Team allesclar ®
| Author | Subject: 205 2.1 16v rallye track car |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
Post #126
this is simply fantastic, a credit to you ![]() ________________________________________ Team allesclar ® |
Post #127
rallyeash wrote: wheels are 106 S2 Rallye steelies so there 6J Cheers,look spot on Has anyone ever tried these on a 306 Rallye? If they were 15 inch pretty sure they would look great ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Post #128
no, because they're 14" ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallyeash
Post #129
as above rallye+gti6 need 15" wheels minimum________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Post #130
rallyeash wrote: as above rallye+gti6 need 15" wheels minimum To clear brakes? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stu
Seasoned Pro Location: Milton Keynes Registered: 22 Aug 2006 Posts: 5,525 Status: Offline |
Post #131
coskev wrote: To clear brakes? |
rallyeash
Post #132
just picked up some vectra v6 injectors for her. im running vectra v6 inners and outers now and after purchasing 2x6 sets means ive an unmatched set spare should i need any replacements.there ideal as they have got the correct flow rate, fit the standard gti6 fuel rail and loom, but also dirt cheap at around £20 for a set of 6. ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
Post #133
coskev wrote: rallyeash wrote: as above rallye+gti6 need 15" wheels minimum To clear brakes? if you want steelies get the c5 "alloy" steels. there round holes though. loads of info on here with the correct wheel bolts ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Post #134
what's the flow rate of them? 2.5 or 3.0?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallyeash
Post #135
225CC @ 3 BAR 16.6 OHMS2.5 items ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
arigti6
Seasoned Pro Location: Wiltshire Registered: 24 Jan 2010 Posts: 2,365 Status: Offline |
Post #136
rallyeash wrote: i'd like it to run 0-60 in flat 5's but we will see. Would love to see some vids of it on Track/hill climb when its ready ![]() ________________________________________ I Live for the 306![]() TEAM CHERRY PINK RALLYE 2008 BMW ///M 320d |
rallyeash
Post #137
ill be taking it up the hill at pugfest next year. will be at the action days, RS day, Rally day and a few trackdays at combe next year.want to go back to cadwell park want to do brands hatch too. also will be looking into competing in a hillclimb series next year. believe theres a southwest series which ill be eligible to enter. so should be about a fair bit next year ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
gtomi-6
Seasoned Pro Location: southampton Registered: 16 Jan 2009 Posts: 1,136 Status: Offline |
Post #138
hi ash, what head work have you had done and what cams are in it?? im going down the 2.1 route but with 285's, head work,longman inlet and bodie, and maniflow full system and manifold. have also been told i could see same figures as you are looking at. would love to come over and see it some time________________________________________ ph3 gti-6 china blue- mint conditionph2 gti-6 nile blue K.I.A dec 2010 |
rallyeash
Post #139
hi, the head has been worked alittle by sandy but nothing to serious at the minute. running catcams 109's.yeah when i get it back no problem, could take you for a spin. the long term plan is to gradually build a proper head up over the next year or so, with race spec cams, double valve springs, solid lifters etc then just swap the heads over and have it mapped, should see 270bhp ish then just with a head swap. ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Post #140
Ash whens it back from mapping? I'm interesed to see the results with the setup you have now.....________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
gtomi-6
Post #141
yes me also, well after you have done a head swap you are bassically in tourign car teritory. look forward to seeign it and deffinatly for the spin. ________________________________________ ph3 gti-6 china blue- mint conditionph2 gti-6 nile blue K.I.A dec 2010 |
rallyeash
Post #142
im going to cornwall tomorrow morning to do some work on the car pre mapping so should be within the next few weeks. will post up soon as i know.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
205gti6_ro
Regular Location: truro Registered: 13 Apr 2009 Posts: 181 Status: Offline |
Post #143
whos doing the mapping? sandy? |
rallyeash
Post #144
yup, will be down at colins farm tomorrow (launceston)________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
205gti6_ro
Post #145
ahh cool, sandy is a top bloke. take it your not going on the road to do the mapping then? |
rallyeash
Post #146
yep propably wont be any road mapping as the car currently doesnt have tax, insurance or mot.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
205gti6_ro
Post #147
ahh fair enough. this might sound like a silly question but do you trust your bonnet pins? i fitted mine last night and the bonnet just seems a little too flexible in the middle. |
rallyeash
Post #148
i trust the aero catches themselfs but with tb's normally the inner skin needs cutting out to clear the trumpets, this then leads to some flap in the middle. What i plan to do is get some 3mm thick 25mm wide flat metal the width of the bonnet and bond it across the inside at the front which should reduce flap. will stick some pics up when ive done it.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
Post #149
couple of pics from today down at colins farm.sorry its abit dirty though ![]() ![]() i wanted to run with the standard pedal box rather than the floor mount as it was to close for my long old legs and didnt get on with it very well. this proved a problem as the pedal box wouldnt fit between the engine, cage and bulk head. i removed the m/c then the servo, had to take the engine off its mounts and jack the engine up, once i got the pedal box fitted, refitted the servo and m/c all fitted ![]() as you can see where the cage goes it runs right where the resovior pot would live. colin spun these up for me out of alloy. was ace watching them being made. take offs to remote mount the resovior pots which ive now done but didnt take a pic ![]() ![]() couple more ![]() ![]() and for ten points who can guess whats in the 309 above my 205. wheels are a big clue! its inline and rwd. ![]() ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Post #150
Honda S2000.![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
