pots on my meter.
Posted 9th Sep 2011 at 21:52
velar
Good call, could be the meter, will try it on a standard xu and see.
Posted 9th Sep 2011 at 22:01
dav1
Wat do the 11.5.1 or 10.4.1 figures realate too?
230bhp 205 gti6
Posted 9th Sep 2011 at 22:57
velar
The ratio of volume in the cylinder with the piston at it lowest and highest points.
Posted 9th Sep 2011 at 23:11
mabgti
NV motors
290psi.. did you do the test with no fuel and wet tests?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 21st Sep 2011 at 23:28
velar
no fuel ( infact no inlet manifold) but what are wet tests
Posted 22nd Sep 2011 at 00:04
On a standard engine dry I saw between 190 and 205 psi, this was on my 111,000 mile old engine though but the bores looked good as new on strip down. Did you CC the combustion chambers and work out the volume of the piston intruder dome when you built it? I ended up wih around 12.7:1 using Wossner high comp pistons, saying that though a small amount of material was removed from the combustion chambers as they were reworked for better burn.
Posted 22nd Sep 2011 at 12:21
rich_w
290 PSI is probably about right for that setup IMO.
The Wossner pistons are around 12.2:1, and as a rule of thumb you would expect to see 17-20 times the CR on a standard engine (say circa 240 PSI).
Given you’ve got longer duration / higher lift cams, you will have a higher volumetric efficiency, which will increase the cylinder filling ability further.
The fact you had no manifold, air filter attached when you did the test will also increase the results of a compression test as there’s no plenum to form a vacuum in around the ports on the cylinder head.
Contact Details:
07732 822546
Posted 23rd Sep 2011 at 12:49
