Author Subject: Car not starting / turning over
springs
Right..
I took the car out on Sunday and it was fine and dandy.. Went to the shops and back with no issues. Parked up and left it overnight on the drive.
Come Monday morning i went to go to work and the car wouldn't even turn over. When you turn the Key all you get is a Click from what sounds like its coming from the starter motor.
Today i've managed to take the inlet manifold off and have a look at it. I've swapped the starter over to another one i had spare and still the same issue.
I've put a screwdriver to the starter motor to try and start it manually and all you hear is a click and the engine won't turn.
I've tried sticking a jumper lead on the starter motor and earthing it against the battery but still the same..
Need some ideas as i could do with the car ASAP..
FYI its a phase 1 Gti-6
Posted 20th May 2011 at 00:54
anderoo
Sounds like a dead battery to me.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 20th May 2011 at 00:56
springs
we tried to jump it when the old starter was installed with no luck
Posted 20th May 2011 at 01:07
matt.gti6
I have this problem with my car at the moment - had the AA look at it last night, he concluded that starter motor is dead. My battery is brand new, and the earthing is all good, car can be bump started fine so it all points to a new starter motor. The only other thing he tested for was if the engine was seized - I hope this isn't the case for you! He checked it by rocking the car when it was in gear (4th i think)
Posted 26th May 2011 at 13:55
crank sensor?
Posted 26th May 2011 at 15:17
Had this happen before, was the crank sensor.
  • Posted 26th May 2011 at 15:53
    springs
    ended up being a dodgy starter motor..
    Solenoid wasn't passing the power from the main 12v line to the starter
    replaced and all working as it should
    Posted 27th May 2011 at 02:35
