displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: How to remove ABS
oldbrownshoe
Why don't you just remove the 2 relay's ?
French military victories?
Did you mean French military defeats?
Posted 6th Aug 2011 at 03:45
cwspellowe wrote:
copper/nickel is easier to form iirc and supposed to last longer. Kunifer rings a bell?
Copper/nickel does last longer,but is alot harder to form/flareSad
Need a decent flaring tool,not a cheap one that will do copper spot onWink
Posted 6th Aug 2011 at 04:12
cwspellowe wrote:
If an MOT guy sees ABS sensors though will he not wonder why there's no ABS to test? Or is it a case of "It only has to be working if it's present" ?
If doing a proper removal you will remove all sensors and put some blanking plates over the holes in hubsWink
And remove the ABS wiring that runs to sensorsSmile
Posted 6th Aug 2011 at 04:15
abs sensors make no odds whatsoever
mine are still in the hubs and i deem mine a "proper removal", it's the same setup as above diagram using fully stainless pipe throughout and a wilwood lever bias valve
abs is fully removable without any custom wiring or anything needed. simple unconnect it all from under the car and remove the full unit and pipework associated with it. never ever ever just remove a fuse to bypass the ABS. this is a very seriously stupid thing to do. also the first person to say "removing fuses stops your brake lights" gets a flying dragonkick
some BTCC cars use the steel pipework if you want to get really pedantic..
Posted 6th Aug 2011 at 04:59
I tend to use copper/nickel, it's stiffer, and more corrosion resistant.
If you think Kunifer is bad though, wait until you find a car with stainless steel brake pipes, and try flaring that...
Posted 6th Aug 2011 at 05:01
oldbrownshoe
Could you explain why don't you just remove the 2 relay's?
Posted 6th Aug 2011 at 15:08
Shock This isn't Offtopic! Are you lost? Wink
Posted 6th Aug 2011 at 14:42
All useful info people, ta Yes
I've always just used copper and it's done me so far, so I'll probably just use that again as I know how to work with it and I know my flaring tool works with it too.
Looks like I'll be ordering up some brass fittings when back from holiday then, if Swampmeister is still giving me the cold shoulder.
Posted 6th Aug 2011 at 14:48
cwspellowe
Long story, but i need the space where the ABS pump is for something else
Bye bye Sundance Kid Sad
Posted 6th Aug 2011 at 15:29
oldbrownshoe
Post #35
That's a reason, but i was referring to rikky warning which imply that all sort of bad things will happen if someone mess with it's electric circuity.
i used to unplug the relay's in the summer for years
and never recall a problem what so ever with it's function.
just wondered.
Posted 6th Aug 2011 at 17:11
oldbrownshoe
Post #36
I really love the skillful way You beat the other girls To the thread bouquet.
Posted 6th Aug 2011 at 17:36
Post #37
Well I'm baffled.
With regards to Rikky's post I don't really know either, but personally I'm looking to remove the lot not for functionality reasons, but for the weight/fluid saving. Therefore I'm removing to physically remove as much kit from the car as possible Smile
Posted 6th Aug 2011 at 17:54
Post #38
Didn't say the ABS sensors made any 'odds' did I?Roll eyes
If your happy with doing half a removal job so be itWink
Just lazy/half arsed leaving the sensors in IMO.
Posted 7th Aug 2011 at 01:49
Post #39
I left half of one of mine in as the bugger wouldnt come out and snapped. Laugh
Posted 7th Aug 2011 at 01:57
Post #40
What's all this ABS stuff? Huh?
Posted 7th Aug 2011 at 02:04
Post #41
I dunno, I wanted to get Abs, singer in boyband 5ive, out of my house, but everyone started banging on about brakes Dunno
Posted 7th Aug 2011 at 02:26
cwspellowe
Post #42
Children children Laugh
Right, shopping's done, need to get the brake lines made at a local motorfactor on Tuesday when am in town.
Fronts -
MC to t-piece, new lines to flexi's
Rears -
MC to bias valve mounted where battery used to be, single line to rear, t-piece to flexi's
Lines will be 50p/foot + 50p/fitting. I'm using 31 feet all measured up, total cost comes to £21 for the lines and fittings which isn't bad imo
Posted 8th Aug 2011 at 00:13
Post #43
Do it yourself you big girl!
What, like, under the bonnet?!
EDIT: Oh, and where are you getting the t-pieces etc from?
Posted 8th Aug 2011 at 00:15
cwspellowe
Post #44
Got the t-pieces from an eBay shop, M10 female fittings, about £8 each? Will see how they hold up, if they're no good i'll buy from a reputable shop Laugh
Valve will be under the bonnet as I have nowhere to put it in the car and I heard it's supposedly illegal to have a bias adjuster within reach of the driver on the road. Will mainly use one setting anyway once it's set up, just fiddled with for the MOT.
**EDIT as for making the lines myself, in the long run yes it would be cost effective but if the lines are going to be around £20 and it's going to cost more than that for copper and a flare tool and fittings it's not economical, don't plan on making the lines more than once!
Posted 8th Aug 2011 at 00:19
Post #45
£8 sounds about right, not much less than that from DT or anywhere so they'll be fine. They're only tapped lumps of brass anyway, not like there's much to go wrong.
What bias valve you going for?
And if you could do me a favour - I'm off on holiday for a week, so if you could have it all bought, fitted and tested before I get back that'd be really handy, ta Wave
Posted 8th Aug 2011 at 00:27
cwspellowe
Post #46
One of these, it's a knob (giggle) type adjustment with M10 fittings and 60% bias adjustability. Was a PITA trying to find one that didn't use NPT fittings without getting bent over for an extra £20 or so. Also doesn't need fancy gubbins as it'll hardly be touched once it's set up, as long as it doesn't fail after a month i'll be happy Laugh
Clicky for the twiddly thing
Will let you know how it all holds up Thumbs up
Posted 8th Aug 2011 at 00:32
Post #47
Yeah looks good, I'm sure it'll do the job.
Best of luck Thumbs up
Posted 8th Aug 2011 at 00:34
cwspellowe
Post #48
If I don't review everything for you it's because i'm dead Smile
Posted 8th Aug 2011 at 00:35
Post #49
Yes, don't forget new braking systems should be tested by getting up to great speed then slamming your foot on the brake hard, so you'll know if anything wasn't done up properly Yes
Posted 8th Aug 2011 at 00:40
cwspellowe
Post #50
Doh reminds me of when a pipe burst 15 miles from home. Instead of doing the sensible thing and getting to the nearest garage, i drove home with the pedal getting softer and softer. Thankfully it was mostly motorway, only had to brake 3 times all the way home as I live just off the motorway LOL
Downshift braking ftmfw Cool
Posted 8th Aug 2011 at 00:45
Pages (2): 1 [2]
