Author Subject: 406 brembos what discs
yadam
hi so i have just gt my 406 4 pot brembos they came with discs of a 406 3.0 but now im told that they make the wheel ofcenter. so what car would have the right size discs thanks Unsure
Posted 24th Jul 2011 at 20:54
Do a search, it's been covered a million times Thumbs up
Posted 24th Jul 2011 at 21:30
yadam
ok thanks
Posted 24th Jul 2011 at 21:43
I heard Citroën xantia discs are best?
Posted 24th Jul 2011 at 22:36
maltese16v
i've done this conversion
206 gti180 discs with 406 brembos
Posted 24th Jul 2011 at 23:06
-er-
Look at this link Wave
4 pod Conversions
My Channel EREL
Peugeot 306 GTi-6 N5 / PH2 / Diablo Red / Mustang Red Cloth (Sold Sad )
Peugeot 306 GTi-6 N5 / PH3 / Diablo Red / Alcantara Suede
Peugeot 306 GTi-6 N5 / PH2 / Bianca (Sold Sad )
Posted 25th Jul 2011 at 01:42
andy306gti
Sorry to hijack the thread but is there much squeal using gti180 discs?
Thanks
Andy
Posted 25th Jul 2011 at 14:19
bellcp306td
yes they squeal when using the 180 discs
Where did the road go!
Posted 25th Jul 2011 at 15:21
They squeal when using anything other than Tarox G88's.
Posted 25th Jul 2011 at 15:25
I thought xantia ones were squeal free, or is that bs?
anyone know if you can get the adaptor for 807 brakes still?
Posted 25th Jul 2011 at 20:18
That, my friend, is bullshit Yes
It seems to be down to luck. Some calipers seem fairly quiet, others (like mine were) are *so* loud the first time I used them I knew I couldn't keep them like that, literally people look round at you from the end of the road.
Posted 25th Jul 2011 at 20:27
velar
couldn't live with this on a road car
xantia discs 406 brembos, mintex f4 pads
Posted 26th Jul 2011 at 01:58
lotek
arrrrghhhhmy f*cking ears!!! ahahah
Posted 26th Jul 2011 at 04:44
Omg. f*ck that then. I'm after a different brake setup for shiz
On another note your car is fast as hell and sounds Niiiice what engine mode does it have
Posted 26th Jul 2011 at 05:19
lotek
off and on? Dunno
Posted 26th Jul 2011 at 12:46
ash
Six Addict
I sell a kit for £320 that fits these calipers using 330mm rotors £276 and the brakes won't squeal. Needs 17" wheels though.
http://www.306gti6.com/forum/showthread.php?id=112533&page=1#1
Posted 26th Jul 2011 at 13:16
velar
Car is fully striped inside, so brakes are a lot louder than they would be on a road carShockWhistle wearing a helmet helps
I have used the same calipers and pads on several different car setups, and the squeel is random!!!
Engine is bog standard, but is on jenveys.
Posted 26th Jul 2011 at 13:51
Tarox G88's are the only discs that won't squeal on the standard Brembo setup.
Posted 26th Jul 2011 at 13:57
techdw
Bloody hell. I was about to get a set of V6 Brembos for mine. and seeing that Vid has put me right off!!
Posted 27th Jul 2011 at 02:08
I'll be selling mine with the non-squealing g88s soon Whistle
Posted 27th Jul 2011 at 03:21
Same, going for the Renault sports now I think :S
Or are there anyone's other than wilwoods that go under cyclones?
Posted 28th Jul 2011 at 00:16
Just get the G88 discs, that way you get no squeal and don't have to go to 16" wheels.
Posted 28th Jul 2011 at 02:29
how much are tarox's to buy then if everyone seems a bit weary of them?
Posted 28th Jul 2011 at 05:30
They're not cheap (about £250 a pair) but I've used mine on about three or four trackdays absolutely pounding them and they've lost practically no material whatsoever.
Considering you can just swap them over directly and continue using the 406 Brembos, they're significantly cheaper than the other options.
Posted 28th Jul 2011 at 13:14
velar
As already said, squealing or silent 406 brembos seams to be down to luck.
once read that Calipers with 4 equal sized pistons are more prone to noise than other designs.
There are loads of threads on here and the 406coupe club forum, and many suggest that if the calipers are kept clean they are less prone to squeal. There are also suggestions that corrosion behind the stainless steel plates is to blame.
I am upgrading to 310mm alcon discs and AP 6 pots (partly due to the noise)
Posted 29th Jul 2011 at 00:19
