displaying posts 151 to 175 of 227
Pages (10): first .. 6 [7] 8 .. last
Author Subject: High Boost Supercharged Rallye
russbez
Post #151
Started to refresh the sills, i have newer Side Skirts to fit
I plan to use my works Rivnut gun to make Skirts removable as a few members on here have done
Some of the holes for Skirts are uneven, need to consider straighten up sills which look to be damaged by jack
All gets hiden by Side skirts but it looks rough
can only think it was damage by last owners... 99% time i am careful with jack
I have access to a competent welder so hopefully I can get a few plates welded here and there
Pictures of arches are off...
pictures of damage to sills... there is more i plan to repair/derust all this
Cleaned debris off the sills...
Cyclones will be refitted shortly and Speedlines will be getting powder... unsure of colour yet but they will not be white!
black stuff on sill is Mastic/Silicone will be getting removed
My Rallye project thread
Posted 28th Jun 2013 at 11:16
russbez
Post #152
got a fair few bits done last few weeks
New bonnet fitted i cleaned up best i could, rubbed down underside of bonnet and painted with Bianca rattle tins pretty happy with the result
Wheels are away getting Powder coated Anthracite, got standard ish looking Speedline Centre cap gel stickers
Waiting on Front and Rear bumper and side skirts getting painted
had a welder patch in L shape sections replacing any rusty/jack damaged sections.
removed a few patches of rust before and after, used about 3 different Bilt Hamber Rust products that other members on here have been using
Posted 1st Aug 2013 at 11:43
russbez
Post #153
Sills fixed... welded, rubbed down, cleaned up, sealed, cleanup some more, Rust inhibitor wax applied inside sills and few other places then painted.
Test fitted Side Skirts seems to fit pretty good.
Can still see the welds, they will pretty much be hidden by Side Skirts
Rubber grommet there for access with Rust inhibitor wax - put this stuff on most panels/box sections I wont see or have access to, most of the interior to avoid any accidents when welding so had access to sills towards back of car.
Delighted with the Rivnut inserts
did have better pictures but seemed to have misplaced them
edit : pictures crap will attempt to find another one
Posted 6th Aug 2013 at 16:59
Post #154
Great workThumbs up
What size riv nuts did you use?
Will use them on mine next time skirts come offWink
Posted 6th Aug 2013 at 16:41
russbez
Post #155
passenger side is M5 - couldnt use M4s at all holes were pretty big already
driver side id rather not talk about LOL
needless to say i needed some practice!!
Posted 6th Aug 2013 at 16:50
russbez
Post #156
Few patches painted gloss white to cover up old Etch primer I used when installing Swirl pot
Bought some 6mm adhesive sound proofing to try and save my hearing a little
Posted 6th Aug 2013 at 16:51
russbez
Post #157
Car is booked in with Wayne Scholfield at end of month for a Remap
doubt i will get my Bumpers and Skirts done in time, will have to get them back and put them on the way they are.
Wheels going back to powder coaters not quiet 100% sure about them yet.... finish isnt quiet right
pressure washed some pretty mint door cards, waiting for them to dry now Yes
Posted 6th Aug 2013 at 16:58
Post #158
M5's?
Didn't see those listed,thought they went up in even numbers like majority of boltsDunno
Takedown
Post #159
Great car mate..
I think gloss black wheels will look the tits with the white
Posted 6th Aug 2013 at 17:50
russbez
Post #160
cheers guys, it was a toss up between Anthracite and Gloss Black tbh
yeh i should of got welder to plate upper side of sills but it would be really noticeable
so i tried to make do..... the holes were pretty damaged, attempted to get M5 inserts to fit.... they did really badly though
but then my welder is on holiday so i decided just to drill out larger holes and use M6 inserts on drivers side
it all gets hidden but the semi OCD part of me tells me both sides should be the same LOL
i got more done tonight but bed is calling me.
Posted 6th Aug 2013 at 22:10
mik
Post #161
Good work.
My car had a jacking dent on the driver's sill box section in exactly the same place as yours. Either car fell off jack or jacked car on the sill cover. All fixed now though.
I know what you mean about OCD fixing things to look good even they will never be seen, being under covers etc, I'm the same.
Cherry Rallye SOLD
Posted 6th Aug 2013 at 22:27
Takedown
Post #162
REdo them Gloss black please!
Posted 7th Aug 2013 at 11:31
russbez
Post #163
doubt that will happen there already Anthracite LOL
Posted 7th Aug 2013 at 11:35
Takedown
Post #164
Do em again black Wink
Posted 7th Aug 2013 at 21:51
russbez
Post #165
more bits i got coated
doubt ill fit them all anytime soon, lacking the motivation just want the thing on the road
Posted 7th Aug 2013 at 21:56
russbez
Post #166
Some movement regards Side skirts and Bumpers
had to rub them down some more though.... painter wants them off me before end of the week
Long last heat shield bracket now fitted
some of the interior back in
I broke passenger side seatbelt, inspecting the springy clip thinking it was broken.... it wasnt but it is now
managed to put it back together but it isnt as tight as it was before
awaiting replacement
tested out my new ramps so i can get my jack right under the car, how the car is sitting just now...
wheels should be back in week or so, getting intercooler bottom brackets powder coated and battery bracket type holder done too this will clean a few minor niggles
Posted 14th Aug 2013 at 12:20
russbez
Post #167
Back quarter panels view…. seam sealer and rust inhibitor wax on top
Replacement seatbelt and interior back in
Exterior came back few days ago, left it as long as I could to cure before I got the itch to fit them
Fitted, I think I will cry if I get stone chips Yes
Side Skirts can go on once I sort the daft stickie clips out
Colour difference is not too bad, rather happy
Posted 19th Aug 2013 at 12:05
eddy_gti6
Post #168
black wheels and black masks Thumbs up
Glad to see you making some progress on this russ
Posted 19th Aug 2013 at 11:44
russbez
Post #169
cheers bud, those wheels are anthracite but they are peeling already hardly even used them
awaiting my Speedlines
not too sure if id bother with black masks
Posted 19th Aug 2013 at 11:48
mik
Post #170
Black masks look the duck's nuts. I tried to avoid getting them on the grounds I'd spend loads but couldn't help myself. Pleased I did.
Your car is looking nice and shiny, I bet it's very satisfying to see it come together.
Cherry Rallye SOLD
Posted 19th Aug 2013 at 18:37
Post #171
They look ace but has anybody noticed there headlights arent as bright?
I removed mine because at night i found it hard to see without the main beam on
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 19th Aug 2013 at 21:31
mattgti6phase2
Post #172
Made no difference for me. If it made a difference then I can't see why manufactures have black mask headlights as standard on a lot of modern cars.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 19th Aug 2013 at 22:50
honestly3k
Post #173
You do have HID's though Shock
Posted 19th Aug 2013 at 23:04
mattgti6phase2
Post #174
Roll eyes
Even still no difference. Manufactures even do this on halogen bulb set ups to.
5 x a 306 owner!
Posted 20th Aug 2013 at 00:38
russbez
Post #175
Yes definitely! The bumpers were the worst part of the car they were a mess. Good feeling having it back on the road LOL
I will see how my Speedlines look on the car, I do like the whole dark wheel and dark headlight masks
But decent ones dont look cheap, and I didnt want to buy someone elses second hand project and have them peel from inside or let moister in.
Posted 20th Aug 2013 at 09:26
