Author Subject: Flywheel prob....
will130787
Hi all, apologies for the wrong section and bluntness!
I have just driven my 6 home without a problem, let it 5 mins outside the house then went back out to it. Got in turn the key and it sounds like the starter motor is skiming the flywheel rather than turning it. The engine is not turning over although the starter motor is spinning with a grinding type noise! The last few times I have started it it's sounded like the starter is engaging or a little too long, a couple of seconds at most.
Any ideas? Easy tests etc?
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 12th May 2010 at 22:28
Sounds like a stck starter,give it a twat with a hammer to free it if you can Thumbs up
Posted 11th May 2010 at 22:21
dan@msx
or try putting it in gear and rocking the car
Posted 11th May 2010 at 22:22
will130787
I have put it in gear and moved it forward a bit, the car started. Switched it off and tried the same process but to no avail.
Fecked flywheel?
Posted 11th May 2010 at 23:19
gti6girl
you dont happen to have a lightened flywheel do you? If you do then its an early type and will be the problem
Posted 11th May 2010 at 23:24
will130787
Yeah I do have a lightened flywheel and also believe it to be the old type rather than the latest (a year old ish)??
Posted 11th May 2010 at 23:27
aaron6
They didnt have the harderned toothed ring pressed on so you will have lost teeth i reckon. Danny (3rd time lucky) had this happen to his early lightened flywheel.Smile
Posted 11th May 2010 at 23:32
will130787
Thats what I'm beginning to think! Thats the flywheels fecked then I guess! Sad
Posted 12th May 2010 at 03:12
will130787
If I put a d-turbo starter motor in will this temporarily solve the problem? As that engages the whole ring gear rather than just a section of it?
aaron6
Wouldnt think the remaining bits of tooth on the flywheel will last long though.
Posted 13th May 2010 at 00:17
will130787
I have just found out that I am already running a d-tub starter as per Marks installation.
Posted 13th May 2010 at 00:34
will130787
I have been out earlier and looked through the hole in the bell housing. I can see this on my fly wheel, although not as bad:
Think this might be my problem!
Posted 13th May 2010 at 02:46
Ouch!
Posted 13th May 2010 at 02:51
allesclar
just as bad doesnt come into it. one broken tooth is a complete and utter fail as a component.
Team allesclar ®
Posted 13th May 2010 at 02:57
nick!
Hi bud,
This happened to mine some time ago. I too had an old style lightened flywheel.
I took the gti starter off and used a starter from a TD. This has a wider spindle and so caught what was left of the teeth. Was fine for a couple of months, but then they finally let go.
Contact rich_w, just explain whats happened, he was a great help to me in helping to sort mine.
http://www.306gti6.com/forum/showthread.php?id=104600&page=1 << thread i posted when i got it!
Cherry Red Rallye - 179.1bhp@fly, 148.4bhp@wheels
Posted 13th May 2010 at 03:08
