Author Subject: Clio 197 Brembos with 406 v6 discs
felixthecat
Where to get adapters for clio 197 brembo calipers to fit with 406 v6 305mm discs?
I know ash is making a kit but these are for the 310mm setup.
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 6th Jul 2010 at 01:26
mabgti
NV motors
ask RICH_W Yes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Jul 2010 at 02:45
berger
mabgti wrote:
ask RICH_W Yes
I asked him but he doesnt have a drawing for them to make them from and sold his set.
If I get a set of 406 discs then I can get some brackets made up no problems.
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 6th Jul 2010 at 02:54
lotek
does anyone have any drawings or actual brackets to get 406 discs on a 6 with 406 brembos?
Posted 6th Jul 2010 at 02:59
velar
I would avoid the 406 305mm discs.
I ran them on a few 406 track coupes(inc an ex btcc shell) and they overheat within a few laps( common on the 406 when tracked).
I replaced them with Focus RS discs and the overheating issue went away.
I think that due to the low offset, the root of the cooling vains are restricted(only about 5mm gap) and this prevents decent airflow through the discs.
The offset is also wrong for the 306 hub.
Posted 6th Jul 2010 at 03:16
lotek
is the focus rs disc the correct offset?
Posted 6th Jul 2010 at 03:15
velar
No but it shows that the 406 disc was the cause of the overheating, not the car/caliper.
Note the offset correction needed for the Focus disc in the photo
Posted 6th Jul 2010 at 03:30
lotek
where can i get those correction spacers from?
and do you have any brackets to get the 406 caliper to fit with them?
thanks Thumbs up
Posted 6th Jul 2010 at 03:22
velar
Spacers are modified 25mm huncentrics off ebay.
Adapters for the 406 brembo are hard to do, it is easier to make adaptors for for a radial caliper like the clio 197/megane 225.
I am putting Ap 6 pots onto my 6 ( Have a set knocking about)with focus Rs discs, the discs are 224mm and less than £100 a set( but a bit heavy). These will fit under 16s
P.S the Focus RS discs with Clio 197 calipers and standard Renault pads are a very good budget solution, but need 17s.
ash
Six Addict
I've got kits for the 306 using Renaultsport Brembo's with 310mm or 330mm rotors, or a kits for the 306 using 406V6 Brembos with 330mm rotors. These are road and race proven and cost a lot of time and money to develop and have professionally manufactured.
I did waste hundreds of pounds trying to produce a kit using Fiat Coupe Brembo's but I wasn't happy that is was safely possible so I abandoned it.
Posted 6th Jul 2010 at 03:47
lotek
ok, seems alot of work to get focus rs to work. Sad
Posted 6th Jul 2010 at 03:43
velar
Ash those kits do look superb, and I would go that route if I did a brake conversion againWink Wink
Wink Wink
Posted 6th Jul 2010 at 13:54
rallyestyle
I have used 406 V6 discs with AP 4 pots on my Rallye Yes They are really good.
Unless time is not an issue and you like to measure/draw then just get one of Ash's kits, excellent product Thumbs up
Velar, do those spacers push the wheel out of the arch at all?
Just Drive It
Posted 6th Jul 2010 at 18:05
velar
The spacers are on a 406 coupe, so the clearance of the wheels is not as big an issue as on a 6.
I use ford wheels( at around ET 35 to 38), and the spacers are 25mm, so everything fits nicely(original 406 coupe wheels are ET12).
This is effectively the same as running spacers to correct the wheel offset, except the spacers sit inside the discs( which is arguably better) rather than on the outside as normal.
This all adds unwanted weight though, so Ash's alloy bells are a much better solutionWink ( did not know he did the kits when I upgraded mineAngry
Posted 6th Jul 2010 at 19:36
hatemgti
Did the 406 Brembo's will squeak using these 224mm ford discs?
Posted 6th Jul 2010 at 21:37
velar
Seams to be hit and miss as to wether they squeal or not!!
Posted 6th Jul 2010 at 22:13
tobeski
mcfc1987 has the adaptors that allow the use of the clio/megane brembos with the 406 v6 discs as these are what I bought of Rich_W and fitted when I owned the car.
They definately didn't squeel.
Now rollin' in a 182FF
Posted 6th Jul 2010 at 22:42
berger
The cooling issue wouldn't be a problem with a 306 provided you had the correct offset wheels though?
Surely the disc is at least 40mm away from the rear of the spokes, as the caliper itself needs to fit to the car, and the caliper measures about 50mm from the edge to the centre depth wise.
Posted 7th Jul 2010 at 00:10
One other thing i'll say about Ash's 310mm kit over the 406 disc is that they weigh a lot less and the Renault Sport calipers also weigh less and look a much better design side by side.
Posted 7th Jul 2010 at 01:43
velar
Remember that the 406 V6 disc vents on the inside, not the outside like the 306 or xantia V6 discs.
Posted 7th Jul 2010 at 02:17
