cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
displaying posts 26 to 32 of 32
Pages (2): 1 [2]
| Author | Subject: Another hesitation issue |
swiftyboi006
Change the plugs then, sound like u need to, might be worth getting a compresion test as there could be a prob with tgat cylinder________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daddy5times
Junior User Location: halifax Registered: 29 Jul 2011 Posts: 69 Status: Offline |
I swapped the coil from another cylinder to the 1 with the crusty sparkie .also put a new plug in it but it's still spores up this morning all others are fine !so can't be plug can't be coil any other ideas chaps? I'm gonna take it for a compression test on Tuesday .if compression was down on the cylinder wouldn't it always run like it's on 3 also wouldn't it idle rough ?thx |
daddy5times
no matter what I try the sparkplug is still getting sutted up .it's not the nearest one to thermostat but the one after .is there any thing else I can check??? |
sounds like headgasket________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daddy5times
oh sh?t how could i check this? |
daddy5times
doesnt use oil no oil in water or overheat???? |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
daddy5times wrote: There seems to b a very small split in the pipe that joins the big pipe witch comes from the throttle body ???? .wondering if this could b making it worse This will cause 100% of the symptoms you describe ... |
Pages (2): 1 [2]
