displaying posts 101 to 125 of 134
Pages (6): first .. 4 [5] 6
Author Subject: Mount mod!!
Welly Forum Admin
Post #101
i will..If you are going to the RR day jump in and tell me what you think
Vrs power!!
Posted 24th Aug 2004 at 22:04
dommorton Forum Admin
Post #102
ok will do.
My tyres are fecked tho Whistle
Posted 24th Aug 2004 at 22:07
Welly Forum Admin
Post #103
whats your tyres got to do with my engine...
Is this a Give us a lift plea
Vrs power!!
Posted 24th Aug 2004 at 22:09
Post #104
No mate my car is running on RR Laugh
Posted 24th Aug 2004 at 22:11
Welly Forum Admin
Post #105
Cool...well i might be picking des up, if not i will meet you on the way
Vrs power!!
Posted 24th Aug 2004 at 22:20
Adam PV
AKA jjfukkard
Post #106
quote:
it certainly wouldn't do any harm...i had to lever mine open with a big screwdriver to get that plate in....it's only 2 bolts to get at it.
Decided to take the preferable route and buy these:
Adam PV has attached the following image:
JJ
Blessed are the cheesemakers...and all purveyors of dairy products....
Posted 25th Aug 2004 at 18:05
6miester
Post #107
Hard to see that picture-could we have a bigger one please....Mellow
(edit)Thumbs up
The Joy Of 6.
But boost is stillbest!
Posted 25th Aug 2004 at 19:14
Post #108
You prefer to spend £130 + fitting
Alrighty then Crazy
Posted 25th Aug 2004 at 18:27
Adam PV
AKA jjfukkard
Post #109
Here is my situation;
I have a 99 ph3 6, the exhaust has ALWAYS blown. I had a Magnex fitted assuming the original was just f*cked....which it was.
After a month the exhaust began to blow so I had it refitted....then a month later.....etc.
The exhaust has now been fitted 3 times and is yet again blowing.
Looking at my engine mount there is no gap between the mount buffer and chassis so chocking it is going to be both impossible and pointless.
So my options are;
1) keep having the exhaust refitted time and time again.
2) Have a flex section welded onto the join meaning my decat would have to go (because thats where it keeps seperating).
3) Ignore it
4) Try group N engine mounts
Which would you choose?
JJ
Posted 25th Aug 2004 at 18:50
Post #110
sure it's not the exhaust fitting?
My 205 exhaust kept separating where stainless met mild steel
I ended up tightening the clamp sh*t loads till it nearly snapped then welded the nuts in place
Posted 25th Aug 2004 at 18:54
Adam PV
AKA jjfukkard
Post #111
I'm positive, the guy who fitted it said he couldn't tighten it up any more than it already was.
Options are limited and I'm at the point where I f*cking hate my car.
JJ
Posted 25th Aug 2004 at 18:58
Post #112
is the engine actually moving much?
As mine used to move loads and the exhaust caused no problems?
try changing the exhaust hangers
if they are fooked the system flops about loads
Posted 25th Aug 2004 at 19:01
Adam PV
AKA jjfukkard
Post #113
Been replaced aready when the exhaust was fitted the third time.....
JJ
Posted 25th Aug 2004 at 19:08
jimmy_boy
Post #114
Just doing the mount welding/repair now Smile
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 25th Aug 2004 at 19:42
Adam PV
AKA jjfukkard
Post #115
any suggestions jimmy?
JJ
Posted 25th Aug 2004 at 19:51
justin
Post #116
I have the same problem and have fitted three fixing kits and it still bloody blows - but my CAT is fecked loads is hissing really loud and makes a really deep thwaaaaaarp sound when flooring it so my theory is this the CAT is so knackered and blocked that the gases are forcing open the spring joint as an easier way out. I will prove this once i fit a new CAT which shouldn't be to long now - i'll let you know the outcome.
time for a new sig!
Posted 25th Aug 2004 at 20:17
jimmy_boy
Post #117
Engine mount plate welded in and solid as a rock Big grin Big grin Big grin
Now with the plate coming right up the sides it stops the mount moving back and forth almost completely
So glad thats done Yes ... I fear many others will go the same way around 70 - 80 K Miles. Sad
GTI-6 & Rallye
Posted 26th Aug 2004 at 11:02
Post #118
Nah this one is the weaky
Posted 26th Aug 2004 at 12:02
pottsy
Post #119
Its probably the bottom mount thats the problem. Thats what was causing me loads of exhaust trouble. It had moved around and was therefore moving too much, the rubber is shaped a bit like (-) and mine was like this ( l ) so it moved too much and caused the exhaust to snap in the middle section all the time.
Make sense?
Impreza Turbo 2000 (every day car)
Peugeot 309 MI16 track car
Posted 26th Aug 2004 at 12:04
nwphoto
Club Snapper
Post #120
quote:
.....the rubber is shaped a bit like (-) and mine was like this ( l ) so it moved too much and caused the exhaust to snap in the middle section all the time.
Make sense?
No
Posted 26th Aug 2004 at 12:13
Post #121
I get you potts
you sure pug didnt press it in wrong from factory?
cant see it moving No
Posted 26th Aug 2004 at 12:16
pottsy
Post #122
Maybe it was wrong from the factory but bear in mind it had done 100k when I got it so I can't believe it hadn't been a problem before, unless it went a bit softer over the time and dodn't matter previously.
I know that was the problem though and putting in a new one the right way round cured it. A sure fire cure would be an uprated one that has rubber all the way round.
Posted 26th Aug 2004 at 12:22
justin
Post #123
What do i have to do ie haynes way when replacing the bottom mount ? Someone help as this problem is one fecker i need to get rid of its really getting on my nerves every time i get in the car! A blowing exhaust and a fecked CAT is losing me power and sounds horrible. I would be extremley grateful regards Justin.
time for a new sig!
Posted 26th Aug 2004 at 13:00
Post #124
The mount in question is speared by the driveshaft Dry
your must remove the drivers side drive shaft
then support engine on jack
Then remove housing with mount in
Press old mount out and press new in
Then rebuild
Posted 26th Aug 2004 at 13:05
rallyecomms
Post #125
i sincerely hope this ain't whats causing my exhaust blowing...
Road Rally car - Manstone Ph3 GTI-6. Quaife ATB, hydraulic handbrake, OMP Cage and loads of other rally crap!
Rally Car - Ford Olympic Blue!. Quaife ATB, hydraulic handbrake, Safety devices cage, GpN Pug Sport kit!
Posted 26th Aug 2004 at 13:33
This thread has been locked
