displaying posts 1 to 25 of 51
Pages (3): [1] 2 3
Author Subject: *XSARA vts breaking*
pugplus!
Hi all, i have a lovely xsara vts up for breaking with only 80,000 miles.
It came from a middle aged couple who looked after it very well and mechanically this car is sound.
Everything is in mint condition and works perfect drives 100% so all mechanical parts off this car will be good.
Parts & Price list:
Exterior
1: Bonnet £30
2: Front bumper £70
3: Wings £20 each
4: Grill £10
5: Hockey sticks £8 each
6: Tailgate £30
7: Side Skirts £35
8: Rear bumper £30
9: Headlights £15 each
10: Tail lights £10 each
11: Doors bare £20
12: Rear quarter windows £10 each
13: Door glass £20 each
14: Windscreen £25
15: Door mirrors £10 each
16: Bonnet badge £10
Interior:
1: seats £60
2: Door cards £20
3: Steering wheel £25
4: Clocks £15
5: Wiper/light stalks £5 EACH
6: Carbon affect dash facia and trim £40
7: Dashboard bare £15
8: Rear quarter cards £15
9: Carpet £10
10: Gear Knob & gaiter £20
11: Handbrake mech £5
12: Seat belts £10 each
13: Roof lining £10
14: Roof grab handles £10 full set
15: Sunroof switch unit £10
16: Interior light £3 each
17: Ariel £5
18: Rear view mirror (rain sensor) £10
19: Heater control board £15
20: Center console (around handbrake) £10
21: All dash switches i.e hazard lights £3 each
22: Heater motor £20
23: Relays £3 each
24: Door looms £25 each
25: Window regs £20 each
26: Door/boot seals £10 each
27: Boot liner £15
Mechanical parts:
1: Rear axel without brakes £100
2: Rear calipers £25 each
3: Rear shocks £25 pair
4: Hubs £20 each
5: Long shaft £20
6: Short shaft £15
7: Steering rack £25
8: Front brake setup complete £100
9: Front struts with springs £25 each
10: Arb £15
11: Bottom arms 18mm £15 each
12: Gear linkage set (3) £10
13: Main gear rod £5
14: Gear stick £10
15: Lift up reverse cable £10
16: Power steering pipe (rack-pump) £20
17: Front abs sensors £10 each
18: Rad £40
19: Fan cowling with fans £25
20: Air Con rad £20
21: Full set or air con pipes £45
22: Abs unit £20
23: Heater matrix pipes £15
24: Bottom rad hose £15
25: Master cylinder £20
26: Backbox very good condition £45
27: Mid section very good condition £25
28: Cat £45
29: Wheels £100
Engine/parts price list:
1: complete engine with loom and unlocked ecu £450
I would like to sell the engine complete as its a very very good non tapping engine with good service history but if i have to split here are the prices:
2: Head complete with cams & carriers £180
3: Bare inlet £20
4: Throttle Body £35
5: Fuel Rail £15
6: Injectors £25
7: Exhaust manifold £25
8: Cam covers £20
9: Alternator £20
10: Starter £15
11: p/s pump £20
12: Cambelt cover complete £15
13: Top engine mount casting £5
14: Lower engine mount casting with mount £15
15: Coil packs x4 £20
16: Thermostat housing £10
17: Thermostat elbow £5
18: Coil cover £10
19: Bottom pulley £10
20: Flywheel £15
21: Sump £25
22: Oil pump £15
23: Rods & pistons £40
24: Bare block £20
25: Clutch complete £20
26: Loom £35
27: Heat exchanger £10
28: Icv £10
29: All engine sensors £5-£10 each
30: Top rad to rad pipe £10
31: Left cam cover breather hose complete £12
32: Right cam cover breather hose £5
33: Crank £30
34: Oil spray bars £10
35: Lifters(16) £25
36: Camshafts & carriers £40
37: Cam pulleys £25
38: Vacuum pump £20
39: vacuum pipe pump-servo £15
40: Cambelt tensioner £5
41: Cambelt idler & roller £5 each
42: Inlet complete £80
43: Bottom end complete £100
PLEASE NOTE! All prices are excluding post.
We also ship international Please ask for postage quote`s.
I think they are very reasonable prices but still open to offers on most parts.
All small parts will be posted with royal mail first class and larger items with dhl 48hr service. I can also arrange for pallet collection for bottom ends/complete engines or bigger orders.
Most parts are on the shelf so will be dispatched same day if ordered before 2:00pm for next day delivery otherwise they will be dispatched the day after,This only applies to small parts.
All dispatch times will be given before orders are placed so you will know when to expect your parcels and will not be let down as some orders may take a few extra days than normal to complete.
Please read our return policy before purchase.
Return policy:
All returns must be made within 14 days of purchase date,anything after that i'm afraid we cannot process. All returns must be wrapped very well to prevent damage as damaged returns cannot be refunded. we will then inspect the part and either send out a replacement or send you a refund, we cannot be held responsible for return costs i'm afraid.
Please make sure the part you order is correct for your car before purchase as we cannot refund mistake purchases im afraid.
Contact info:
Email: pugplus@hotmail.com
Tel: 07532066648 (richard)
Pugplus Peugeot parts specialists!!
1000`s & 1000`s of new & used parts in stock
International shipment
Genuine Peugeot parts suppliers
A range of Peugeot's for sale
Contact info:
Mob:07532066648 (richard)
Posted 18th Aug 2011 at 00:19
matt evans
Hi, how much for the Aux belt cover c/w fitting bolts?
honestly3k wrote:
owain wrote:
Posted 27th Feb 2011 at 23:21
jord294
is the axle including postage?
Posted 27th Feb 2011 at 23:27
pugplus!
hi, i could do it for that price posted without the brakes and shocks.
other wise they weigh 60kg and are very expensive to post.
many thanks,richard.
Contact info:
Posted 28th Feb 2011 at 00:40
pugplus!
hi, did you want just the little cover over the power steering pump pulley?
Contact info:
Posted 28th Feb 2011 at 00:56
matt evans
Yeah sorry thats what i meant.
Posted 28th Feb 2011 at 01:45
pugplus!
ok no problem atall i can do that for £10 inc post.
Contact info:
Posted 28th Feb 2011 at 02:39
mattgti6phase2
Washer jets please Big grin
How much posted?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 28th Feb 2011 at 02:43
stilly
you have pm...Big grin
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 28th Feb 2011 at 02:52
pugplus!
How much posted?
hi, call it £5 to you because you are having other parts from me aswell.
Contact info:
Posted 28th Feb 2011 at 14:42
pugplus!
hi,pm reply it would be £110 inc post.
Contact info:
Posted 28th Feb 2011 at 14:43
j collen 306
would like the gear box how much to sent it to Ireland Dublin and ill sent the money straght over
thanks
Posted 28th Feb 2011 at 21:01
pugplus!
thanks
hi, i can do that for £100 for the box and around £50 for post due to the weight.
Contact info:
Posted 28th Feb 2011 at 21:44
binkagti
Hi mate, how much for the back box posted? to canterbury kent
TEAM Supercharged Rallye
Posted 1st Mar 2011 at 00:02
pugplus!
hi, i can do that for £45 inc post (price is in the listing). its in very good condition and is not that old.
Contact info:
Posted 1st Mar 2011 at 00:08
binkagti
How would you like payment mate?
Posted 1st Mar 2011 at 00:43
pugplus!
hi again, paypal would be fine, did you want me to pm you the details?
Contact info:
Posted 1st Mar 2011 at 20:01
binkagti
hi can you pm me mate, oh your inbox is full aswell
Posted 1st Mar 2011 at 23:42
ed_doe
Dibs on rear beam as discussed earlier on the phone
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 2nd Mar 2011 at 02:31
pugplus!
hi, ill pm you the info now. many thanks,richard.
Contact info:
Posted 2nd Mar 2011 at 16:04
ed_doe
Rear Beam sold to MEEEE :] Paypalled, please confirm delivery date Rich.
Posted 3rd Mar 2011 at 14:40
ed_doe
EDIT: Internet fail Roll eyes
Posted 3rd Mar 2011 at 17:10
pugplus!
hi ed, i will be taking the engine out over the weekend so ill take the beam off at the same time.
it will be posted out monday for you with dhl so you should have it by wednesday.
Contact info:
Posted 3rd Mar 2011 at 18:26
pugplus!
UPDATE:
gearbox
long shaft
rear axel
steering rack
engine
SOLD!!!!
Contact info:
Posted 11th Mar 2011 at 01:15
pugplus!
bump
Contact info:
Posted 7th Mar 2011 at 14:38
Pages (3): [1] 2 3
