when under hard braking the rear beam vilontly vibrates, what could cause this?
cheers!
| Author | Subject: rear beam vibrating when hard braking? |
zxturbo400
Regular Location: rugeley Registered: 21 Dec 2010 Posts: 104 Status: Offline |
Does anyone know what this can be? the cars lowered 80mm and is on the bumpstops ( shit i know) and the rear shocks are leaking (obviously) when under hard braking the rear beam vilontly vibrates, what could cause this? cheers! |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Rear beam mounts foobarred!________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
everything is fooked, come back when you've sorted that ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallyeash
beam mounts, rear discs, shagged shocks.also bring it up 40mm, might look alright then too ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
FACEPALMSMILEY ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
rallyeash
??![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
welshpug! wrote: everything is fooked, come back when you've sorted that My thoughts exactly. How can you expect it to do anything else when you've listed faults already? daveyboy wrote: FACEPALMSMILEY ![]() ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
sounds like yo need a complete back end mate. your disc are fooked causing the beam to vibrate because its to low which proberly hasn't been apart since it was lowered which was more than likely done the wrong way. get it sorted________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
zxturbo400
its drum btw, cheers for imput, il tell him to get another beam for it, was fine at 120mm when i had it and after being sat for months its had no use so dont know why its just startedcheers |
might be oval drums then.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
zxturbo400 wrote: was fine at 120mm ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
zxturbo400 wrote: was fine at 120mm The tarmac was absorbing the vibration. ________________________________________ pet hate, the cat |
zxturbo400
Aye, had no bump stops and everything was on the floor, i guess its only 80 at the momment, il get the drums off and have a look at the rear end! its a horrible vibrating that goes right through the car, its gained so many problems since i owned it |
rallyeash
always makes me laugh, people think the lower there car is the cooler it is too...________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
zxturbo400
was as low as a mx5 roof wise, handled shite and couldnt go anywhere when i had it, the bottom of it was mashed, il get pics of the underside when we change the steering rack and beam (if thats the problem!) |
