Author Subject: Play in steering rack
Long story short, I've finally had my tracking sorted after about a year and had them put on new track rod ends while they were there.
However on the way home, I noticed a knocking noise.
Assuming it was something to do with my new wishbones, roller bearings, balljoints etc I got it jacked up, couldn't find anything. Everything was good and tight, no play at all.
It wasn't until I got the wheels back on I realised the knock was from play in the steering rack. Called back the place who did the tracking, obviously the manager was on day off and no-one else could even look at it, but he did say he's never known changing a track rod to damage a steering rack.
So what's the deal? Is it knackered? Can it be adjusted? Does it need replacing? How hard is it to do?
I've been searching through but most people seem to get play in the column, not the wheels. Very annoying as I've got a trackday tomorrow and was looking forward to having the ultimate steering setup with my new roller bearings.
Cheers people.
O.
Posted 4th Mar 2011 at 14:49
mark.evs
Sounds like they might be faulty too mate. or just not tightened properly.
Take it down to another garage and have them to look over it for you.
My GTi6 track project
White Rallye project
Posted 4th Mar 2011 at 15:31
ive seen racks and columns go mate,its just wear and tear things on these cars Sad
racks not too hard,can get a bid fiddly at times
Posted 4th Mar 2011 at 15:39
Oh titties, that's annoying. Quite possibly it was just on the way out and changing the ends has just finished it off.
I was going to go back to the garage, but they're never going to say "oh well must be us, we'll replace the entire rack for free".
Will have to live with it for now until I can get another one then. I believe the Xsara rack is the one to go for, fewer turns for full lock? In which case, is it just the VTS rack or any?
Subframe doesn't have to come off does it? We don't seem to have an FAQ, yet Wink
Posted 4th Mar 2011 at 16:06
bennn
I think the subframe does have to come off to replace the rack.
Cherry Red 306 HDI
Posted 4th Mar 2011 at 16:09
Good times Thumbs up
Posted 4th Mar 2011 at 16:10
you can do it without removing the subframe but it's very tight and likely to make you lose your temper. been there done it
so yes. remove subframe to avoid needing facial reconstruction for removing forehead wrinkles
are there any differences in TRE's on the models?
Posted 4th Mar 2011 at 17:20
Nope, just one to rule them all.
Posted 4th Mar 2011 at 17:21
only thing i can think is if they've bent the steering rack removing the TRE's, which takes a fair bit but is possible
are the arms wound in aswell? or are they fixed? i seem to remember them spinning out on a rack i had - eg, they could be wound in a bit to counteract play (regardless of track rod end)
then again you'd notice massive play at 9-3 on the wheel and the track rod end itself is doing that job anyway. odd one
Posted 4th Mar 2011 at 17:25
It is indeed, doesn't seem to make any sense.
New rack time I'd guess Sad
Posted 4th Mar 2011 at 17:31
where is the play exactly?
Posted 4th Mar 2011 at 17:32
Hard to tell, both wheels will wobble side-to-side, so it's something rack-specific rather than to one TRE or rod.
Posted 4th Mar 2011 at 17:34
mark.evs
is there slight play in your steering wheel to?
Posted 4th Mar 2011 at 17:41
Hard to tell, there's always been a little but I wouldn't call it play as such, just what you'd expect on a car like this.
Steering with the wheel doesn't cause it to knock though certainly.
Posted 4th Mar 2011 at 17:55
tvrfan007
You can't use a VTS rack without inhibiting the lock, remembers. Smile
I'm fitting a P2 VTS rack to my Rallye. Yes
You can get play in the tie-rods that go from rack to TRE. I have to change my passenger one as it had play in it during the MOT. there are a couple of threads on here for it.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Mar 2011 at 19:41
Yeah remember seeing something about that, put the standard ram onto the VTS rack or something?
Posted 4th Mar 2011 at 19:42
Don't forget there are inner track rod joints as well as the outer ones Thumbs up
Motaquip do these for about £15 each iirc, part of the track rod.
Posted 4th Mar 2011 at 22:57
FAIL Wink
Posted 4th Mar 2011 at 23:51
I did not know that, I'll take a look Smile
...between laps.
Posted 4th Mar 2011 at 23:53
monkgti
yep, theres the inner tie rods that connect directly to the rack and then the TRE's connect on to them.. I had to change one of mine a while back as it had play in it aswell. With the wheelks off the ground is there play in both wheels or just the one?
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 5th Mar 2011 at 01:55
Both wheels.
Posted 5th Mar 2011 at 02:01
tvrfan007
roland rat wrote:
FAIL Wink
FOYC! LOL It's going on my seam welded subframe. Smug
...between laps.
I said it before Welshpug!
I'm Si btw Tee hee
Posted 5th Mar 2011 at 02:42
davedgti6
You need the phase 1 Vts rack, that's the quick 2.4 turns one, phase 2 Vts is similar to gti-6 I think,
very good mod though, you can take small/medium roundabouts without shuffling your hands like you have to do with the six rack,
Posted 5th Mar 2011 at 02:44
TVR - Sorry mate, you said about tie rods which I assume are the actual bars, Welshy specifically mentioned that they have joints of some description.
Some how I couldn't see a rod going wrong, but a joint I could Yes
Wasn't ignoring you, sorry! LOL
Phase 1 eh? Cheers buddy Smile
Posted 5th Mar 2011 at 02:47
tvrfan007
They're listed as tie rods in the parts catalogue. They screw into the rack and the TRE screws on the end. Smile
Dave, you lot told me the xsara racks were both quicker! Where does the info actually come from regarding locks as I was told the VTS one was 2.6 on Phase 2? I broke a P2 for parts.
I'm Si btw Tee hee
Posted 5th Mar 2011 at 02:51
