Author Subject: best spark plugs??
knoxie
What you guys think are best for the 6?
ex S16 (K.I.A Sad )
GTI 6 Big grin
TEAM more scratches than an emo kid
TEAM BLACK
but wishing it was bianca white Sad
Posted 8th Oct 2010 at 14:59
mr swampy s16
**BAD SELLER**
ngk r!!!
bout a tenner a set from local factors
Posted 8th Oct 2010 at 15:15
knoxie
Are they standard pin? Or multiple, been told the treble pin is better than quad :s, only reason is that it feels astho its running on 3 checked everything an the plugs look a bit spent lol
ex S16 (K.I.A Sad )
GTI 6 Big grin
TEAM BLACK
Posted 8th Oct 2010 at 15:18
anth
spark plugs arent going to make any difference mate i dont know what ones im running now but the quad, singles etc ive never noticed a difference
Posted 8th Oct 2010 at 15:42
mr swampy s16
**BAD SELLER**
The only advantage of running multi eleactrode plugs is they give a more consistant spark over a longer milage.
The only performance upgrade you will see is a return to standerd power.
Posted 8th Oct 2010 at 15:55
james_gti6
NGK Iridium plugs,
part number BKR6EIX and the stock number is 6418.
if i dont see you in the mattress il see you in the spring
Posted 8th Oct 2010 at 16:09
jon kirby
denso iridiums, had em for the full 6 years i owned my 6, never needed changing, always started first time every time!
Posted 8th Oct 2010 at 16:10
309btcc
**DODGY SELLER**
genuine peugeot plugs IMO
Posted 8th Oct 2010 at 17:36
SteviePut
I'm with Swampy on this one. IMO a standard NGK plug is best. The iridium plugs, are, IMO, a waste of money unless you leave them in there for 6 yearsWhistle
Posted 9th Oct 2010 at 02:23
Another one for bog standard issue NGK plugs, they're twin electrode and easily under a tenner, never needed to change a set since fitting them.
Posted 9th Oct 2010 at 02:45
bobdylan_55
single pin ones are fine. The spark only goes from the closest pin anyway, so having more is pretty pointless until they wear.
The iridium ones are pointless unless you are boosted as they handle higher temps.
309 GTi6-T
Posted 9th Oct 2010 at 02:47
b11 bob Banned!
When would there ever be a need to go to a colder spark plug ? ie colder than standard are they any performance advantages going colder than standard heat range
205 GTI6 235 bhp at 7400 rpm
Posted 23rd Dec 2010 at 00:07
Only if you're generating significantly more heat/energy in the combustion chamber - i.e. Highly strung N/A engines and boosted applications, to prevent the spark plug becoming a hot spot.
Posted 23rd Dec 2010 at 00:23
Only time when you need to go to a ''colder'' plug is when the cars supercharged/turbocharged.
Posted 23rd Dec 2010 at 00:24
