displaying posts 1 to 25 of 40
Author Subject: Reasonable price for brake replacement?
nicknpip
I've just had a quote for replacement of rear discs and pads, near and offside rear hoses, and the nearside rear caliper (if necessary - possibly seized), and fluid flush. (it's a 306Hdi)
£45 for the flush
£96 for the rear pads
£125 for the rear discs
£80 for each hose
£154 for the caliper if needed.
Is this a reasonable quote or should I look elsewhere?
Posted 30th Dec 2010 at 22:47
mr swampy s16
**BAD SELLER**
The hose price is that fitted?
Standerd rubber hoses from gsf are about a tenner each, i can supply braided ones for £25 the pair!
Rear pads standerd spec around £25 the set
rear disks around £25 each for decent quality ones.
Posted 30th Dec 2010 at 23:06
brownboy
£500 for all that id be telling them to f*ck right off
Posted 30th Dec 2010 at 23:29
gilesy
f*ck my old boots, that's disgusting.
I hope they kiss you before they bend you over!
For info you should name/shame this place, maybe we could continually call them and ask for quotes.
That is waaaaaaaaaay overpriced
Posted 30th Dec 2010 at 23:43
laurentgarnier
Agreed!!!
I'd most definitely be looking for another garage to do the work.
The Leveller
Team China™
Laurent Garnier "The Man With The Red Face"
Posted 30th Dec 2010 at 23:46
mr swampy s16
**BAD SELLER**
Them kind of prices are what shit fit would charge.
Posted 31st Dec 2010 at 00:16
SteviePut
Get the parts from buypartsbuy.co.uk and bring it all down to me and I'll fit the lot fro just a few beer tokensThumbs up
Posted 31st Dec 2010 at 01:09
brownboy
carl mechanical repairs on her is breaking a hdi so you could get the caliper off him which should be around the £40 mark disks are about £30 pads around £20 and the £25 for the lines off swampy and some break fluid looking at about £120 ish for parts and then beer tokens for steve job done Smile
Posted 31st Dec 2010 at 01:18
SteviePut
Rear discs from BPB are only £5 a pop Wink
Posted 31st Dec 2010 at 01:34
In summary:
nicknpip wrote:
Is this a reasonable quote?
No.
Posted 31st Dec 2010 at 01:59
nicknpip
Cheers for the replies - I also realised mine's not a gti6 so thanks for the replies anyhow!
Halfords Autocentre - first place I went as I'd already had to drive 2hrs down the M4... I knew they'd be top retail prices but knew it was worth a check on here first. SteviePut, where abouts down south are you?
Posted 31st Dec 2010 at 20:35
brownboy
That is a disgusting over inflated price even for halfrauds i wouldnt even think it would be that much at a stealers Blink
Posted 31st Dec 2010 at 21:15
mr swampy s16
**BAD SELLER**
Rears ard all the same throug out the range
Posted 31st Dec 2010 at 21:32
vulpine2
Thosed prices are just obscene. I can recommend the Mintex box set (ie rear discs and pads) which can be had for less than £45 delivered.
Cheers,
Rob
Posted 10th Jan 2011 at 12:18
lotek
nicknpip wrote:
£45 for the flush
£80 for each hose
Laugh my ass off
.discs are a tenner each on buypartsby.com
.hoses are like 40 from swampy
.if you need rear calipers i have 3 @ £30 each
if fronts needed you can get a pair for like £60-90
flush you can do with a friend, or pay me or hovis to fit and bleed the lot , your only down the road from us (reading)
Posted 10th Jan 2011 at 21:13
he needs your rear cailpers
Posted 10th Jan 2011 at 21:14
allesclar
no not a reasonable price, its a disgusting price.
go else where.
Team allesclar ®
Posted 10th Jan 2011 at 21:17
I'd happily do the lot for £450 (Mates rates Wink ) LOL
Posted 10th Jan 2011 at 21:26
monty-69
I have just fit and supplied new rear discs and pads and a rear caliper to a 306 today and the bill came to £150. Them prices sound a bit on the steep side
Posted 11th Jan 2011 at 03:10
lotek
my offer to do the work still stands Whistle
back on the weekend,
need some money for my repmobile fund LOL
Posted 11th Jan 2011 at 03:57
miles
Very steep, And knowing most service stuff at Halfords is cheap the mark up on that is as bad as the 'Kays or Littlewoods'
Flush whats that all about.
I'm impressed they knew about the callipers thou as the bleed nipples which often snap off meaning a new calliper so bear that in mind.
But as said all that should come in around £150.00,
Disc's £30.00
Pads £21.00
Hose's £16.00
Dot 4 Brake Fluid 1L £5.00
S/H Calliper £25.00
Labour £45.00 (Hour ish)
Total £142.00 (Close to est)
www.pugracing.com
Posted 11th Jan 2011 at 07:52
tvrfan007
Fluid flush is just the way they've presented a change of brake fluid to him Miles.
You could get that lot done at a smaller garage much cheaper, or better yet learn to DIY and do at least the pads and discs yourself and get a garage or a skilled friend to do the hydraulics.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 12th Jan 2011 at 13:03
Biggest stumbling block will likely be siezed rear bleed nipples. These will cause you grief if you snap one off so investigate local availability of rear calipers before you start the job.
Posted 12th Jan 2011 at 13:12
lotek
quote:
[quote="daveyboy] investigate local availability of rear calipers before you start the job.
Whistle
Posted 12th Jan 2011 at 18:45
nicknpip
Just ordered the pads and discs from BPB for £38, need the hoses from Swampy and will have a look at the calipers when I take the lot over to Hovis. My plan is to watch and learn and end up doing as much DIY as possible! Once the Smart's sold I'll have the garage for workspace as a bonus.
Lotek, Hovis and I work together - he's offered me the calipers if I need them, cheers.
Posted 13th Jan 2011 at 01:47
