displaying posts 1 to 25 of 30
Author Subject: Low RPM High torque
mc leong
my understanding is ,gti6 engine need to rev high RPM only can get the power .
but i need a low RPM with high torque engine.
xu10j4r with gti6 piston ?
Thanks
Posted 6th Jul 2010 at 10:03
cress87
D-turbo Wink
Posted 6th Jul 2010 at 13:07
oldbrownshoe
or GTI-6 with xu10j4r inlet manifold
French military victories?
Did you mean French military defeats?
Posted 6th Jul 2010 at 13:08
NO LOL
J4RS makes more torque than the J4R, if you want more you need more CC or Diesel fuel and a Turbo.
Posted 6th Jul 2010 at 13:27
mc leong
NO LOL
How if gti6 bottom end, and J4R head , pick up will be better the original gti6 ?
i need pick up!!!
Posted 6th Jul 2010 at 14:34
mike306
Could go for 87mm pistons and a 88/92mm diesel crank which will give you 2.1/ 2.2 litres... or there's always the 3.0 v6 option Wink
High boost '6 for weekends
406 2.1 Executive for weekdays
Posted 6th Jul 2010 at 14:56
See that big stick with a knob in in the middle of the cabin?
Use it.
Posted 6th Jul 2010 at 17:26
kyleey2k
Use it.
spot on Wink
Posted 6th Jul 2010 at 22:48
joevts
J4RS makes at least 115lb/ft from 1750rpm right through to limiter, if thats not enough low down torque you need to either buy a tractor or take a serious look at your driving style.
Posted 7th Jul 2010 at 00:04
or fit a V6, well over 170 LBFT from 2k to peak of 200 ish dropping to 160 at the limiter.
Posted 7th Jul 2010 at 00:43
oldbrownshoe
considering the weight of the engine it's really another name for the tractor option.
Posted 7th Jul 2010 at 03:03
Rubbish. Its all alloy so not as much as you might think my friend. Trust me when I say the handling is 98% of what it was and its a lot quicker than a GTi6 Wink
Next time you are in the UK give me a shout for a test drive Smile
Posted 7th Jul 2010 at 03:07
oldbrownshoe
I will. Big grin
i can tell you that those 2% difference means a lot ,
i had ZX 1.9 Volcane (all alloy engine)
and it was beautifully balanced.
when i switched
to ZX16V , i lost the faith in the chassis,
the more violent weight transfer when you move beyond the grip level frightens me, it's like you need to walk barefoot where the floor now covered with rusty nails.
the weaker & lighter ZX handled better .
i deduced the same for the V6 Vs RFS .
Posted 7th Jul 2010 at 14:21
if you lost faith in the ZX 16v chassis you best not drive a 306 gti6 as they have even more of the weight % up front for some reason.
its a bit silly comparing the 16v directly with the volcane, as they had different dampers and springs, they were much stiffer front and rear, especially rear roll bar.
Posted 7th Jul 2010 at 14:25
oldbrownshoe
My volcane used ZX16V dampers ,Eibach stiffer & lowered springs & Yoko A520 195/45/15 .
I drove the GTI6 , the steering is less sharp
then the ZX16V.
the lost of faith is something that i can deal with, i needed the time to train my self
to anticipate it's reaction.
Posted 7th Jul 2010 at 14:44
did you use 16v springs and rear axle?
yoko road tyres are a bit crap really LOL
Posted 7th Jul 2010 at 14:53
oldbrownshoe
no , just the Eibach Pro-kit in the front,
and lowered the ride in the back, still it handled well.
i planned more , but then i decided that what i really wanted all the time was the ZX16V.
see ?
Posted 7th Jul 2010 at 15:12
that would be where yoyu went wrong, stiffen the front and not the rear and you'll get more understeer and snap oversteer.
my zx 16v does not do that.
Posted 7th Jul 2010 at 15:10
oldbrownshoe
My ZX16V is standard, still i'v lost the tail,
it went sideway so fast in 130 km/h turn that i needed to paint my hair.
Posted 7th Jul 2010 at 15:22
My car is far from standard though now. I agree 2% makes a difference, but I have yet to move weight (battery) backwards and fit stiffer rear springs. The damping setup is rather good Smile
Posted 7th Jul 2010 at 16:32
oldbrownshoe
do you have the weight of the engine ?
the Mi16 132KG
the GTI-6 ? (i reckon about 20 KG more)
the V6 3L ?
(by the way the BMW 330I 6 inline weights 120KG )
Posted 7th Jul 2010 at 20:12
I seem to remember the XU10J4RS being 150kg with no inlet, exhaust, starter, pas, alternator but with the rallye aux bracket and flywheel.
The V6 I'm not 100% sure about but was told it was 175 - 180 without ancillaries (starter, pas, alternator). The gearbox weighs 10kg more, the flywheel on mine is 7.1kg total, the clutch will be a tad heavier and the shafts are about 1.5 extra each (but are very modified). It also uses more oil (+1L) and coolant (+ about 4L).
If you consider that I don't have aircon, have significantly lighter wheels, tyres, suspension and brakes then there really isn't much in it over a phase 3 gti6. Any weight gain and distribution issues can be overcome fairly easily. It is a fair bit quicker than a GTi6 or my old engine. Its unstressed and has a fair bit of potential, not that I have the money to realise that!
I'd love one of those BMW engines - will probably be in the next car I own tbh. Shame its too long to fit transversely!
Posted 7th Jul 2010 at 20:54
Fits just fine behind the front seats.
Posted 7th Jul 2010 at 21:02
Come on though - would you bother with that engine if you'd gone to the hassle of getting it behind the front seats? V10 everyday... oh yeah you've got one Ninja Whistle LOL
Posted 7th Jul 2010 at 21:05
oldbrownshoe
how can you overcome about more 50KG which half or more is hanging outside the front axle ?
Posted 7th Jul 2010 at 21:08
