Author Subject: Brake hose replacement
anth
Just a quick one,
I need to change the hoses on the dturbo.
I need to get a brake pipe spanner as i tried with an open end one before and failed and destroyed the nut.
I know its an 11mm but i have heard people say you also need a 9 and a 14mm as well??
I will be doing all 4, so maybe the other size spanners are needed for the rears?
EDIT: Just released i only have four hoses and the the car is a p1, didn't the p1 use 6 hoses?
Posted 15th May 2010 at 23:50
mr swampy s16
**BAD SELLER**
Only the veryearly cars had 6lines.
My s16 was an l plate and had four rear flexis.
Posted 15th May 2010 at 23:54
anth
Ah OK, hopefully I'm OK then its a 96 model.
any idea on the spanner sizes?
Posted 15th May 2010 at 23:58
Status: Online
DTurbo has drums, hence 4 lines.
later P1 disk rear cars were 4 line, 4th august 95 was when the 5th+6th hoses were deleted so the changeover was on the S16, all 6's afaik will be 4 hoses.
I think you'll need a 17mm possibly, but not a brake pipe spanner, Draper do the 10/11mm spanner which is all you need apart from the 14mm for the male end of the front hoses.
8mm I think for the bleed nipples, but been a whikle since I worked on the rear end of a 306 with drums, as it happens I will be doing so tomorrow LOL
Posted 16th May 2010 at 00:04
anth
DTurbo has drums, hence 4 lines, later P1 cars were 4 line, 4th august 95 was when the 5th+6th hoses were deleted so the changeover was on the S16, all 6's afaik will be 4 hoses.
Thanks mate,
I will get myself a 11 and 14 then.
Would be greatful if you could confirm the sizes of the rear spanners needed.
Have fun with it tomorrow LOL
Posted 16th May 2010 at 00:07
Status: Online
I guess you haven't got a standard 10 to 19mm set of spanners? I'd get down to halfords and check their special offers Thumbs up
I'll be allright, I loves it LOL
Posted 16th May 2010 at 00:11
anth
Yeah i have got standard spanners but last time i used a standard spanner to do this it caused me alot of emotional issues Smile
Glad your be alright, i on the other hand probably will have trouble LOL
Posted 16th May 2010 at 00:16
smegal
Halfords do some nice flare spanners.
The draper 10 and 11mm spanner is a good bet.
Ex SC-6
Now in a Megane R26
Posted 16th May 2010 at 06:08
oldbrownshoe
I use the Facom's , superb quality .
but if you already rounded the banjo bolt head as i did,
you'll going to suffer.
first you'll need to throw away the steel hose , and it's a job from hell.
then , don't even think of routing the new steel hose with all it's bents , it won't work.
the steel hose could be installed only when you strip the engine from the car .
the solution i worked out can be seen in the picture
the nut i destroyed
French military victories?
Did you mean French military defeats?
Posted 19th May 2010 at 19:58
anth
well im going to give it a reasonble amount of force if that starts to happen il bin the idea off and pay someone to do it i think.
Posted 19th May 2010 at 20:01
oldbrownshoe
the banjo bolt PSA used have tendency to stick ' and the steel it's made of is too soft and round easly,
the method used in american cars are far more superior,
if you can , do conversion to the american way :
look in this video how it's easy :
How to Rebuild Front Brake Calipers : How to Assemble the Banjo Bolt on Your Car
Posted 21st May 2010 at 16:42
if you are sure its not going to come undone easy then i wouldnt even use the brake pipe spanner id just get the mole grips straight on it and make sure its a firm grip, as soon as its cracked off then use the brake pipe spanner
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 21st May 2010 at 04:47
Chop the pipe off and get a 6 sided socket on there.
Posted 21st May 2010 at 04:53
yep and mole grips on the solid steel pipe union nut
Posted 21st May 2010 at 05:00
anth
Ok thanks il do that.
Is it a good idea to replace the union nut?
Can you pick these up from halfords or any motor factors?
Posted 21st May 2010 at 20:20
mr swampy s16
**BAD SELLER**
To replace the nut on the meal pipe u need a brake pipe flareing tool.
Id advise you try not to damage it
Posted 22nd May 2010 at 04:47
oldbrownshoe
There might be not enough length in the pipe to play with .
i'd rather prepare for replacing the pipe with complete new one,cut it to three section and flare it.
the flare should be adequate for braking with 37 degree angle.
Posted 22nd May 2010 at 11:40
anth
Failed
So having bought my jack Axel stands and a flare spanner
Start to do the job and notice the CV boot is destroyed.
I have therefore binned the idea off and taking it to Carl's in Norfolk, I'm now going to the pub with what little money i have left.
Thanks for everyone's help though.
Posted 22nd May 2010 at 17:13
ablister
have you ever tried to flare steel pipes? VERY difficult...
306 rallye, Richard Longman engine
rc10gt
Posted 24th May 2010 at 01:54
gilesy
I went to replace my rear calipers yesterday> Now the nut cracks off easy enough however it is turning the pipe with it.
As I am in France with no spare line, I nipped it back up LOL
I will get some new stuff on return to the UK
Posted 28th May 2010 at 16:34
GTI-6
errrr.
Drove home from work, brakes were being quite soft - Ive had a hose leaking. Noticed it a week ago and ordered a new hose.
old hose was dripping like a dirty hooker.
Got to the nut and it was completely seized and slightly rounded. Gave it some WD, an 11mm and a couple of light cracks and it just lost it. I've ground the spline part and removed it that way.
ISSUE:
I've now got a cut brake line. WTF do I do? I've cut it right behind the nut, so it will take a new fitting, but it's steel - I've flared thin copper pipes before, no issue, but this looks nasty.
Do I have to remove the entire brake line? Does anyone know the dia of the pipe? Hoping i can get a flange tool, an olive and a fitting.
I've worked on heaps of French cars and that is by far the worst design Ive ever seen. Lame.
Love thy 6
Posted 10th Jan 2013 at 08:24
photo might help but you need a proper brake spanner really rather than open ended ones. you could also try using some P-grips which are like crocodile teeth (for plumbing usually) to try undoing it. they grip tighter as you turn them
Posted 10th Jan 2013 at 08:46
GTI-6
Thanks Rikky. I had to cut the steel line as it was just rooted. Taken tomorrow off work to get it sorted.
Any suggestions on flaring the pipe?
Love thy 6
Posted 10th Jan 2013 at 08:49
tbh every time i've had a brake issue i've just repplaced with 3/16 copper pipe and m10 fittings i think, with a little DIY flaring kit off ebay. the steel stuff is good but too hard to work with when replacement is involved unless you are buying the dealer pre-formed lines
where is it leaking exactly? or which part needs replacement?
Posted 10th Jan 2013 at 08:51
GTI-6
2 secs, ill stick a photo up
Love thy 6
Posted 10th Jan 2013 at 08:59
