cheers
Team Astor
displaying posts 1 to 25 of 44
| Author | Subject: revving out |
daytime-6
Regular Location: devizes Registered: 06 Jan 2010 Posts: 133 Status: Offline |
for the past few days ive noticed that i can rev to 4000rpm but after that it struggles like hell,has anyone else had the same problem,ive tried cleaning my map sensor and changing coil packs over but still have the same problem every timecheers ________________________________________ Team Astor |
anth
Bottom end f*cked? |
joevts
Senior User Location: barnsley Registered: 21 May 2008 Posts: 608 Status: Offline |
what does it sound like when it gets to 4k? i had a similar problem in my paxo once, turned out a stray tennis ball had rolled under my seat and got wedged under the throttle pedal hope yours turns out to be something daft like that, NOT a f*cked bottom end, because that's just not funny |
daytime-6
hope not, its had a full rebuild about 20,000miles ago ![]() ________________________________________ Team Astor |
daytime-6
it sounds like its runnin out of rev's n slows down and i can just get over 5,500rpm , like if it hasnt got a rev limiter n dies down if you now what i mean,________________________________________ Team Astor |
joevts
ignition timing maybe? could be the crank position sensor or something. |
daytime-6
Were abouts would the crank position sensor be as I'm kinda new to were these parts are ?________________________________________ Team Astor |
joevts
i have no idea sure someone else will though |
Crank sensor is on top of thr gearbox under the thermostat housing ![]() I'd say maybe the TPS (throttle posistion sensor) has gone or even something fouling the accelarator cables path causing this |
daytime-6
I've had a look at the cable and it all looks pretty free and nothing making it restrict it's self,how can I test the TPS sensor for if it's working or not?________________________________________ Team Astor |
Get a multimeter and see what reading your getting from it.all the reading are in the FAQ section somewhere |
daytime-6
Ok cheers will give it ago when get home,cheers for help________________________________________ Team Astor |
smegal
Blocked cat or exhaust.________________________________________ Ex SC-6Now in a Megane R26 |
daytime-6
'the car sometimes feels like its holding back on the power it has and other times it goes like 'Thats what I got when looking at the other threads on throttle position sensor and I'm having the same problem so it defo has to be my TP sensor ________________________________________ Team Astor |
smegal wrote: Blocked cat or exhaust. Good shout mate |
daytime-6
I've got a magnex cat back system and it's got a rattly centre section but it's been like it since I've had the car ,you reason I should go to a mot station n ask them to test my emissions?________________________________________ Team Astor |
spiky
Seasoned Pro Location: Cardiff Registered: 13 Oct 2006 Posts: 2,310 Status: Offline |
maybe the rev counter is mis reading?________________________________________ Do you need a 205 > 306 gti6 plug and go engine loom? PM METORQUES for all your braided fuel line needs MY YouTube Videos' SUPERCHARGED 205 GTI6.... are you Fooking nuts!.... ummmm YIP ![]() 268+BHP and 860kg = FUN |
daytime-6
Na that reads ok ,it revs ok whn not in gear it's only when you put load on the engine that it doesn't wana performe how it should do________________________________________ Team Astor |
rallyeash
crank sensor, throttle pot sensor, icv, lambda, colapsed/blocked cat.if the engine sounds alright below 4k i'd looks at checking those. ive got spare cat mate if you want one to try. crank sensor is only like £20 from a factors. injectors all firing alright? could be injector gone down or dodgy connections when the throttles fully down the butifly is open fully. got injectors/rail you can use to fault find but you cant keep it. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
daytime-6
I tried the emissions n there fine,I'm guna order a new tps and a crank sensor tomorrow and see if they sort the proplem out,yer it pulls reali well up till 4k thn hardly anything happens after that________________________________________ Team Astor |
wont be the crank sensor if it runs, they tend to work, or not.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daytime-6
so u recon it will be the tps then?________________________________________ Team Astor |
rallyeash
ive had a faulty crank sensor which was giving weak readings but genuinly yes eithere they work or don't.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
daytime-6
So should I buy both or buy one at a time and go from there?,why's your number ash i don't think I've got it lol________________________________________ Team Astor |
rallyeash
07796313382.upto you mate, could buy one at a time but with xmas shutdown could take a while to order one at a time so i'd buy both. lambda sensor alrite? ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
