displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: KW V2 Kit - Also Advice on Handling
techdw
I have KW Coilovers V2 fitted to my Rallye, but I want to adjust the rebound, Height is perfect, I have the KW plastic key it came with and tried turning it but the plastic feels like its going to snap and break? Whats the correct way of doing this?
Thanks
Posted 27th Jun 2011 at 18:02
birk
Allen key.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 13th May 2011 at 23:08
lotek
take em off and sell em to me Yes
techdw
Haha!! I'll hang on to them Lotek.lol
Allen key is to adjust the Spring isn't it?
I want to adjust the damper .
Posted 13th May 2011 at 23:14
smegal
Pliers? Does it turn the other way? Mine seem quite free to turn. That said I don't actually know how to operate mine I just fiddle and hope.
Ex SC-6
Now in a Megane R26
Posted 14th May 2011 at 00:03
techdw
I was going to try Pliers Smegal, but but thought I would try the plastic ajuster it came with first. I take it + is to make it stiffer and - is to make it softer?
Posted 14th May 2011 at 04:14
Metal allen key in the top, adjust away surely?
Posted 16th May 2011 at 01:23
techdw
I got some type of plastic key to adjust it. Does the car need to be jacked up to adjust it?
Posted 16th May 2011 at 01:29
Nope. You're talking about the fronts, right? 2mm (iirc) allen key in the top of the strut, job done.
Give us photos.
Posted 16th May 2011 at 12:30
techdw
Yeah the fronts mate. Ill a Picture in a bit.
Posted 16th May 2011 at 14:15
techdw
Posted 16th May 2011 at 17:25
mole grips FWT, dont just wang it round though, wiggle it back and forth to free it off.
Posted 16th May 2011 at 17:31
Eew, wtf is that? Doesn't look anything like mine. I'd guess that yellow bit in the top just turns, but I'd soak it in some WD40 first.
rich_w
The adjustment instructions can be found on the KW Suspension website
Contact Details:
07732 822546
Posted 16th May 2011 at 17:32
rich_w
They've changed the design from that spade shaped spigot on the early ones, to a small allen key on the new ones Smile
Contact Details:
07732 822546
Posted 16th May 2011 at 17:34
Well, I simply must have the latest model Smile
Posted 16th May 2011 at 17:45
techdw
When I tried using the purple adjuster I have, it just feels like its going to break! Will hav to use mole grips.
Posted 16th May 2011 at 18:22
Yup, if it's siezed up you'll never turn it with the plastic jobby. Just don't damage it Wink
Posted 16th May 2011 at 18:31
Careful with the mole grips, that's a very long, very thin steel shaft, and you don't want to snap it...
Posted 16th May 2011 at 18:42
techdw
Think I may sell them and just get Koni's.. I dont really need KW's.
Yeah Ill leave it as it is, knowing my luck ill snap it.
Posted 16th May 2011 at 18:44
Just make sure you soak them in WD40 first, they'll be fine as long as you're careful.
Posted 16th May 2011 at 18:47
techdw
eah will do mate. Ill soak them in a whole can of WD40, that should do the job.
Posted 16th May 2011 at 18:48
Make sure plenty of it drips onto your brakes Wink
Posted 16th May 2011 at 18:51
techdw
lol
Posted 16th May 2011 at 18:52
smegal
When adjusting, can you turn the adjuster all the way. I have never really done much on mine and turning them all the way hard or soft then going back is the only way I can think of for getting them matched.
Ex SC-6
Now in a Megane R26
Posted 16th May 2011 at 21:28
Pages (3): [1] 2 3
