displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: Brake bleeding-how do you know when the air is out?
I think I did, but I don't think I ever had the proper box for it, so it's not impossible the correct one got lost along the way.
Normally I just wait until the girlfriend is in and make her do it Yes
Posted 28th Jun 2011 at 03:09
flynn_ wrote:
What do people think of the gravity method?
It's shit.
Posted 28th Jun 2011 at 03:36
daveyboy wrote:
It's shit.
Sound like a method of contraception. Which would also not work.
Posted 28th Jun 2011 at 03:39
jeffers Forum Admin
Jus t buy an easibleed kit from halfrauds and be done with it, it'd much quicker and easier to bleed the system! Only cost about ~ £17 well worth it IMO! Wink
Team Running Engine again!
Team Negative Camber!
Posted 28th Jun 2011 at 03:59
Do they actually work as well as pumping the pedal? A person's foot can put exert an awful lot of pressure.
Posted 28th Jun 2011 at 04:00
Work very well tbh, provided you can get the right seal.
Posted 28th Jun 2011 at 04:04
Will this one do?
Posted 28th Jun 2011 at 04:06
berger
Mine doesn't have a high flow rate when bleeding the rear calipers, I guess due to the lines being a lot longer than the fronts.
This is using the recommended 20psi in the tyre. I dare not use more as I don't want to risk spraying brake fluid everywhere.
I pumped the pedal at the same time as using the bleeder to help it along.
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 28th Jun 2011 at 04:09
Sounds rubbish to me.
Is there much point using it at all if you're pumping the pedal as well?
Posted 28th Jun 2011 at 04:10
gilesy
Posted 28th Jun 2011 at 04:14
Post #36
That's just a pot with a bit of pipe on it. I use a bit of old washer hose and a Robinsons bottle for the same purpose, and they're free Yes
Posted 28th Jun 2011 at 04:16
gilesy
Post #37
I didn't have either of those things, so to buy robinsons would have cost me £2 and had no pipe...so was easier to get that!
Posted 28th Jun 2011 at 04:19
Post #38
Rubbish, you can get a litre of orange & mango (no added sugar) for £1 at Tesco, I have four bottles downstairs in the kitchen and another six on my desk at work.
Luckily, I have a (soft) drink problem, so bottles are pretty easy to come by.
Posted 28th Jun 2011 at 04:22
gilesy
Post #39
I'd lay off the sugar dude LOL
Posted 28th Jun 2011 at 04:26
Post #40
EVER FEEL LIKE NO-ONE LISTENS TO YOU?!
Jeeeez, I think I need a Ribena
Posted 28th Jun 2011 at 04:28
Post #41
They bleed pretty damn quick at 40psi...
Posted 28th Jun 2011 at 04:32
gilesy
Post #42
Surely it comes with its own sugar???
Posted 28th Jun 2011 at 04:33
Post #43
Naaaa, it's all chemicals and other such e-numbered goodness. Yes I'll probably grow another head but it's got about 80 calories in an entire bottle.
Erm, back on topic, erm - I wonder how many calories are in RBF660 as a comparison?
Posted 28th Jun 2011 at 04:39
Post #44
Drink it and find out, if you suddenly put on 10 stone and look bloated in the morning we'll know.
I have a feeling it might be a good diet actually, and you'll end up pretty damned skinny by this time next year...
Posted 28th Jun 2011 at 04:41
Post #45
PLUS I'll be able to withstand temperatures of up to 350 degrees C, not like you feckers.
Posted 28th Jun 2011 at 04:42
jeffers Forum Admin
Post #46
You don't need to pump the pedal with a pressure bleeder that's the whole point!Roll eyes
Posted 28th Jun 2011 at 16:28
berger
Post #47
I said that the flow rate was very slow, so pushed the pedal to speed things along!
I could have used more pressure like Phil but didn't want to blast brake fluid over my engine bay.
Posted 28th Jun 2011 at 21:21
Post #48
^There's so much free space in my engine bay it probably wouldn't hit anything anyway!
Posted 28th Jun 2011 at 21:23
davedgti6
Post #49
True you don't if you are just changing the fluid, but if you have air in there it helps to displace air bubbles and it tells you in the instructions to pump the pedal if you have difficulty bleeding
Posted 28th Jun 2011 at 22:02
flynn_
Post #50
Well I used the gravity method in the end and even though I bled it through last time until there was straight fluid seeping out, this time even though there was no air leak in the system, some more bubbles came out as I cracked the bleed valves and then I let a fair bit of fluid to seep through just to be sure there was no more air in them.
The result is a very firm pedal, so much so that I cannot push the pedal any measurable distance when the servo is off (but this is with braided hoses as well). So although some people have said the gravity method doesn't work I can happily say that, in my experience at least, it does Smile Certainly saves a lot of hassle with pumping the pedal and buying a bleed kit!
Posted 2nd Jul 2011 at 00:57
Pages (2): 1 [2]
