displaying posts 101 to 125 of 125
Pages (5): first .. 3 4 [5]
Author Subject: turbo gti6 questions
bobdylan_55
Post #101
the bottom end does straight fit and lowers the compression as they are dished pistons, but i dont know to what extent, or how much boost could be coped with. 10psi easy id imagine.
309 GTi6-T
Posted 9th Jun 2010 at 19:13
spiky
Post #102
shame they not pocketed as well, as could be a easy fit and then fit nice cams on a gti6 NA Smile
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 9th Jun 2010 at 19:14
bobdylan_55
Post #103
also ive been told the s16 pistons and rods sit around 1mm further down the bore (not sure on accuracy of this but they do sit 1mm down the bore and not flush) so might be good for lowering compression a tad.
309 GTi6-T
Posted 9th Jun 2010 at 19:16
spiky
Post #104
handy, though i'm not sure as to how much, that part of engines goes over my head ...lol
MY YouTube Videos'
Posted 9th Jun 2010 at 19:19
pugheaven
Post #105
could you not use the hdi box as it Should cope with more torque and thats what kills the box. Dont think tom has ever blown his gear box up to be fair! Know of a few high power turbo cars and they dont seem to have problems with the gear box.
Posted 9th Jun 2010 at 19:30
bobdylan_55
Post #106
hdi boxes arnt much better if any, infact the best ones are surposed to be the old be1 from 205 309 gtis as they have helical gears instead of straight cut ones. If you drive it careflly and done floor it everywhere it might be ok, but if you want the full potential from it (especially if your aiming for 350-400bhp) then you should go for the ml5t
309 GTi6-T
Posted 9th Jun 2010 at 19:41
chrisd306
Post #107
davies is 16v head is on an 8v bottom end with woosenr pistons and diff rods im sure and a Rich_w head gasket.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 9th Jun 2010 at 19:45
jarrus464
Post #108
I don't think that the gearboxes off any pug 4 cylinder (be it diesel or petrol) can cope with any more than 300lbft really, I think you may have to source some stronger cogs or a straight cut sequential box
Posted 9th Jun 2010 at 20:05
binkagti
Post #109
jarrus464 wrote:
@binkagti,
Nice car dude Smile
Was thinking about forced induction if/when I get a 6, do you get much trouble with torque steer? and what benefits does your hybrid manifold offer over a standard one? or a modded gti6 one?, and 400lbft sounds a lot for the standard gearbox, I know rich w has trouble containing less than that how does yours cope?
and does that boost controller help with a smooth power delivery?, and what management do you use?
sorry for all the questions, just looking for inspiration Smile
Brett
Hi brett
Management wise i use efi, same as the peugeot le mans car uses, mine is euro 1 they are euro 8 i think lol.
The boost controller was stolen so not using that one, we have mapped the car for each rpm in each gear so very progressive.
Not too much torque steer but can catch you out if not holding tight.
Gearbox wise mine is standard i think cant remember to be honest, just have to make sure in gear before putting on the power. Have not taken it on track for long so really need to do some testing when i get it back to make sure it all works.
Manifold, does have a very good flow rate and one reason we can make so much ft/lbs with the turbo custom done aswell it all works well together.
TEAM Supercharged Rallye
Posted 9th Jun 2010 at 22:49
binkagti
Post #110
Moving on with more pics:
Rollcage, got it fitted but after engine broke decided to let it go to make some money, am gutted i sold it, proper safety devices cage.
One very broken engine lol, can just see he conrod still attached to the crank
Intercooler
Oil cooler behind i/c
Fuel system which i also sold, 1 swirl pot, 1 lift pump and then main cossie pump
New number plate.
First engine build up
Posted 9th Jun 2010 at 23:03
jarrus464
Post #111
binkagti wrote:
jarrus464 wrote:
@binkagti,
Nice car dude Smile
Brett
Hi brett
thanks dude,
so EFI is the company then? I'll look them up,
and you had it mapped and limited the torque in certain gears? what boost control do you use now then?
Posted 9th Jun 2010 at 23:41
sosmotorsport
Post #112
av only ever done in one gearbox so far with a genuine 380bhp and mostly track use so getting a hard time ,
as for a cheap turbo conversion to do it correctly i dont believe anyone can say there is a cheap way and for under 1k a highly doubt it certainly not to see over the 300 mark.
SOS Motorsport
www.sosmotorsport.co.uk
450bhp 205 16v Turbo
www.facebook.com/pages/SOS-Motorsport/159917677353556
Posted 10th Jun 2010 at 00:21
binkagti
Post #113
Yep i spent around £12000 on my current build, its not cheap, turbo 1 grand exhaust 1 grand pistons and rods more than 1 grand lol, brakes 1 grand, it soon adds up.
Posted 10th Jun 2010 at 01:41
sosmotorsport
Post #114
everything is a grand on a 16v turbo a soon found that out hahahaha
SOS Motorsport
Posted 10th Jun 2010 at 01:53
peder_306
Post #115
and you are looking at?
Peugeot 306 Dimma CoupƩ.
binkagti
Post #116
Looking at???
Posted 10th Jun 2010 at 02:03
peder_306
Post #117
binkagti wrote:
Looking at???
I ment bhp, sorry.. Smile
Posted 10th Jun 2010 at 02:08
binkagti
Post #118
Stated earlier, spiky said the injectors will be maxed out around 360bhp, i will be running almost full cycle so around 350bhp, also hoping for around 350 ft/lbs, last yr was running more, around 400 bhp, no graph to prove but was quite swift.
This time want to prove the power and use the car.
Posted 10th Jun 2010 at 02:14
peder_306
Post #119
386£
I just bought brand new wossner pistons 87mm with a bored block 87mm with xu10j4rs rods and with ported 8v head and inlet and exhaust manifold.
Im going to use the 8v turbo electric and ecu mangement, then i will buy vems for 286£ and go 16v Smile
Aiming at 300 hp. Smile
Posted 13th Jun 2010 at 20:31
pugheaven
Post #120
386 quid for what? That cant be pistons and rods surely?
Posted 14th Jun 2010 at 14:25
peder_306
Post #121
for all that ooohh and with 2,1d crank Smile
Posted 15th Jun 2010 at 00:59
pugheaven
Post #122
just realised you said using standard rods. Should be good! Ps i found a place that will make me my custom inlet for not alot of cash!
Posted 15th Jun 2010 at 16:30
peder_306
Post #123
well just pistons goes for £549.99, so it was a bargin with a complete engine. brand new! Big grin
how much exactly, pictures?
Posted 16th Jun 2010 at 01:14
fatlapit
Post #124
Look how far we have come from this
All of sos cars are still going trong too
Posted 13th Dec 2016 at 18:20
peder_306
Post #125
HAHAHA
Big grin
Posted 15th Dec 2016 at 07:29
