displaying posts 26 to 50 of 68
Pages (3): 1 [2] 3
Author Subject: Hydraulic clutch conversion
spiky wrote:
the ford cossie guys a bmw part (thrust bearing )for their hydraulic clutch,
and i dont understand why you need to go to a pedal box to just have a hydralic clutch
You don't have to, but I'll be fitting one anyway, so it makes sense to get the right one from the start.
Posted 18th May 2010 at 15:03
spiky
gti6girl wrote:
We use an ap racing slave unit which was machined in to the box a little. You will also need a rallye pedal box and loose your servo which makes the braking pretty shit
i was referring to comment above really Smile
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 18th May 2010 at 15:22
Ah, don't see why the braking has to be shit, if you get the right size master cylinder it should be fine.
Posted 18th May 2010 at 17:44
You'll need to get as much slack out of the system as possible so you can run a fairly small M/C, along with some high-torque pads.
Posted 18th May 2010 at 18:43
Carbon Lorraines will do the trick Ninja
Posted 24th May 2010 at 21:56
ecureuil_zx16v
mine
for this clutch
Citroen ZX 16v
XU10J4RS turbo
Posted 2nd Jun 2010 at 22:47
Very nice, does that setup work on a BE4 casing? And did you need to do any machining to the gearboc to fit that slave cylinder?
Posted 2nd Jun 2010 at 22:52
ecureuil_zx16v
much probably will fit, it's a very compact hydraulic release bearing... alcon one has 46mm tall, this one is 41mm tall... (5mm can make the difference). Only measuring you can be sure.. but must have enough space, for the bearing and for a mounting flange
Dind't do any machining to the gearbox, just made the flange between the 2 hole patterns..
Citroen ZX 16v
XU10J4RS turbo
Posted 3rd Jun 2010 at 11:47
Thankyou mate, just what I'm after Smile
Posted 3rd Jun 2010 at 14:44
Post #35
ecureuil_zx16v - anyone ever tell you that you are completely mad? In a good way, but mad all the same Big grin
Posted 3rd Jun 2010 at 17:38
Post #36
I would've mind seeing the pedal end, I know what the clutch end could look like LOL
Posted 3rd Jun 2010 at 23:45
pdd144c
Post #37
f*ck me you're taking this seriously Jim! Are you going to fabricate a pedal box then?
If you speak to Helix they can do a clutch that will be perfect without losing the clutch cable... Might be a cheaper option? And easier to repair at the circuit if needed, as if the slave seal goes it's gearbox off.
With regards starts a lot of series do rolling starts so this will help limit clutch wear...
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 4th Jun 2010 at 01:31
Post #38
use a BE4 (or BE1) casing, slave sits on the outside Smile
Posted 4th Jun 2010 at 01:45
pdd144c
Post #39
Ah ok, makes good sense.
FOR SALE
Posted 4th Jun 2010 at 01:51
Post #40
I don't know if anyone has done that yet though, the box pictured is an ML!
quite a few BE4's have a standard hydraulic clutch slave bolted across the front with an arm like a BE1 box.
Posted 4th Jun 2010 at 02:08
ecureuil_zx16v
Post #41
I use a ML5T gearbox, but there isn't why not use this setup in a BE gearbox
will take a picture of this hydraulic release bearing in a BE4 gearbox
One thing you can be sure... its the most expensive way Sad
But people say it's the best option possible for clutch release
If you can use a slave cylinder outside the gearbox much probably will be a lot easier and cheaper
Citroen ZX 16v
XU10J4RS turbo
Posted 4th Jun 2010 at 03:22
ecureuil_zx16v
Post #42
Lots of people Sad
But that's my intention... Devil
Citroen ZX 16v
XU10J4RS turbo
Posted 4th Jun 2010 at 03:31
206
Post #43
Hi guys,
registered specifically for this thread, as the topic is something i've been thinking about for a while now.
I have a slightly overpowered 206 GTI (that's an understatement...LOL), running a very aggressive AP Racing twin plate 184mm clutch, on an GTI 180 BE4 gearbox, using a cable operated AP clutch bearing. Needless to say, apart from operating more like an on/off switch rather than a clutch, it's EXTREMELY heavy - combination of the 2 makes it impossible to modulate. So what i'm thinking is that it would be a good idea to replace the regular bearing with a hydraulic one, if i can find one slim enough with adequate throw-out.
I was also thinking, instead of making the hydraulic bearing fir the cable bearing gearbox, it would be much easier, i think, to find a car that already uses a BE4 gearbox and a master/slave hydraulic bearing setup, cannibalize the casing from it, and combine it with the existing gearbox on the car - and use the OE hydraulic setup on the AP clutch. Yes, it might not be ideal, might be heavy, might not work at all, but still worth a try.
Ideas? Recommendations? Comments?
Also, what car uses a BE4 that fits onto an EW10 block, with cable linkage and hydraulic bearing setup?
Thanks.
Posted 24th Feb 2011 at 20:33
Post #44
Thanks.
206 gti180 LOL
Posted 24th Feb 2011 at 23:04
206
Post #45
...well, do you think i'd be asking that question if that car really had hydraulic bearing + cables? Smile I've got 4 GTI 180 boxes lying about, and they are all mechanical with rod linkage.
Posted 25th Feb 2011 at 00:50
Post #46
can't be from 180's then LOL
the 138 gti clutch setup is the same as the 180, but the 180 uses cable shift.
Posted 25th Feb 2011 at 00:57
206
Post #47
Yes, they're all from the 180, but i'm a moron, and a very tired one at the moment. making STUPID mistakes Smile Asking a similar question about another car's gearbox, and mixing up my facts...never mind LOL
Yes, they are cable operated, but using mechanical clutch, so no good. Other ideas?
Posted 25th Feb 2011 at 01:30
206
Post #48
Oh, btw - the car - 206 GTI, EW10J4, GT30 turbo, ITBs, nitrous, TON of other mods, 6 years and who knows ho much $$$. 470BHP.
206 has attached the following image:
Posted 25th Feb 2011 at 01:15
Post #49
RHD 138 and 180 have hydraulic clutch Thumbs up
206
Post #50
Nope, no RHD cars over here...
There must be SOMETHING that uses the BE4 hydraulic clutch that i can find over here???
Posted 25th Feb 2011 at 01:34
Pages (3): 1 [2] 3
