displaying posts 51 to 75 of 103
Pages (5): first .. 2 [3] 4 .. last
Author Subject: Rallye Track Slag
r4ly j
Post #51
Finally got a start on getting the rallye roadworthy for mot.
Passed with flying colours, repainted calipers red and fitted ds3000 pads. Today was dedicated to fitting the bodies and sensors for gauges.
Then started making a cardboard template for the inlet.
And then cut it out of 1mm alu plate.
Bought some trim edging off eBay for £2 a metre.
Finally after many test fittings to get angles wright and clearance on power steering pump got it all fitted up and I'm well chuffed with the result, big thank to my mate Jim it's bin a long day.
Just got injectors to fit, make up a linkage, wire up the emerald and finally fit a 16row mocal cooler.
Should be up and running next week.
Posted 15th May 2011 at 15:18
Post #52
Looks strangely familiar Wink
[IMG]http://i401.photobucket.com/albums/pp94/daveyboy69bucket/100_0590.jpg[/IMG
Nice job, get some supports on it though or it will fatigue along the fold line at the front and crack, also it looks a little close to the trumpets, you don't want them rubbing on it when the engine moves Smile
Posted 15th May 2011 at 06:46
r4ly j
Post #53
Same idea, that one hasn't got pas for some reason, pain in the ass to work round.
Posted 15th May 2011 at 08:12
r4ly j
Post #54
If anyone has any ideas about throttle linkage, ive got few ideas but a tried and tested would be better other than spending £100 on a jenvey linkage. Also as Willygti pointed out I as fitted some cage padding last week.
Posted 15th May 2011 at 14:10
matty_rallye
Post #55
Ive never used jenvey throttles, however from seeing cheaper linkages on carbs you seem to get what you pay for. Someone else may know of something different tho.
Car looks very nice aswell!
2.1 16v 306 Rallye.
Posted 15th May 2011 at 14:44
paddygti-6 Banned!
Post #56
i always thought that to fit throttle bodies you need to relocate power steering pump???
pat
Posted 15th May 2011 at 21:37
r4ly j
Post #57
Not to sure on that mine fit fine. Maybe if you were running 48 or 50s maybe.
Sorted out my linkage too will get some pics up tomoz when I should have it all sorted.
Here's a mock up of it so far.
Posted 16th May 2011 at 00:17
chrisgti
Post #58
Looking good jay will be good to see it when it's done
270 bhp N/A Made by pug1off
¼ mile 13.6
Posted 16th May 2011 at 00:24
Post #59
Don't have to, its just easier as you get more room to fit airbox/airscoop Thumbs up
Looking good mate Big grin
Posted 16th May 2011 at 00:26
rallyeash
Post #60
im running a jenvey linkage, as expected works without issues. i did once have a cheapo linkage on a set of carbs and had to be replaced with a proper one due to being unreliable.
yes there expensive but i don't think its worth skimping on somthing as important as the throttle system. i'd pay £100 not to have the throttle stuck wide open trying to brake into a corner on track.
p.s car looks great!Big grin
309 3dr K20 Type R
Posted 16th May 2011 at 00:38
r4ly j
Post #61
I've sorted the throttle, simple but should be effective. Had to reshape paddle slightly to gain a little more travel travel,
fitted fuel rail and injectors, hole and alu duct to feed throttle cable and air temp sensor.
Posted 17th May 2011 at 17:34
velar
Post #62
Throttle linkage looks good, but how are you going to fit an air filter ???
Posted 18th May 2011 at 00:52
rallyeash
Post #63
won't that have a chance of slipping off the side?
could have issues with the filter though
309 3dr K20 Type R
Posted 18th May 2011 at 01:04
r4ly j
Post #64
I have filled a groove into the cable runner to take the cable so it can't come off, I was goin to get some trumpet socks like these
Example: clicky
Posted 18th May 2011 at 03:03
Post #65
nooo not socks! they sap power, you need a sausage filter and a backplate.
Posted 18th May 2011 at 03:20
chrisgti
Post #66
Jay if u want some socks I have some if u want to make me a offer for them
¼ mile 13.6
Posted 18th May 2011 at 03:35
rallyeash
Post #67
don't buy socks, they tend to get inverted and the foam sticks to the plugs and you'll end up with a misfire and changing plugs. also sap a good bit of power!
309 3dr K20 Type R
Posted 18th May 2011 at 03:44
r4ly j
Post #68
Well I'm not sure on the options then really, got any pics of ur socks Chris. In kinda out of funds. You ever had anything go in yours uncovered Chris??
Posted 18th May 2011 at 05:03
matty_rallye
Post #69
Avoid socks, they are terrible. Saps the power and i have known them to get sucked in and jam the throttle body open. Could be worse than that and get stuck in a valve!
2.1 16v 306 Rallye.
Posted 18th May 2011 at 23:54
Post #70
It's my car, and it has the PAS pump relocated to the brackets on the sump. The reason is to give enough clearance to allow the fitting of a decent sized dome filter as you can see there is little room for that as standard.
Posted 21st May 2011 at 01:07
r4ly j
Post #71
Well after a very long weekend and a very neglected misses Ive pretty much got it all sorted.
Made up and fitted new decat pipe (original one was too small diameter so just as bad as cat. Forgot to take pics but i think it's pretty tidy, plus fitted a new dohnut gasket, straight to back box now.
Got my cooler fitted up with about 2mm clearance on the fan, have heard about fitting oil rad should be fitted flat against coolant rad or it upsets the air flow. Not sure how to get round this if it's true without fitting a slim fan.
Thought I'd give the calipers a fresh coat of paint but driving it to the mot whilst bedding in the ds3000's they have decided to shit all over the fresh red calipers and turned them blackish.
Started fitting my gauges too, sensors are in place for oil temp and pressure and water temp will get pics up soon.
Engine wise: Finally gone everything set up wired up and running sweet with a map from a 205 with same spec producing 200bhp until I go to rollers next week.
But in true weekend car work not all went to plan and the ecu threw a wobbly and said no. So have to wait till end of the week to get it back now.
Will keep posted on what happens at rollers.
Posted 24th May 2011 at 12:29
r4ly j
Post #72
Well finally got the rallye back to life yesterday, after 3 weeks in the shed. Had abit if a nightmare with the ecu and a blown ignition driver so now running a coil pack and ht leads from a 406 turbo. Not my first choice but had to be down in time aloud for rolling road tomoz. I wil report back tomoz with power results. Fingers crossed, hoping for 190bhp.
Posted 1st Jun 2011 at 03:56
r4ly j
Post #73
Well a pretty successful day at the rollers, apart from my mates 106 rallye melting his spark plugs and chewing up his pistons at 9000rpm pulling 190bhp.
So started of my session on the the rollers shitting my pants about my car being strapped to the operating table and raped to 8000rpm.
Was hoping for a healthy mid 190's consider I'm running standard ex manifold and head just intimate road cams, 45mm throttle bodies and emerald.
Il let the graph speak for itself....
Posted 2nd Jun 2011 at 02:11
Post #74
nice! what cams and pistons?
Posted 2nd Jun 2011 at 02:26
r4ly j
Post #75
264 Newman cams I think. And standard pistons.
Posted 2nd Jun 2011 at 03:00
