Author Subject: Heatshield fasteners
cress87
Gents,
I'm trying to remove the exhaust heatshield under the fuel tank just in front of the rear beam. It's attached with these w*nky plastic screw things and when you turn them they don't un-thread. Roll eyes
Is there a secret technique to removing these? Unsure
Any quick answers would be much appreciated as the car is on axle stands and I would rather it didn't remain so for too much longer. Smile
Cheers.
Posted 19th Jun 2010 at 01:28
antn1.b
my ones you just held the outer ring then wound the middle out, screw unwinds ¼ of an inch the you can wiggle them out. couple where jammed and got pulled out then replaced
Posted 19th Jun 2010 at 00:19
cress87
Hmm I'll have another look later and report back. Cheers mate. Thumbs up
Posted 19th Jun 2010 at 00:45
cress87
Stuff like this really p*sses me off. They are not coming out at all. They just continue to spin. The base attached to the fuel tank is not spinning so I don't see why they won't come out.
What exactly is wrong with metal screws and some form of captive nut? Onion-munching tosseurs. Dry
Any better ideas before I cut them off?
Posted 19th Jun 2010 at 01:27
side cutters under the head and pull.
Posted 19th Jun 2010 at 02:11
cress87
Cheers Welshpug.
Under the big washer or just the central screw head?
Posted 19th Jun 2010 at 02:16
under the screw head Smile
Posted 19th Jun 2010 at 02:23
cress87
Thanks again. Thumbs up
Posted 19th Jun 2010 at 02:24
cress87
All done, worked a treat.
Posted 19th Jun 2010 at 18:39
Epic thread bump, but once you managed to get these off could you reuse them again or did you need new ones? Dunno
Posted 16th Dec 2012 at 08:29
Depends how cack handed you are when removing.
I'd buy some new ones ready Stan if I were you.
  • Posted 16th Dec 2012 at 08:51
    I re-used them fine, I guess that means Dan thinks you are cackhanded Laugh my ass off
    Posted 16th Dec 2012 at 09:47
    Cheers guys, do they unscrew or are they a push-fit to start with?
    Posted 16th Dec 2012 at 10:41
    24seven
    Pretty sure the idea is you push them in, screw them up and as you do they splay out and hold themselves in place, hence how if you can unscrew them and carefully pull them out they can be re-used, although they'll probably always be a little loose afterwards.
    Posted 16th Dec 2012 at 17:54
    Yes
  • Posted 16th Dec 2012 at 17:56
    Cheers for the advice guys, managed fine in the end. Thumbs up
    Posted 16th Dec 2012 at 23:16
