displaying posts 126 to 150 of 227
Pages (10): first .. 5 [6] 7 .. last
Author Subject: High Boost Supercharged Rallye
Post #126
Looks amazing Russ, very jealous Love
Posted 31st Aug 2012 at 15:27
russbez
Post #127
thanks mate
just ordered a bottle of supercharger fluid
its near £99 a bottle Sad
My Rallye project thread
Posted 31st Aug 2012 at 15:58
Post #128
Dont spill it! :p
(Can you imagine :O)
Posted 31st Aug 2012 at 16:02
eddy_gti6
Post #129
My wilwoods took a couple off times to bleed right but now with the red stuff pads in they are unreal but then again there only stopping something like 850kg whats nowt really LOL
Think this will be able to keep up with the saxo at knockhill next time we meet then? Cool
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 31st Aug 2012 at 16:03
russbez
Post #130
Wilwoods are now bled and well bedded in, done 50 mile the night taking it easy most of the time
yeh charger fluids a rip off Sad
Posted 1st Sep 2012 at 03:19
russbez
Post #131
More pictures now that everything running good
Car seems to be running perfect
Gear changes and clutch feel great
Engine doesnt seem to be using any fluids its not meant to.
accelerates great, hardly stalls at all
But.... i am getting a high pitched squeal, only happens when revs are dropping back down and around 2/3k revs Dunno
doesn't seem to be effecting the running of the car.
Does not sound like a bearing sort of squeal
I had it before i changed the engine (iirc!!)
but now its happening a lot more and ever so slightly louder
it comes from the gearbox area, possibly clutch/flywheel area Thumbs down
does it both when in gear and not in gear
quiet hard to pin point, will get a second opinion
Posted 3rd Sep 2012 at 13:22
russbez
Post #132
Video of the noise LOL
was nothing major
just seemed like the silicon hose was vibrating onto the aluminium pipework when the right amount of pressure/boost was on the hose, i think due to me having the clamps on the edge of the tubing.
if needed i will replace the silicone pipe, seems to have shut up for now.
Brakes are pretty decent now, hearing a slight squeal when very very light braking.
Brake pedal is almost as high and firm as my Brembos when they were bled good
Posted 5th Sep 2012 at 10:36
fatlapit
Post #133
boost leak sounded like
Posted 5th Sep 2012 at 19:06
russbez
Post #134
sounded like .... LOL
anyway looked at credit card bill there
supercharger fluids up to £117 Erm?
delivery and VAT i think
someone's getting there moneys worth
Posted 6th Sep 2012 at 12:25
Post #135
£117 Shock thank god I've just changed mine not looking forward to paying out for hat in a couple of years... So does this use exactly the same setup as low boost but obv bigger pipe work injectors and no boost restrictor? Otherwise the same?
Posted 13th Sep 2012 at 12:32
russbez
Post #136
ohh and thats plus a filter LOL i already had a spare
yes you need 2.5" pipework
i already had larger 2.5" pipework and intercooler back from when Lynx done the original low boost install
fuel swirl pots moderately hard work, i read up on it and had few tips from others got it done reasonably quick.
pretty much everything i posted anyway Smile
i do have more pictures of swirl pot, fuel line routing, wires and relay wiring.
Posted 13th Sep 2012 at 12:44
Post #137
You missed off the forged lower comp engine!!!!!LOL
Posted 13th Sep 2012 at 23:02
russbez
Post #138
hehe..... well i was hoping the pictures of second hand forged engine and big pile of parts would be a guide for what iv fitted to make it high boost Big grin
Posted 14th Sep 2012 at 10:22
Post #139
Lol I thought the low comp forged bottom end was obvious enough not to state it lol. I'll be on the look out for high boost ic and pipe work next year.
Posted 19th Sep 2012 at 20:16
russbez
Post #140
Insurance renewed and retaxed last month...
Failed its Mot last week, tiny bit of the Eibach spring has snapped off at top on passenger side
couldnt hear anything was up or see any height difference, springs are 4/5 years old Sad
£120 for new set Yes
Planning getting Speedlines powdercoated (and my missing bracket replaced and powder coated too)
Supercharger fluid needs replaced this Spring i guess
Maybe even an oil change
Silly Supercharger pulley bearings are squeaking already, goes away when warm
do not fancy one of them failing again!!
Posted 27th Mar 2013 at 09:35
russbez
Post #141
Well its that time of year again, made a start to car for Mot, required spring changed and the Charger oil while car was in the air
Everything comes apart soo much easier when things have not been over tightened
Salt still everywhere from the one run up North i done in February Sad
Drained as much charger oil out as i could, more went on the floor than the old container i put down to catch it
Everything nipped back up, oil and filter changed
Posted 9th Apr 2013 at 13:32
eddy_gti6
Post #142
Much happening with this then russ?
Posted 4th Jun 2013 at 13:42
russbez
Post #143
Back in April i fitted B4s they were too standard, so suspension had to come apart again now i am running B6's and loving them, i took a few pictures they arent very good though
Bonnet is now looking really scabby, pretty annoyed just looking at it LOL
Really tempted to take old bonnet off and grind the worst of the rust off the underside of bonnet
remove as much rust as i can and make it last a few more months.
Still attempting to get though Building Warrant for house so Rallyes been tucked up in Container and out for blasts at the weekend.
Posted 13th Jun 2013 at 09:43
russbez
Post #144
new bits
B6 vs B4
rears done
next day :-
pretty much done
Small lip on the brake pads, there is a thread somewhere about it
Arches are full of dirt Thumbs down
think of all that added weight Yes
soo happy with new setup, car is mainly weekend car so dont mind it being the little bit harsher feels soo much more planted when boosting
Also bleed the brakes again for good measure!
Posted 13th Jun 2013 at 09:59
Post #145
Nice to see an updateThumbs up
Posted 13th Jun 2013 at 11:28
oecken
Post #146
Is it the same bonnet we looked for a replacement for on the RR day all those years ago, Laugh my ass off
Posted 13th Jun 2013 at 12:12
russbez
Post #147
yeah it is! wish i took that resprayed one from Eccose when i was there it would of looked a lot better still
anyway order another bonnet off of an ebay chap
Posted 14th Jun 2013 at 15:59
oecken
Post #148
And to think we wasted good beer drinking time that day No LOL
Posted 17th Jun 2013 at 23:50
russbez
Post #149
lol getting flashbacks of me in the rain outside Eccose washing an ole scabby bonnet with you and Dave watching LOL
there was plenty of time for that afterwards Big grin
received newer bonnet yesterday, few small issues with it nothing that isn't fixable!!
Posted 18th Jun 2013 at 10:00
russbez
Post #150
newer bonnet awaiting fitting, gave it a good wash then t cut to remove bright blue over spray, sticky tape and grime the last owner was nice enough to leave on it Yes
cleaning up the underside too
Posted 25th Jun 2013 at 15:14
