Author Subject: for all you looking for Rallye Aux Setup,
found this new rallye Aux setup on Ebay for all you lot looking to ditch your Aircon,
you will need,
Idle Pulley
Part no Gatt36036
Manuel Tensioner
Part no Gatt38098
then go to
Euro car parts,
Peugeot etc and order
Alternator Belt 5750 WL
Tensioner Screw 5703 67
and below a pic of the setup borrowed from another post!
hope this helps some of you lot out! Thumbs up
Posted 19th Jan 2023 at 20:51
jord294
my hero Love
i recently bought a replacement pulley, which when fitted had a severe wobble
took it back for replacement, and the replacement was just as bad
cheers
Posted 25th Jun 2011 at 18:04
Cheers for that! I need this, but I also need to lose power steering so need to do some research.
  • Posted 25th Jun 2011 at 18:15
    Nice findSmile
    Feel free to use my diagram........Razz
    Wink
    Posted 26th Jun 2011 at 00:52
    masekwm
    Is that for a 205 GTi6?
    Posted 26th Jun 2011 at 01:06
    If you have a gti 6 engine (xu10j4rs)
    And you don't want your aircon then this is for you!
    You need to loose it all together??? :/
    Shorter belt I'd have thought?
    What are you upto? Shifty
    coskev wrote:
    Nice findSmile
    Wink
    Cheers thanks Thumbs up
    Posted 26th Jun 2011 at 06:35
    405gti6
    You dont really need a special tensioner screw from Pug as any bolt works fine to tension it up. Thats what I did to mine.
    XU10J4RS powered 405 Big grin.
    Posted 30th Jun 2011 at 22:25
    Haha ok for those shhhh,... So did I
    Well one Jim had Smile
    But if you don't then that's the part number for the bolt needed Wink
    Posted 2nd Jul 2011 at 21:01
    atterz
    What is the thread size of the tensioner bolt?
    owain wrote:
    Posted 17th Oct 2011 at 18:03
    m8 iirc Smile
    Posted 17th Oct 2011 at 18:55
    atterz
    Cheers mate, plenty at work Big grin. Which thread am i likely to need to tap out as it will be rusted solid? And is that M8 as well?
    Posted 17th Oct 2011 at 19:53
