Author Subject: 306 Rally Car Project
gtylerroberts@manx.net
Some of you may remember my earlier (failed) attempts at this - But I am starting again - And this time it will be completed!
Posted 15th May 2011 at 18:17
lotek
Pics Dunno
Posted 15th May 2011 at 19:59
http://s1080.photobucket.com/albums/j321/gtylerroberts/
For some of the pics
Spec so far:
Leda Forest adjustable coilovers and dampers to rear
Sadev 6 speed dog box
Pipercross induction
Decat exhaust and Scorpion back box
OMP Roll cage
Relocated battery
Engine bay fire supression
Posted 15th May 2011 at 21:14
midlife
Good luck with your project, I hope you put more effort into it than you have put into this thread!!!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 15th May 2011 at 20:58
Thanks Midlife - perhaps you have some pointers for me - first forum I have used! LOL
Posted 15th May 2011 at 21:12
jonv
well er posting pictures with a description of how and why you did it usually helps Roll eyes
2000 'W' GTi-6
Posted 16th May 2011 at 20:56
clen666
Take a look in the projects section at some other build threads, even midlife's will do Whistle, to get an idea.
Sounds interesting and would like to see more
Team 'unintentional rat look'
Posted 16th May 2011 at 20:59
I'll be nice.
Those Leda's look like they've seen better days LOL
Posted 16th May 2011 at 21:16
Thanks guys - how did you resize the pictures?
Yes - The Ledas need a service!! Smile
Posted 16th May 2011 at 21:27
rallyeash
just copy the img code on each photo from photobucket into the reply box Thumbs up
309 3dr K20 Type R
Posted 16th May 2011 at 21:31
So having digested all the previous comments and reviewing some of the other project threads - I realised that MY project thread was carp!
So I will try harder
Not easy when I can't get the damn photos to upload though¬Angry
Posted 29th Jun 2011 at 02:31
Having spent a couple of evenings playing in the shed I have fitted the suspension to the front and rear ready to get the shell rolling.
I have had to use spacers so that the wheels I have will fit without rubbing on the suspension. Because of this I got studs and wheel nuts to replace the bolts. However due to the studs coming undone sometimes I welded them to the back of the hub. Not sure it was a good idea but seems to have done the trick!
having painted the underside of the shell I was more than a little dissapointed by the appearance of the old parts. So I brought a sand blaster to tidy them up. Results to follow. Would appreciate advice on best paint to use on the clean parts though please.
(This ball joint had grown legs and was planning on escaping!)
Posted 29th Jun 2011 at 02:46
Huh?
yeah sorted
Posted 29th Jun 2011 at 02:50
thanks to you bud !
Posted 29th Jun 2011 at 03:11
I then went on to look at installing the gear lever.
I have rose jointed couplings that are from the doner car. I also bought a quickshift from a forum member.
Posted 29th Jun 2011 at 03:24
Before I could install the gear lever though I had to remove the existing plastic location ball and plastic sleaves from the gear stick. Not easy! Even though they had already cracked I had to grind the plastic off
When it was cleared it was looking ready for installation.
Then it all went wrong! Either I have brought a bad part or there is something not right with the play in this coupling!!!
The gear lever is not the same diameter as the opening in the quickshift. Any ideas on making this work?
I decided to fit the new lightened flywheel from Rich. Great product and nice guy to deal with
Posted 29th Jun 2011 at 03:32
