Author Subject: Air Box Parts Explained
wangobotics
Hey,
Does anyone know what the cheese wedge looking thing coming off of the standard airbox is actually for?
Posted 11th Jun 2011 at 23:14
lotek
resonator
Posted 11th Jun 2011 at 23:15
lotek wrote:
resonator
I WISH ALL THREADS WERE THIS EASY.
I'd recommend we make this one a clicky.
Posted 11th Jun 2011 at 23:40
atterz
owain wrote:
Posted 15th Jun 2011 at 01:30
Cheese is really not the word I would use to describe it.
  • Posted 16th Jun 2011 at 17:48
    jimmyhackers
    as said its a resonator.
    notice how its on the clean air side of the filter.
    durring the intial stages of acceleration it gives a larger amount of redily available air. it also helps keep sharp increases of vacum to a minimum which in theory should smooth out throttle responce and acceleration etc
    its more complicated than that but that a basic idea of what it does
    Posted 18th Jun 2011 at 03:11
    ^^No, that's what the plenum is for.
    The helmzholt resonator on the intake is for suppression of intake noise by generating opposing pulses in the intake to those creating the most noise - effectively cancelling them out. It's also partially there to help bolster flat spots in the torque curve (caused by the combination of camshaft and runner lengths) by adding another frequency chamber that gives a small pulse tuning effect - same as the runners themselves do - albeit at the slight expense of the peak torque values. That's why it's connected through a relatively small port - it doesn't need to flow much air, just influence the sound waves traveling back and forth through the inlet manifold.
    Posted 18th Jun 2011 at 03:19
    I preferred this thread when it was only two posts long. It had a certain simple charm to it.
    Posted 18th Jun 2011 at 03:24
    ^^With you posting it's going to stay simple anyway. Not sure about the charm though.
    Posted 18th Jun 2011 at 03:28
    Ha! My mummy says I'm charming! LOL
    Posted 18th Jun 2011 at 03:29
    jimmyhackers
    so what your saying is this thing helps the engine run better, which is what i was saying, all be it in a rather more primative way.
    seeing as you know more, would a better quality filter in the same setup with other na engine mods benefit from a differnt sized resonator?
    im guessing it probly makes a fart in a tornadoes worth of perforomance doing it though Big grin
    Posted 18th Jun 2011 at 03:36
    You've got confused with two different parts...
    The airfilter is pretty much nothing to do with it LOL
    Posted 18th Jun 2011 at 03:49
    It really is very simple:
    Helmholtz Resonance
    Posted 18th Jun 2011 at 15:26
    sparko
    Helmholtz Resonance
    hurts my head lookin at that this early on a sat....
    no wait thats the hangover Razz
    Cherry Red - Phase 1 Restoration
    She's alive again Smile
    Posted 18th Jun 2011 at 15:30
    sparko
    Helmholtz Resonance
    Posted 18th Jun 2011 at 16:07
