displaying posts 76 to 100 of 103
Pages (5): first .. 3 [4] 5
Author Subject: Rallye Track Slag
eddy_gti6
Post #76
Take it the 264 newman cams fit in no problem at all without and mods to the pistons then? Good outcome Thumbs up
Posted 2nd Jun 2011 at 06:47
Post #77
Result! Now get a decent air filter in it before your engine ingests a stone or loose nut and destroys itself Wink
Posted 2nd Jun 2011 at 14:05
r4ly j
Post #78
Guna have to work on a filter.
Posted 2nd Jun 2011 at 18:20
Post #79
I was looking at your setup and it's not going to be easy, what with the PAS pump in it's original location and your front mounted throttle cable means fitting a conventional dome type filter will be difficult at best.
Posted 2nd Jun 2011 at 18:24
ben306
Post #80
Looking well. I'd love to have the dollar to go with TB's.
Hows it drive out on track? Done may track days in it now?
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 2nd Jun 2011 at 18:29
Post #81
Buy cwspellowe's R1 TB setup? El cheapo Love
Posted 2nd Jun 2011 at 18:31
r4ly j
Post #82
It does look like it's going to be a pain in the ass, may mount sum sort of mesh between bonnet and grill to prevent any stones flicking up but. As you say my options are limited some wot as previous post state trumpets socks are useless. Any ideas would be greatfull.
Posted 2nd Jun 2011 at 18:38
Post #83
I would try to find a way of closing in the top of your ally air scoop with a flat K&N style panel filter. Then knock up something to seal the back. It won't look particularly sexy, but nothing is ever going to look as good as open trumpets Wink
What you have to consider is the effects of going off into a gravel trap. It will be thrown everywhere under the engine bay as it hits the subframe and suspension arms and bulkhead, if you don't have something over the trumpets themselves you would be very lucky not to suck in some debris.
Posted 2nd Jun 2011 at 18:47
r4ly j
Post #84
Well I'm buying a house nxt year so thought mite as well get it out the way before I'm really skint.
It drives spot on, troy from northampton motorsport did a spot on job with the mapping. Drives real smooth all the way threw the revs then goes made at abot 6500rpm to 7900rpm and the sound is just awesome.
Havnt done any trackdays with them yet but mite get a go this weekend at fcs, have done quite a few trackdays now and Germany three times. Forth in July. It's put alot of other higher power cars to shame purely with it cornering ability so should be interesting now.
Posted 2nd Jun 2011 at 18:48
Post #85
Cracking result mate Cool
Troy seems to really know his stuff. Does all the work on my friends Westfield race car.
Posted 2nd Jun 2011 at 19:18
r4ly j
Post #86
Yeh he had some serious bits of kit in him workshop. Happy to explain what's going on aswel.
My main concern now is that producing that sort of power with standard internals, how long is it going to last??
Posted 2nd Jun 2011 at 19:48
Post #87
Ages as long as you don't overheat it or over rev it. What oil are you planning to run? (sorry if its mentioned further back in the thread)
Posted 2nd Jun 2011 at 19:50
r4ly j
Post #88
Well I've fitted a 16 row mocal with thermo plate to keep oils down and even on the rollers after 3hours of thrashing the water temp only just topped 99degrees but mainly stayed at 86-96.
I'm running 5-30w valvoline fully synth.
Posted 2nd Jun 2011 at 19:57
Post #89
5-30? Most serious track guys are on 15-50.
Posted 2nd Jun 2011 at 20:10
r4ly j
Post #90
Is that an issue??
Posted 2nd Jun 2011 at 20:29
Post #91
r4ly j wrote:
Is that an issue??
Id say so, its not even the same spec as standard oil I don't think.
Posted 2nd Jun 2011 at 23:43
rallyeash
Post #92
abit thin im sure, 15W50 mobil 1 motorsport is the kiddie for track work
309 3dr K20 Type R
Posted 3rd Jun 2011 at 00:05
r4ly j
Post #93
I thought anything over 10-40w was too thich for hydraulic lifter, suppose it would fine runner sonic lifters maybe.
It will be on the pug1off stand at the weekend so feel free to come say hi, stand will have lots of new and second hand standard and performance parts that mite be worth a look.
Posted 4th Jun 2011 at 00:16
matty_rallye
Post #94
15-50 is fine with hydraulics, quite a few people use it with no issues at all.
2.1 16v 306 Rallye.
Posted 4th Jun 2011 at 00:34
Post #95
No, it's fine, plus as temps go up film strength drasticly drops. Some oils loose as much as 50% by 100 degrees C. Plus most of these engines are worn a bit by now so the extra viscosity helps to keep oil pressures up at sensible levels. If a bearing is at the upper end of its tolerance it needs a lot more oil pressure to maintain adequate flow. 15-50 for the win.
Posted 4th Jun 2011 at 00:42
r4ly j
Post #96
Well aventually got everything done before French car show, up cleaning it till 10.30 the nite before where the keys also got locked in the ignition. After alot of swearing arm waving I come up with an idea and managed to break in with no damage, I'm not going to say how. Lol
Anyhow got to show nice and early and parked her up in full glory next to Chrisgti's rallye on the pug1off stand, got some pics off a friend because I didn't pic up a camera all day.
If anyone got any more pics feel free to post them up as these are all I have. Thankyou please.
Posted 9th Jun 2011 at 12:35
henrik c
Post #97
daveyboy wrote:
What intake air tempature sencor is this?
/Henrik C
Posted 17th Jun 2012 at 10:39
Post #98
henrik c wrote:
The standard one that comes with the Omex/Jenvey kit. It just looks different because I made a custom bracket for it to prevent it suffering from heat soak.
Posted 18th Jun 2012 at 09:23
soton_s16
Post #99
daveyboy wrote:
Where did you get the heat shield form?
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 18th Jun 2012 at 10:12
Post #100
I made it.
Posted 18th Jun 2012 at 12:40
