Anyone know what could be causing this?
| Author | Subject: Creaking/knocking when turning! |
jakeypoo
Regular Location: Kent Registered: 22 Sep 2010 Posts: 318 Status: Offline |
When I turn in my rallye I sometimes get a creaking sound coming from the suspension and other times when it is bumpy it seems to make a knocking sound as the suspension compresses!Anyone know what could be causing this? |
jord294
worn mounts ot bushes ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jakeypoo
Is this a cheap/easy enough job to do?Im just getting my head around the peugeot as used to looking a Z series vauxhall engines, and vauxhalls as a manufacturer |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
cheap yes easy.......can be lol________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
i had same problem in the front drivers side when i changed the top mounts, droplinks, springs and struts. Think it was slightly loose top mount screws (the 3 you can see from the engine bay) so tightened them and not had it since but only driven it once though it was a spirited run in the b-road twisties! Easy to change if you have half a clue about what you're doing... ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
jakeypoo
Will give that a go first then! Cheers for the info! |
kit
Seasoned Pro Location: Location: Location: Registered: 22 Jan 2009 Posts: 2,394 Status: Offline |
Also have this exact problem, yet to have it looked at, keep us posted about what was causing the knock.________________________________________ Racing driver, fighter pilot, astronaut, compulsive liar. |
tacha-gti-69
Regular Location: Portsmouth Registered: 04 Sep 2010 Posts: 117 Status: Offline |
i had this problem turned out to be a cv joint |
phil b
Seasoned Pro Location: Market Drayton Registered: 25 Aug 2006 Posts: 3,090 Status: Offline |
Usually a tired/seized topmount bearing, it's usually the spring turning in it's cup, hence the creaky twangy sound, had this on most my pugs living down a farm drive________________________________________ '97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'194.2bhp 127.6 dB '96 PH1 'Black Noir' 306 DTurbo (project in permenant storage) '94 300tdi LR Discovery (project gone dead and buried) '99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again) The 6 can go fast, the disco can go anywhere Built: 9 January 1997 - that's a Thursday Skip Brown cars: tarporley Cheshire Tel: 01829 720492 add me --> philbrindley85@hotmail.com TEAM: Snapper |
paulvt
Regular Location: norwich Registered: 01 Sep 2009 Posts: 402 Status: Offline |
Mine does the same but also does it from the rear end sometimes? Rear beam seized? ________________________________________ allesclar wrote: wrote: the only kind of similarities of the xsi and a 6' is if you jumble the letters round to spell six |
