displaying posts 1 to 25 of 33
Author Subject: Hows this spec?
craigm
Hello
Im going to be starting a project build very shortly, im due to collect the engine next saturday ready to start it.
Ive been running through the uprated parts in my head and just wanted to check them off with you guys as im guessing your slightly more gti 6 gurus than me Razz
Basically i'll be finishing off with a full Jenvey Setup but just to make sure ive got things right.
- Wossner High comp Pistons
- PT82 Cams + Lifters + Double Springs
- Vernier Pulleys
- Gas Flowed Head
- 4-2-1 Exhaust mani + Downpipe
- Decat Section + Straight through exhaust
Ive probably forgotten something blatent, ill be replacing any damaged or unservicable ancils that come with the engine naturally
But would appreciate any advice as to the spec ive listed, anything ive missed or any differences you would like to tell me about Smile
Thanks muchly
6 Project Coming Soon Smile
Posted 3rd Oct 2010 at 00:03
I wouldnt bother with -
- Gas Flowed Head
you will need a remap or a mappable ecu.
Posted 3rd Oct 2010 at 00:14
rallyeash
add a 1.9 T diesel crank, theres a set of pistons and rods to match a diesel crank forsale on here atm.=2139cc
also standalone ecu and loom for the jenveys
but also it masively depends on what you are looking to use the car for, race series, daily drive, track slag etc
309 3dr K20 Type R
Posted 3rd Oct 2010 at 00:17
midlife
Hope you've got the brakes & suspension suitably uprated before you start, oh and a roll cage, buckets & harnesses...
Your money is better spent there first
Cool
Team 330™Cool
Team "no front end or engine"
Posted 3rd Oct 2010 at 00:23
craigm
Yea Brakes and suspension will come in time before it goes on the road.
Reason i put the exhaust in there, well i cant run a standard exhaust and mani with it, would be epically restrictive wouldnt it?
Had a nice little shock aswell, Spoox do the TB kit for £2021, Buying all the parts individually including management and loom from jenvey and spoox is £1780. Dont know if this has already been noted though Smile
As far as the 1.9 D Turbo crank rods and pistons, is the bore the same as the 6 block?
Posted 3rd Oct 2010 at 00:49
just the crank, not the rods + pistons
Posted 3rd Oct 2010 at 00:54
craigm
Oh ok, i get what your saying now cheers.
Without sounding like a complete dunce, what rods and pistons would match the crank? Im guessing the standard 6 ones wouldnt>
Posted 3rd Oct 2010 at 00:55
jonnywilcock
how do you work out the extra cc from adding different cranks? iv heard you can use the 2.1 crank? better or not i dont know?
Posted 3rd Oct 2010 at 01:06
rallyeash
im running a 1.9 td crank with custom rods and pistons.
basiccly the rods need to be 1mm shorter otherwise they will pretude out the top of the block.
or you can run s16 rods which i believe are a touch shorter.
try this
http://306gti6.com/forum/showthread.php?id=127245&page=1
309 3dr K20 Type R
Posted 3rd Oct 2010 at 01:08
rallyeash
standard manifolds are not restrictive until 220bhp+
also before you buy any managment talk to the person who will be mapping the car and ask which ecu they prefer
309 3dr K20 Type R
Posted 3rd Oct 2010 at 01:16
- Gas Flowed Head
WHy is that then ???
Ex longmans head ported and the chambers opened up with a matched maniflow manifold and exhaust plus a matched inlet manifold is the way forward - every little helps as they say Wink
Posted 3rd Oct 2010 at 01:22
because the cams are pretty mild, coupled with pretty damn big ports as standard, no point wasting money on the head when gains are minima, also I'd be dubious about the phrasing "gas flowed head...."
as mentioned above, the standard manifold is fine for 220-240 odd, which the pt82's wont be anywhere near unless he's going to go big bore, a decent exhaust system wont go amiss, something like Miles's proven off the shelf system, or maybe a slightly larger version if required.
Posted 3rd Oct 2010 at 01:28
jonnywilcock
is the diesel crank/s16 pistons + rods a worth doing while the engine is apart then?
Posted 3rd Oct 2010 at 01:30
No point getting the pistons either then as you can squeeze 200bhp from std pistons and pt82s on management no probs
Smile
Posted 3rd Oct 2010 at 01:32
Wouldn't bother with TD crank either but thats just my thoughts
But hey what would I know I mean its not like I ever had proper engine or anything Big grin
Posted 3rd Oct 2010 at 01:34
SteviePut
Smile
You'll need the pistons machined thoSmile
How much can you machine a standard piston before compromising it's strength?
Posted 3rd Oct 2010 at 01:36
as above, PT81's really need the pistons machining, PT82's are definitely not safe in a stock bottom end, may even need some material removing in the head where the cams run, I don't know on these ones.
you'd need to ask Sandy or Martin how much can be removed from the pistons, what you have to remember also is that you are lowering the static compression ratio by enlarging the cutouts, something you don't want to do with more overlap on the camshafts.
Posted 3rd Oct 2010 at 01:41
SteviePut wrote:
Smile
Thats not strictly the case depends how much has been skimmed off the head ? -
Just get some lairy cams, rods, pistons, have the engine built and checked with proper head work to take the cams. open the chambers match the manifolds get standalone management put on 48tb's but have them fluted to take 50 trumpets = job done - maybe look at 8 injectors as well Whistle
Finish off with a 2.5 bore exhaust system Cool
Posted 3rd Oct 2010 at 01:43
rallyeash
if you going to do the above why wouldnt you want a diesel crank which is no extra work and will give 100cc extra..
309 3dr K20 Type R
Posted 3rd Oct 2010 at 02:05
hmmmm guess its not a tried and tested thing ?
each to there own I guess Cool
Posted 3rd Oct 2010 at 02:09
rallyeash
theres a fair few 2.1's kicking around now which sandy has built. theres 2 about 40 foot away from me... Smile
309 3dr K20 Type R
Posted 3rd Oct 2010 at 02:11
craigm
Cheers for all the advice and pointers, im starting to get a better idea as to what to put in the motor.
Posted 3rd Oct 2010 at 02:18
Furry muff bud hows my old TBs by the way ?
Posted 3rd Oct 2010 at 02:39
rallyeash
yeah good job, running a longer inlet with 8 injectors now though,vectra v6 inners and 106 gti ones in the tb's. they are also run upside down now too Smile
being mapped in 3 weeks...
309 3dr K20 Type R
Posted 3rd Oct 2010 at 02:47
jeffers Forum Admin
I Love this car!
Team Running Engine again!
Team Negative Camber!
Posted 3rd Oct 2010 at 05:02
