displaying posts 26 to 44 of 44
Pages (2): 1 [2]
Author Subject: Using a strut brace with solid top mounts
You do need a strut brace, the turrets on a 6 are made from tinfoil. You do want a decent brace (Limited number of choices as it's not a popular modders car) so a steel one is the obvious choice. And I can see no reson why a competent mechanicaly minded person could'nt make provision for a fourth bolt using the OMP brace. Now about this gay stuff you were after, not my scene but I prpbably know someone that can sort you out, what exactly were you after? Leather chaps perhaps? Or a stick on handlebar moustache? Razz
Posted 20th Dec 2010 at 18:30
pugheaven
If I had a omp brace Im sure I could sort something out but as I don't have one how do I know that I can get a bolt in under the brace it's self, hence y I'm asking, no point in buyin one to find out the bar will be in the way!
Posted 20th Dec 2010 at 18:39
allesclar
i have an omp strut brace with 3 hole in it, bolted down no problem.
i presume from the other thread you are wanting to know about the 4th hole location? i would assume it would be fine to CAREFULLY drill through the struct brace to get the extra hole down?
Team allesclar ®
Posted 20th Dec 2010 at 18:42
pugheaven
Daveyboy could you make an omp strut brace fit using all 4 bolts?
Posted 20th Dec 2010 at 18:43
pugheaven
Thanks dude just wanted to know if the cross bar will be in the way of the 4th hole or is the bar offset to allow a bolt every ¼?
Thanks
Ollie
Posted 20th Dec 2010 at 18:46
I suspect so, if you want to swing by some time you can offer my brace up and take a look for yourself.
Posted 20th Dec 2010 at 18:50
pugheaven
No engine in the car so that might be a bit of a problem! Just want to make sure I can pitch the hole on the right place before I go and buy one! A side on view of the strut brace fitted would be good aswell as a birds eye view to see if it's possible to do!
Posted 20th Dec 2010 at 18:59
Looking at it, its going to be tough getting your bolts in the 9 o'clock and 3 o'clock positions on the passenger and drivers sides respectively.
There are a few options but I think that as the OMP brace covers up what effectively would be the location for the fourth bolt hole, you won't see that it's not there anyway.
Posted 20th Dec 2010 at 19:24
pugheaven
That's more like it! So it looks like I'll just keep mine and not bother with the forth bolt as no matter what brace I get it will be the same, looking at the omp one I might be able to grind away a bit of the plate away so the bolt can be used it just won't go into the brace, if you understand what I mean!
Posted 20th Dec 2010 at 19:33
Post #35
why the obsession with the "4th" bolt? there is no "4th" bolt, you're just making un-necessary work for yourself.
Posted 20th Dec 2010 at 19:38
pugheaven
Post #36
Surely the more the better! If iv already drilled the hole I might as well use it! Maybe if I had noticed the problem before I would have left it with just 3.
Posted 20th Dec 2010 at 20:01
Post #37
More weight, no benefit...
Posted 20th Dec 2010 at 20:03
allesclar
Post #38
actually the more the better isnt necesserily true.
Team allesclar ®
Posted 20th Dec 2010 at 20:05
pugheaven
Post #39
I'm goin to drill the centre out of every bolt to loose weight lol. I know more isn't better as it will make the turret more flimsy if i used every available hole on the top mount but as iv already drilled the 4th hole I may as well use it!
A) I wish I had never drilled the hole, Cool I wish I had never asked on this forum!
Posted 20th Dec 2010 at 21:02
Post #40
So do we...LOL
Posted 20th Dec 2010 at 21:28
allesclar
Post #41
LOL
Team allesclar ®
Posted 20th Dec 2010 at 21:46
pugheaven
Post #42
Was it really a stupid question? All I asked for was if anyone knew of a strut brace that would accommodate the 4 bolts I have on the top mount! Can't remember if I asked if it's ok to use 3 or even 2 bolts?
Posted 21st Dec 2010 at 05:05
Post #43
It is, put the drill away, go drive it.
Posted 21st Dec 2010 at 07:00
chrisd306
Post #44
This was mine before i drilled a hole for the 3rd top mount bolt, ive got 3 bolts hold the top mount and 3 that hold the braqce in place. dont have a pic showing it tho
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 21st Dec 2010 at 15:00
Pages (2): 1 [2]
