displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: Hows this spec?
309btcc
**DODGY SELLER**
why run upside down?? and why 8 injectors??
Posted 4th Oct 2010 at 19:15
mxcrazy
The pistons i have for sale are 88mm dia Wossner, with a 1mm lower pin to crown height than stock, this means you can use a td or mi16 (1.9) 88mm crank (stock is 86mm) and standard rods (or after market rods with standard dimensions) to get 2139cc, no messing about matching pistons with different rods, having blocks decked, modifying pistons etc, just bolt together! (except having the bores taken to 88mm ofcourse)
They are 11.5:1 compression using the 88mm crank, and have huge cut outs to safely run 'lairy' cams.
I also have an 88mm head gasket to suit, im after £500 (+offers) for them. Im getting rid because i am back into racing motocross, and have 2 bikes to look after now.
Speak to Sandy or Colin Satchell about a GSXR throttle body set up on their manifold, sandy has had some awesome results with them.
Posted 4th Oct 2010 at 20:44
rallyeash
instead of having 4 massive injectors which makes it harder to drive on light throttle and loads of fuel being chucked in you run 4+4 injectors, the ones closest are the main injectors i believe which run all the time and the second set, in the tb's overlap around 4-5k with both sets working in the power band
upside down gives a much better air/fuel mix
309 3dr K20 Type R
Posted 4th Oct 2010 at 21:22
matty_rallye
I would say it would be worth changing the crank and rods if you are going to the extent of piston change. You could even go for the 2.1 td crank, which along with the 87mm pistons would make just shy of a 2.2. This setup with suitable cams + itb's is usually good for 200 lb ft!
2.1 16v 306 Rallye.
Posted 5th Oct 2010 at 00:14
309btcc
**DODGY SELLER**
hmm well why didnt richard longman run bodies upside down and he got 280bhp with 4 injectors??
Posted 5th Oct 2010 at 00:39
more than likely because they'd be mounted in the trumpets not in the throttle body?
Posted 5th Oct 2010 at 00:49
miles
4 Injectors on the bell mouths or 8 as std give the best all round, Nice low down and a nice peak figure, on the 8v's you got about a 10% gain in peak power from this little mod.
Sodemo are the only real experts on this engine in my mind, But you pay for it as you only have to look at the real BTCC cars (405 and 406) over here the engine's I remember always went pop but in Europe they won, I know budget had allot to do with it in the UK which never helped.
But the overall engine spec really depends on budget and what you want from, High end screamer or a torque monster
www.pugracing.com
Posted 5th Oct 2010 at 00:52
309btcc
**DODGY SELLER**
well miles you put that one too bed mate lol
Posted 5th Oct 2010 at 00:54
Pages (2): 1 [2]
