So I quickly pulled over and turnt the engine off but was unsure if I should open the bonnet. Anyway I thought f*ck it, opened it up and the smoke appeared to be coming from behind the heat shield and a lot of it!
Luckily I had a 10mm spanner handy so I cracked off the nuts
and pulled the heat shield out to find 2 holes had been burnt into it where it has been resting on the mani. So I'm guessing at some point in the cars life it been removed and poorly refitted and I noticed the 2 nuts that would secure the bottom of the heat shield werent there which was allowing it to rest on the manifold. Obviously I'm glad it didn't catch fire!!!
I don't have a spare heat shield to hand so I cut away the bit of burnt shield and re attached it an secured it properly and so far so good I'm guessing it's only protecting the heater matrix hoses from melting and catching fire?
Team Nile 6
Team: 40.2 MPG
5 x a 306 owner!
currently abusing type r's in a town near you ™
I truely live for the 306 ®
midweek madness
mattgti6phase2
Its also packed nice and tight together...
