Author Subject: drilled and grooved disc's
ghost6
looking to fit some drilled and grooved discs to the front and back running of standard calipers wats any good and wat would be the best pads to use?
ghost
Posted 28th May 2010 at 02:57
kit
You are better off staying clear of drilled discs as they are crap and will soon crack. I remember a member on here saying drilled discs on cars such as a Porsche 911 are cast, where as the cheaper discs are not.
What is wrong with brembo vented discs? Do you want these for purely aesthetic purposes?
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 28th May 2010 at 04:06
Even the cast ones'll crack if they get too hot, but drilled ones...No
Posted 28th May 2010 at 04:09
ghost6
basically i just want some better ones cus i think the standard ones are ok but not brilliant so you reckon brembo vented ones would be best then?
ghost
Posted 31st May 2010 at 03:51
jeffers Forum Admin
Dude don't bother with drilled and grooved discs, some standard Discs with either Mintex 1144 pads or Ferodo DS2500 make an awesome set up!Wink
Team Running Engine again!
Team Negative Camber!
Posted 31st May 2010 at 15:42
bobdylan_55
as long as the discs are vented which im presuming all gti6 ones are, then they should be fine.
Stay clear of drilled ones, grooved ones can be ok tbh though and give good stopping power in wet weather conditions.
309 GTi6-T
Posted 31st May 2010 at 15:52
I'm using the plain Brembo vented discs from GSF with genuine Peugeot pads all round, really can't fault the setup for normal and fast road use. I'll be using them at FCS on track and at the nurburgring this summer, i've never had any problems with them getting too hot tbh.
I'm now using AP racing 600 fluid and braided lines but even with some unknown fluid and the rubber hoses i was impressed with the cars braking ability.
Posted 31st May 2010 at 18:22
kit
Grooved/drilled won't be any better, most likely worse and as Phillip said, will soon crack if they get too hot. I'm using standard Pug discs and pads. Stopping is great and more than enough? Dunno
I will be investing in some braided hoses soon, but will stick with standard discs and pads. If you plan on going on the track then I would suggest upgrading to Mintex 1144/1155 or Ferodo pads.
Posted 1st Jun 2010 at 02:22
foxy6
when i bought my 6 they had drilled and grooved discs, recently changed to standard and they were cracked bad, standard discs are spot on mate.
Posted 2nd Jun 2010 at 03:04
