displaying posts 1 to 25 of 68
Pages (3): [1] 2 3
Author Subject: Hydraulic clutch conversion
Has anyone apart from Gti6girl done this? I'm looking into getting it done and the prices I'm bieng quoted are horrific, it seems it's not particularly straightforward. If you have any info regarding what slave cylinder is suitable etc. that would be much appreciated.
Posted 16th Apr 2010 at 20:39
gti6girl
We use an ap racing slave unit which was machined in to the box a little. You will also need a rallye pedal box and loose your servo which makes the braking pretty shit
Posted 16th Apr 2010 at 21:05
blaze wip
So not a good idea then?
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 16th Apr 2010 at 21:07
When I spoke to A B Motorsport about it they reckoned £400 odd to machine the gearbox to take the slave cylinder. That seemed a bit steep. Do you know exactly whats involved?
I know the AP Racing triple plate clutch is about £900 and the slave cylinder is about £300.
The pedal box is bieng ditched anyway and so is the servo so I know I'll have to get physical on the middle pedal from now on.
Posted 16th Apr 2010 at 21:14
gti6girl
I suppose it depends on what slave you are using as there are many types. On mine a plate had to be machined to go on the back of the unit and a little off the box where it was catching. Andy baker made my pedal box for me, but i rhimk my braking is due to standard discs and pads
Posted 16th Apr 2010 at 21:21
gti6girl
For what reason would you want to do this conversion?
Posted 16th Apr 2010 at 21:29
Because I want a seriously uprated clutch, as I plan at some point to race the car and the standard setup won't last long under that kind of abuse. I'm going to a bias pedalbox system anyway. The AP clutch can be rebuilt pretty reasonably by sending it back to them, so long term it will work out more cost effective to go that way. I had thought about upgrading to Piper 320 cams at some point down the line, but they said that because lowdown torque was so low in order to get the car off the grid you basicly have to put in about 5000rpm then sidestep the clutch! This will kill off the current clutch arrangement in no time, so I was planning to upgrade that side of things beforehand.
Posted 16th Apr 2010 at 22:10
mabgti
NV motors
x2 on whatever you do daveyboy... i wantBig grin
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 16th Apr 2010 at 23:49
gti6girl
Sorry i can understand why you would want the clutch but would recomen just running off the cable. I only went down this route as i got the whole setup fitted for around £200 including the clutch.
Posted 17th Apr 2010 at 02:31
miles
The pedal end is easy and if you run a pedal box is even easier, You can run a remote servo if you want as well which helps.
I;'d have a look at a BE4 box on a 206 GTi etc as thats got to be the easiest way to fit one or just use the AP bearing with a couple of pipes coming off of it
www.pugracing.com
Posted 17th Apr 2010 at 02:59
What am I looking at for you to source me a box and supply a hydraulic clutch setup complete?
Posted 17th Apr 2010 at 17:57
gti6girl
dont spend too much as i think you will be dissapointed as you prob wont notice any difference from a cable apart from a stronger leg
Posted 18th Apr 2010 at 01:02
miles
LOL, I have been looking for a cheap BE4 box for a while so I can have a nose
www.pugracing.com
Posted 18th Apr 2010 at 01:17
dj_turbo
I used an ap twin plate in my old paxo and the pedal was heavy but ok i extened the gearbox arm this helped alot.
I now use a helix 7 ¼ race clutch in my 205 with a be3 gearbox and a custom release bearing and the pedal is fine the bite is harsh but it will be even with hy set up.
Posted 18th Apr 2010 at 02:59
Just stick a V6 in and you'll be halfway there Razz
If you get the box side sorted then there are a few cable to hydraulic setups about if it helps Smile
Posted 18th Apr 2010 at 19:41
I have a BE4 box I can take a picture of, but for those that oknow 205's, its just like a BE1 but with a slave cylinder instead oft he quadrant, IIRC some early BX's had the cable directly on the arm like this.
also some partner vans had a cable setup in the same place as the hydraulic cylinder.
Posted 19th Apr 2010 at 16:49
Try speaking to bobdylan, think he is changing to hydraulic clutch setup?
Posted 20th Apr 2010 at 00:22
fletch
Track Head
Wouldn't it be better to change the standard clutch every 3 or 4 races at £100 a time?
Posted 21st Apr 2010 at 14:32
Certainly would get good at taking the box off etc LOL
Posted 21st Apr 2010 at 15:04
ecureuil_zx16v
http://www.alcon.co.uk/Catalog/14.pdf
that's what I'm doing in my ML5T gearbox, but with Tilton 7,25" 3-disc clutch, also tilton release bearing and master cylinder
Citroen ZX 16v
XU10J4RS turbo
Posted 11th May 2010 at 20:56
bellcp306td
I have a problem thinking about the car side of things (master) side of a hydraulic conversion.
Where did the road go!
Posted 12th May 2010 at 20:46
Do you have part numbers/prices for what you have done there buddy?
Posted 12th May 2010 at 21:38
ecureuil_zx16v
Sure
Still going to install, bought the parts this week from USA, must receive next week:
61-8002 - Tilton hydraulic release bearing, 1,60" tall, 44mm bearing contact (right diameter for the 7,25" clutch) - 320 US dollars
74-750U - Tilton master cylinder kit (with reservoirs and remote kit) - 80 US dollars
Remember, I use a ML5T gearbox,the right is to measure the space available for the release bearing, know how tall it can be.. It varies with the flywheel, the clutch, and gearbox used.
If you use a push-type clutch in the std 215mm flywheel and a BE3/BE4 gearbox, I can measure it for you tomorrow. My car is without gearbox and I have the BE housings of a broken one
Citroen ZX 16v
XU10J4RS turbo
Posted 13th May 2010 at 10:23
if I'm correct with a BE box you can use a BE4 casing from a DW8 in a Partner on an XU engine, these do use a hydraulic as well as cable clutch so there are off the shelf O.E parts to do the engine end.
not sure how you'd get around the pedal end due to the position of the servo, but probably mount the master inside the cabin above the pedal.
Posted 13th May 2010 at 15:25
spiky
the ford cossie guys a bmw part (thrust bearing )for their hydraulic clutch,
and i dont understand why you need to go to a pedal box to just have a hydralic clutch
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 13th May 2010 at 16:23
Pages (3): [1] 2 3
