displaying posts 1 to 25 of 53
Pages (3): [1] 2 3
Author Subject: Fitting Track Rod
ravemercer
Will be fitting these next weekend along with wishbones, track rod ends, droplinks, B4 Bilstien's and strut mounts.
Fitted all the other bit's before just not the track rods just wondered if there's anything worth knowing before I start the job probably on a cold rainy Saturday morning.
Posted 13th Jan 2011 at 00:04
rallyeash
obviously get the tracking done straight away.
fitting a new track rod end too? may aswell at the same time
309 3dr K20 Type R
Posted 13th Jan 2011 at 00:14
ravemercer
Doing track rod ends as mentioned above you fitted these before are they easy or a pain in the arse ?
Posted 13th Jan 2011 at 00:43
rallyeash
alot easier than trying to remove the TRE from the old track rod, normally requires heat
309 3dr K20 Type R
Posted 13th Jan 2011 at 00:47
ravemercer
yeah can be a right c*nt jack it up gets a bit of pressure to get the nut off.
Posted 13th Jan 2011 at 02:20
eddy_gti6
i will be doing these at the weekend along with track rod ends, ball joints and drop links
Posted 13th Jan 2011 at 02:24
ravemercer
Should be nice and fresh afterwards.
How much did you pay for the track rods ?
Posted 13th Jan 2011 at 02:44
rallyeash
i picked up 2 TRE's from a factors last week at £7 a pop.
although that was for a 205 but can't see beeing much different
309 3dr K20 Type R
Posted 13th Jan 2011 at 03:04
ravemercer
Cheap enough might as well do them while your there paid £9 eurocarparts.com iirc peugeot wanted roughly triple that.
Posted 13th Jan 2011 at 03:09
russbez
see on the passenger side, there is a black rubber cover? im pretty sure last time i done mine i damaged the sleeve/cover
didnt you have issues getting the track rod unscrewed to fit new rod?
My Rallye project thread
Posted 17th Jan 2011 at 16:53
ravemercer
fitting this saturday as waiting for new shocks and mounts.
there should be a retaining clip then slide back the rubber boot by all accounts there real stiff to unscrew hopefully theres a couple of flat spots for a spanner as new ones i got do.
will take some pics and post up sunday if all goes well.
Posted 17th Jan 2011 at 18:09
russbez
good luck and let us know how you get on
Posted 17th Jan 2011 at 21:33
SteviePut
I need to get these changed on mine. There's slight play in the current ones. Hope the play isn't too excessive for the MOT tester on WednesdayLOL
Posted 17th Jan 2011 at 23:05
russbez
im looking at my track rod (not tre)
and theres a fair bit of play in it, how the f*ck do you get them off LOL
mine is similar to top right of picture of post one except... well its not the same
i will get pictures
Posted 18th Jan 2011 at 00:33
SteviePut
i will get pictures
Remove the gaiter and unscrew it from the rack I thinkSmile
Posted 18th Jan 2011 at 01:23
jbradders
Bit of info
Posted 18th Jan 2011 at 01:27
russbez
mine doesnt seem to have the notch for a spanner like in picture from post 1
it has a wierd knuckle round the inside of it, nothing fits in it
Posted 18th Jan 2011 at 01:58
russbez
really small pair of stilsons maybe?
Posted 18th Jan 2011 at 02:16
jbradders
Or grips and a hammer.
Posted 18th Jan 2011 at 02:18
russbez
little or no room i would of thought
Posted 18th Jan 2011 at 02:28
Stilsons/grips according to users on hereSmile
Thought I was going to have to remove my drivers side one when TRE was seizedAngry luckily came undone with some heatWink
Looked at removing mine,but as you say not much roomBlink I reckon on full lock and go at it from under the front wheel arch will give you best chance/most roomWink
Posted 18th Jan 2011 at 03:19
tvrfan007
Handy thread, I got an advisory for this last week on the n/s. Was just looking for a post like this when someone bumped it to the top.
I wonder if it's any easier on the HDi. Hmm
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 18th Jan 2011 at 12:48
russbez
theres no way room for a hammer LOL
getting a new track rod tonight
(reason im replacing it is that theres is excess movement in the joint on the actual track rod)
Posted 18th Jan 2011 at 21:30
ravemercer
Will try to mock up a faq this Saturday grips are the way forward eddy managed to get these off with a hammer and grips hopefully I'll do the same.
Posted 19th Jan 2011 at 04:25
russbez
done passenger side last night, had a new rubber sleave to go with it (got it off peugoet a while back).
took heap of pictures, basicly you need to change the steering wheel position so it moves your wrack.
for passenger side i had steering on hard left.
thus letting me see the knuckle of the rod a bit better and get vice grips in from underneath subframe, loosen it like normal.
rubber sleave i put in boiling hot water to loosen it up and it pops on reasonably easy
this Yes
Posted 19th Jan 2011 at 15:00
Pages (3): [1] 2 3
