displaying posts 51 to 68 of 68
Pages (3): 1 2 [3]
Author Subject: Hydraulic clutch conversion
Post #51
307 Smile
the BE4 hydraulic gearbox uses the same pressure plate and bearing, just a different arm with a slave cylinder bolted on the front.
Posted 25th Feb 2011 at 01:45
206
Post #52
Which one, the 2.0?
I've heard that some of the commercial vehicles, with diesels, might also use the version of the hydraulic BE4...?
Posted 25th Feb 2011 at 02:52
Post #53
the petrol 2.0 and anything smaller that doesnt use the MA.
Most of the 2.0 + 2.2 diesels and the 2.2 Puma diesel in the commercials use an ML5 or ML6 gearbox.
Posted 25th Feb 2011 at 03:11
206
Post #54
Ok, i'll try and find on and see how it goes, if the standard hydraulic clutch setup will work with the AP clutch.
Posted 25th Feb 2011 at 03:19
Post #55
206 wrote:
Oh, btw - the car - 206 GTI, EW10J4, GT30 turbo, ITBs, nitrous, TON of other mods, 6 years and who knows ho much $$$. 470BHP.
Finally a 206 I like Big grin Cool
Posted 25th Feb 2011 at 03:25
206
Post #56
I bet you'll like this even better, then Smile
No thread hijacking any more, i promise...Ninja
206 has attached the following image:
Posted 25th Feb 2011 at 03:55
Post #57
very nice, this is the second TB/Turbo setup on here in a short space of time, have to admit I'd never even heard of mixing the two induction types until last week. Technicly it's still a plenum style inlet, but with the throttle butterflies in the runners instead of the mouth of ther plenum. You calibrate the engine map with a MAP sensor on the plenum somewhere I guess?
Posted 26th Feb 2011 at 15:09
206
Post #58
Two MAPs and a TPS - TPS (AlphaN mapping) for lower revs for more precise control as MAPs have poor resolution while off boost (TB setups are like that), making the transition to MAP control gradually as it starts coming out of the vacuum.
2 MAPs are on the car, one before and the other after the throttle plates, gives much more precise and quicker boost control, with positive feedback control.
Soon to be mapped on E85 (~550BHP), which should put it back on the 1st place as the world's most powerful EW10 Smile
Can this be split as a new topic, i don't want to disrupt this one anymore?
Posted 26th Feb 2011 at 16:27
cwspellowe
Post #59
Just make your own thread LOL
More pics in it too Thumbs up
Bye bye Sundance Kid Sad
Posted 26th Feb 2011 at 19:53
Post #60
Sounds like a very well resolved setup. I imagine wheelspin is a major problem for you though.
Posted 26th Feb 2011 at 21:20
206
Post #61
No, not really - i'll open a new topic, post a few video links, pics, specs, etc.
Anyway, anybody got anything to add on the topic of the gearbox?
Posted 27th Feb 2011 at 00:16
rallyeash
Post #62
daveyboy wrote:
this is the second TB/Turbo setup on here in a short space of time, have to admit I'd never even heard of mixing the two induction types until last week. somewhere I guess?
standard on the lotus esprit...
Love
309 3dr K20 Type R
Posted 1st Mar 2011 at 01:04
206
Post #63
Nissan Skyline as well
Posted 1st Mar 2011 at 02:05
Post #64
Pulsar GTIr too Smile
Posted 1st Mar 2011 at 02:32
206
Post #65
Ok, furthermore - what should be the clearance between the hydraulic bearing and the plate cover, and what should be the piston travel - e.g. on the pictures posted earlier in the thread?
Posted 2nd Mar 2011 at 15:52
bobdylan_55
Post #66
dont know if its been said or not yet, but change to the ml5 gearbox from 406 coupes or 2.0 turbo etc they fit straight on and are hydraulic. The biggest pain is remanufacturing the hydraulic hosing from the slave and then fitting a master cylinder somewhere. O and bleeding can be a pain in the batty if you get the old style slave as it has no bleed point.
Best way id recommend is to get the newer slave with the metal union and pipework, cut it off about 3 inch from the slave, put another brake union onto it and joiner etc to some more brake pipe and then go from there.
309 GTi6-T
Posted 2nd Mar 2011 at 16:04
bobdylan_55
Post #67
ecureuil_zx16v wrote:
mine
for this clutch
Just wondering how you managed to get this flywheel to work? the inner diameter of the flywheel wheel for this clutch setup needs to be a maximum of 132mm, where as this flywheel has an inner diameter of 160mm.
Did you have to make an adapter?
thanks
309 GTi6-T
Posted 23rd Dec 2015 at 13:31
petert
Post #68
Sorry, only a few years late @bobdylan_55. Use a 205 1.6L Motronic flywheel.
Posted 4th Jan 2021 at 10:47
Pages (3): 1 2 [3]
