displaying posts 251 to 275 of 516
Pages (21): first .. 10 [11] 12 .. last
Author Subject: Sigma to Sundance
cwspellowe
Post #251
eddy_gti6 wrote:
They could do with a better paint mate LOL
I know, they're not to my usual standards! They've been sat in the garage all winter so the paint's cracked and flaked off while i was working on them
Bye bye Sundance Kid Sad
Posted 12th Jan 2011 at 02:27
eddy_gti6
Post #252
RAMAIR
Posted 12th Jan 2011 at 02:30
ryangti6
Post #253
cwspellowe wrote:
Love
Not long to go now. Just need to make up a pipe to complete the vacuum system, silicone the area under the idle sliders, make a plenum like Yanni's, modify a TPS and that's it! Cool
And yes, i know trumpets would be better. And so would a sausage filter. Accoustic pleasure ftw though Razz
Definitly getting there, oviously you already know those filters arent the best but better than getting crap in the engine.
with the backing plate you are best off getting some thin steel and make your own then just buy a universal filter to suit.
Only other thing I would do is whip them back apart and replace all those nuts for pieces of tube cut to size, it'll only take a few mins now you know the sizes and will look better and make 100% sure they are clamped together
Ryan
Posted 12th Jan 2011 at 03:12
cwspellowe
Post #254
The bolts are all locked up tight, no gaps and threadlocked at the open end. They're rigid as hell Smile
How does the backing plate attach to the bodies though? Erm?
Posted 12th Jan 2011 at 03:14
ryangti6
Post #255
Happy days then.
Are there no bolt holes anywhere on the front of the bodies?
I'm more familiar with carbs tbh and every set of those I've seen have holes at the top and bottom on the front but I cant see any at the top in your pics.
Ryan
Posted 12th Jan 2011 at 03:22
cwspellowe
Post #256
Nope, they look like they mated yp with the bike airbox by way of a rubber o-ring but can't see anything to bolt a plate to :S
Posted 12th Jan 2011 at 03:25
cwspellowe
Post #257
Hold the phone, aye there's bolt holes.clearance is an issue though, because the housing for the idle sliders protrudes forwards from the inlet side of the bodies I won't be able to fit much of a plate, unless I offset it upwards slightly. Might clear the PAS pump then too
Posted 12th Jan 2011 at 03:27
mr swampy s16
**BAD SELLER**
Post #258
cwspellowe wrote:
Love
the braided hose in your parcel is the ideal size to make a vacume pipe from.
And yep you got stainless manifold bolts Wink
Posted 12th Jan 2011 at 03:31
eddy_gti6
Post #259
Any word on your cams? you can get the single ramair filters, look on ebay
Posted 12th Jan 2011 at 03:32
cwspellowe
Post #260
mr swampy s16 wrote:
cwspellowe wrote:
Love
What braided hose? You just ruined the surprise!
cwspellowe
Post #261
None yet. Can't afford them just now, £400 for cams + cambelt kit + time needed to fit them, a job for the summer i think.
Posted 12th Jan 2011 at 03:33
mr swampy s16
**BAD SELLER**
Post #262
Haha.
Posted 12th Jan 2011 at 03:41
Post #263
Without trumpets you will more than likely find the bodies flow less well than the standard plenum. I would'nt waste the money on a map until you have some trumpets buddy. And dont for god's sake make a box like Yanni's with a flat plate with holes in the back going straight to the bodies, a step change like that is death to airflow and will cause a huge loss in potential flow. 4x Full radius shiny air horns FTMFW Cool
Posted 12th Jan 2011 at 03:49
cwspellowe
Post #264
Fair point davey. As i'm sure i've mentioned already, i'm not in this for gains. Just so I can look at it and say yeah, I built that. Getting the bodies airtight and stable is my first port of call, then will be looking at trumpets and a dome filter. Out of interest, anyone know what size baseplate can be used without fouling the PAS pump?
Posted 12th Jan 2011 at 03:51
eddy_gti6
Post #265
R1 trumpets
Ramair sock filters
Thats £35 and your sorted LOL
Posted 12th Jan 2011 at 13:31
Post #266
eddy_gti6 wrote:
R1 trumpets
Ramair sock filters
Don't use socks No
When I was buying bits for my 'bodies I was heavily advised against by many not to use socks!
Posted 12th Jan 2011 at 17:38
Post #267
Buy a normal DCOE backplate and offset it to the right if you are'nt going to move the PAS pump.(Mines 425mm Wide)
Posted 12th Jan 2011 at 17:48
ryangti6
Post #268
cjm_harris wrote:
eddy_gti6 wrote:
R1 trumpets
Ramair sock filters
Don't use socks No
+1 on this, not supposed to be very good at all.
Also those trumpets would be a bit pointless really, way too short as they are designed for the bike.
Thats good that you do have bolt holes on the front, should make it quite easy to make and attach a baseplate.
Ryan
Posted 12th Jan 2011 at 17:57
cwspellowe
Post #269
ryangti6 wrote:
cjm_harris wrote:
eddy_gti6 wrote:
R1 trumpets
Ramair sock filters
Don't use socks No
Trumpets may appear short but the inlet tract is alreday quite long so trumpet to valve length would be similar to a setup with a shorter manifold.
Wanted to keep the manifold length as it curves down the way so can fit it under the bonnet. A shorter manifold the way i've done it would point the bodies at the sky.
Posted 12th Jan 2011 at 23:01
cwspellowe
Post #270
Grr nothing's easy these days. Got everything I need now to get the bodies fitted and been pricing up fuelling options, the clutch has given up the ghost. Really can't be arsed fitting a new one as I don't have a spare pair of hands and it's baltic outside Sad
Anyway have some pics if you aren't already disgusted enough. First, some shiny touches:
And some sticky touches:
Can't wait for some decent weather to get it cleaned, fit the bodies and do the clutch, think one of my top mounts are nearly dead too with the f*cking potholes round here :dry
Posted 21st Jan 2011 at 05:08
:: blade ::
Post #271
RUINED!!!!
only kidding mate Smile looks good,
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 21st Jan 2011 at 05:19
james_gti6
Post #272
say no more, was i lovly car
if i dont see you in the mattress il see you in the spring
Posted 21st Jan 2011 at 06:03
Post #273
Love fapfapfap!
Where it says "Ohhh shiny bits" on the inlet, when I saw that on previous pics, I thought that was just 'shopped on Laugh
Posted 21st Jan 2011 at 15:22
cwspellowe
Post #274
Gave it a wash today as i was sick of looking at road salt and scum, made me love it a bit more again Smile
Thought i'd post some more pics for the majority of you to moan about some more LOL
Posted 22nd Jan 2011 at 21:50
ballardpaul
Post #275
I like it alot. Think Matt black wheels is a must to fit in though.
Don't like the stickers inside.
Nissan 350Z (300 BHP)
Posted 22nd Jan 2011 at 22:15
