displaying posts 26 to 50 of 52
Pages (3): 1 [2] 3
Author Subject: KW V2 Kit - Also Advice on Handling
That's what I do, turn them full one way then, say, a half turn back.
Posted 16th May 2011 at 21:30
smegal
I should have read the instructions before posting.
Ex SC-6
Now in a Megane R26
Posted 16th May 2011 at 21:31
I have the same ones as the OP, and I need an adjuster (bought second hand and don't have one)
Which ones do I have so I can go to KW about it? Don't want to ring up and explain which type I have in German Laugh
Posted 16th May 2011 at 23:30
smegal
KW have a good UK office.
Just phone them up and ask for the plastic adjuster.
They may ask for the art number off the shock but I doubt they will.
Ex SC-6
Now in a Megane R26
Posted 17th May 2011 at 18:29
info@kwautomotive.co.uk is the address you'll want, they're pretty good Yes
Posted 17th May 2011 at 18:31
stu
Chris, I have a KW adjuster that came with my KW V2 kit when I bought it, however the shocks were the new design where you adjust them with an allen key.
So, I'm not sure why they sent me an adjuster, probably just trying to get rid of them or something.
I have since sold the shocks but I found the adjuster the other day in the shed, if it's the right one for your shocks then you're more than welcome to it. Thumbs up
I can get a picture if you like.
Posted 17th May 2011 at 18:37
techdw
I have just noticed something, Should there be a metal plate on top on the strut wr it bolts down??
techdw wrote:
Posted 18th May 2011 at 20:45
should be a metal cup under that nut yes!
Posted 18th May 2011 at 20:53
techdw
Ah , I thought something looked strange
Posted 18th May 2011 at 21:19
lotek
Post #35
those shock adjusters look IDENTICAL to Koni Yes
and by the sounds of it there just as hard to adjust.
and yes there should be a cup under the bolt. Crazy
Posted 31st May 2011 at 01:20
techdw
Post #36
Dont you just love the Rallye.. :-)
Posted 31st May 2011 at 04:34
techdw
Post #37
Just a quick update. I had a fooked droplink so replaced them both. Also fitted;
Roller bearing wishbone bushes From Rich_W
New Ball Joints
but would still like the handling to be improved.
What else can I uprate at the front..
Going to the rear of the car i already have Koni's and they seem set to soft as I can push the car down without much force.
Any more mods that would help??
Beam rebuild, seals and so on.
Hybrid ARB
Solid Beam Mounts
21mm Xsara Torsion Bars
Posted 27th Jun 2011 at 18:00
Post #38
"as I can push the car down without much force"
That's the springs (torsion bars) more than the dampers. Smile
Posted 27th Jun 2011 at 18:04
techdw
Post #39
Ah OK thanks phillip.
So the 21mm Xsara Torsion Bars will help alot with this!?
Posted 27th Jun 2011 at 18:10
dhampton
Post #40
Got V2's on the Rallye. Solid top mounts with some more castor, rebuilt beam, 25mm torsion bars, hybrid ARB. Ideal for track but the ride's easily acceptable for use day to day.
Clio 182 FF 306 Rallye (track) 306 Gti-6 Megane R26 Clio 172 Cup (track) 106 Rallye S2 (track) 306 Rallye Saxo VTR 106 Zest2
Posted 27th Jun 2011 at 18:30
Post #41
Incidentally I'm about to fit my adjustable top mounts to my KWs. Have you had any issues? Or just the usual crap trying to get the tops off the suspension to put on the tapered tops?
techdw
Post #42
Wr are the 25mm Torsions bars from mate? and also the solid top mounts.
Posted 27th Jun 2011 at 18:31
Post #43
KW and koni are one and the same aren't they?!
Anyway those adjusters are identical to the ones on the top of 205 koni yellow dampers from about 7 years ago (when I had some). Be very careful turning them as if they break the shock is fooked.
The top mounts are available from a few places iire, compbrake, spoox etc. PM Ash on here about the bars as he might have some (I don't mean Roland Rat...).
Posted 27th Jun 2011 at 19:04
techdw
Post #44
Iv already PM'd Ash about the ARB.
Just wanted to source the Torsions bars
Posted 27th Jun 2011 at 19:06
dhampton
Post #45
Picked ours up used. 23mm ones available from http://www.spoox.co.uk/ (at a price!)
Posted 27th Jun 2011 at 19:26
Post #46
Jesus, £375?!
Posted 27th Jun 2011 at 19:32
techdw
Post #47
£375.
MAD!!!
techdw
Post #48
Are the Xsara 22mm good enough over std? bet they cost a bomb from main dealers
Posted 27th Jun 2011 at 19:34
Post #49
Ask him about the bars too. I wasn't talking about the ARB Wink
Posted 27th Jun 2011 at 20:28
Post #50
xsara ones are 21mm, not that expensive from the dealers, £100 a piece IIRC.
Posted 27th Jun 2011 at 20:32
Pages (3): 1 [2] 3
