Author Subject: what have i done
bukosgti6
hi people need some help please i did an ecu reset on my 6 then left it standing for a mth without driving it now my new battery keeps dying Sad
Posted 19th Jun 2010 at 22:13
khj100
Your battery is dead
</lecture in rocket science>
Posted 19th Jun 2010 at 22:17
bukosgti6
i gave it a full charge 4 days ago and the battery is 3 mths old
Posted 19th Jun 2010 at 22:18
binkagti
It can still die, have you checked water levels in battery and the sell by date on it?
TEAM Supercharged Rallye
Posted 19th Jun 2010 at 23:01
bukosgti6
yes there fine i was wondering if it had anything to do with ecu reset i did cos since i did it its just been sat on drive way and not driven
Posted 19th Jun 2010 at 23:25
anth
ECU reset wouldn't have killed the battery.
Just get another battery when you ready to start driving it again and see how you get on.
Posted 20th Jun 2010 at 00:01
bukosgti6
ok thanks guys..
Posted 20th Jun 2010 at 01:01
chris167
get yourself a mate and get him to swap his battery into your box. should be fine mate Thumbs up
There are currently 1 people online
Most ever was 173 on Sunday 9th Nov 2008 at 8:04pm
Registered Users: chris167
Posted 20th Jun 2010 at 01:03
bukosgti6
could do but i wouldnt of thought a brand new battery would die in 4 days.
Posted 20th Jun 2010 at 01:10
chris167
are you sure you never left any lights on etc
Posted 20th Jun 2010 at 01:15
bukosgti6
no i thought that on tues so gave it a full charge and it died again today so ive took the battery off.I will take it back and get a new 1 next mth it never gets driven 500 mls a year it wont hurt leaving the battery off for a mth or so will it
Posted 20th Jun 2010 at 01:21
daveyboyholt
You might have some sort of problem with you electrical system. Mine was the rad fans. They kept coming on randomly after i'd locked it up. Thought it was the battery. So i bought another one, nice powerful diesel battery, and that went dead as well. I think there is a FAQ on detecting a drain on the electrical system. Ampmeter and pulling fuses one by one rings a bell
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 20th Jun 2010 at 04:03
bukosgti6
hi guys went shop got new battery old one was 3 mths old but was showing less than 1 volt so they replaced it this was sat.Now tuesday eve and its dead no lights left on not even been driving wtf is going on any suggestions.
Posted 1st Jul 2010 at 03:36
jeffers Forum Admin
Disconnect the alarm and see how you get on..Wink
Team Running Engine again!
Team Negative Camber!
Posted 1st Jul 2010 at 03:40
bukosgti6
how do i do that jeffers
Posted 1st Jul 2010 at 04:01
james_gti6
check to see if the alternator is charging, also check the discharge on the battery, put a amp meter between the battery neg and batt terminal and see what you get
if i dont see you in the mattress il see you in the spring
Posted 1st Jul 2010 at 04:03
bukosgti6
i aint even started the car since i put the new battery on.
Posted 1st Jul 2010 at 04:05
joevts
lock it manually with the key so it doesn't arm the alarm.
Posted 7th Jul 2010 at 00:14
bukosgti6
thanks guys sorted faulty remote wire on head unit.
Posted 7th Jul 2010 at 02:14
bukosgti6
bas**rd aint sorted. Was dead today it must be becauce its just standing and not being driven. I give up ive just took battery off
Posted 14th Jul 2010 at 22:36
al4x
burn it
Posted 14th Jul 2010 at 22:35
bukosgti6
now where have i put those matches
Posted 14th Jul 2010 at 22:38
