Author Subject: Another hesitation issue
daddy5times
Sad I know there's loads of these threads on here but mine is all through the rev range .I've tried unugging maf or map sensor I dOmt know what it's called and engine cuts out instantly what other things could I try ??? Thx in advance
Posted 9th Aug 2011 at 23:18
daddy5times
I've also tried unplugging lamba and taking it for a quick razz problem remains .all plugs look a nice soot free light brownish colour what else can I try??? Thx
Posted 9th Aug 2011 at 23:46
swiftyboi006
Bit more info as to whats going wrong with it?
Black p3 Love
Posted 10th Aug 2011 at 00:51
daddy5times
Just holding back when I put foot down even of I do it slowly .it's like someone's holding car by bumper to slow it down when I take my foot off a bit it's ok .I can feel it trying to go but it doesn't I've tried it when I've unplugged tps/lamba/ when I unplugged maf/map it cut out instantly .idles perfectly when I set off at lights it holds back soon as I put foot My foot down but the picks up a bit then hesitates all throgj driving range .I'm a bit stumped
Posted 10th Aug 2011 at 01:04
Tried the ICV?
  • Posted 10th Aug 2011 at 01:06
    daddy5times
    No I've not tries icv I thought that just sorted idle????I've done ecu reset
    Posted 10th Aug 2011 at 01:11
    daddy5times
    There seems to b a very small split in the pipe that joins the big pipe witch comes from the throttle body ???? .wondering if this could b making it worse
    Posted 10th Aug 2011 at 03:08
    gti6power
    i had the same problem with mine and it turned out to be a 10 amp fuse had blown for the lambda sensor or oxygen sensor(which ever you want to call it) in the fusebox near the ABS pump
    Posted 10th Aug 2011 at 03:25
    daddy5times
    Cheers I'll have a look in morning
    Posted 10th Aug 2011 at 03:45
    daddy5times
    No all fuses seem ok!
    Posted 10th Aug 2011 at 15:07
    swiftyboi006
    I very much doubt the icv but it could be the tps not knowing how much stick ur giving it (throttle position sensor)
    Does it idle lumpy at all or is idle perfect?
    Black p3 Love
    Posted 10th Aug 2011 at 18:06
    pebbles167
    Unplugging the map sensor and plugging it back in won't do a thing if its damaged. You would need to buy a replacement part. My car had a hesitation issue that was intermittent but frequent all the way through the rev range, almost as if you were to gun the accelerator and kick the clutch every second or so. Turned out tot be the map sensor, new one is around £20 - £40 depending on brands and location of purchase. And the icv can cause problems with hesitation too. Try taking both sensors off. Soaking them in carb cleaner (or something similar) and cleaning them with rag. Don't worry about covering up the electrical connections as they will be fine, sometimes this works but generally a new part is always preferred.
    2005 Peugeot 206 GTI 180
    2008 BMW K1200R
    Posted 10th Aug 2011 at 18:17
    daddy5times
    Yes swifty idle is perfect .as I set off it hesitates for a sec then gets going like it doesn't wanna go any faster .there's no peticular speed it does it at can be anywhere but always does it as I set off at lights etc thx
    Posted 10th Aug 2011 at 20:21
    daddy5times
    I'll take sensors off now and give em a bit of a clean with wd40 I ll post back results later and thx all
    Posted 10th Aug 2011 at 20:28
    daddy5times
    Tried cleaning map sensor but still the same .chap who fit my thermostat has just said he only filled it up with water !!!no antifreeze silly question but could that have anything to do with it holding back??????
    Posted 11th Aug 2011 at 00:10
    daddy5times
    It's like it's missing when I accelarate but then sometimes picks up when I ease off sometimes makes a popping sound from exhaust !!!
    Posted 11th Aug 2011 at 16:12
    swiftyboi006
    Try with a new tps like I said, also coilpacks are now known to be intermittent not sure if they would cause this but you never know. Def try the tps tho as it sounds like this to me
    Black p3 Love
    Posted 11th Aug 2011 at 18:38
    daddy5times
    Could I not 1st try cleaning the 1 that's on ? When I took throttle off there was no gasket . Should there be 1 ??
    Posted 11th Aug 2011 at 19:37
    There should be a throttle body gasket yeah.
    That pipe with a split, replace it. could be completely unrelated, but should be replaced anyway.
  • Posted 11th Aug 2011 at 19:41
    daddy5times
    Just noticed wires that go to lambA are joined and taped up could it be there not done right?
    Posted 11th Aug 2011 at 20:25
    swiftyboi006
    Also double chrck fuse box
    Black p3 Love
    Posted 12th Aug 2011 at 12:16
    daddy5times
    guys where abouts is tps???
    Posted 12th Aug 2011 at 15:14
    ryangti6
    On the throttle body, it's the big white/cream sensor.
    Have you taken the plugs out? If not that would be where I'd start, check general condition and also note what colour they are and if any stand out as looking different etc as this can usually show you where the problem lies.
    If it's as bad as you say though I'll go with fuel pump dying rather than a sensor problem.
    Ryan
    Posted 12th Aug 2011 at 16:05
    daddy5times
    Yes pal all plugs look same kinda light brownish colour
    Posted 12th Aug 2011 at 16:08
    daddy5times
    Just been to look at plugs again and 3look good 1is covered in a crusty matter that I can pick off with my thumb and is a different colour to the rest .uuummmmm plugs coil ?
    Posted 12th Aug 2011 at 19:43
