Author Subject: big rear discs
mxcrazy
With people upgrading discs, calipers, pads etc on the front of their cars, what are you doing about the rear?
Using bias valves, or leaving them as they are? With a bigger discs, or better calipers, less pedal effort is needed to lock the front wheels, thus, less pressure goes to the rear calipers as i understand.
I was looking for bigger discs but non vented, so they are not too heavy, and low and behold, 406 rear discs, 290mm diameter, 10mm wide.
Im sure some brackets can be made to relocate the stock rear calipers even.
Thoughts?
Posted 14th Apr 2010 at 02:38
oldbrownshoe
Bigger (substantially) front disks = longer stopping distance.
it's just so common mistake to only upgrade the front that it became a norm.
French military victories?
Did you mean French military defeats?
Posted 14th Apr 2010 at 02:59
mxcrazy
oldbrownshoe wrote:
bigger (substantially)front disks = longer stopping distance.
Why is that you think?
If they are really heavy then i can understand.
Posted 14th Apr 2010 at 02:57
I'd just uprate the rear pads if you need to get the balance back to the rear, do you really need the extra heat capacity of 290mm rear discs, or just the extra rear bias?
Posted 14th Apr 2010 at 03:05
mxcrazy
Just thinking really phillipm, out load (quietly) so to speak (type).
Was thinking bore bias than anything, i know the weight is an issue but i would help surely, leverage effect.
Posted 14th Apr 2010 at 03:17
cress87
On my dad's 406, and presumably all the others, the rear discs incorporate a central drum which is utilised by the handbrake. I doubt they'd even fit onto a 306 hub.
Posted 14th Apr 2010 at 03:21
oldbrownshoe
Read this
http://www.stoptech.com/Products/BBK/balance.shtml
in a nutshell :
the optimal breaking occurs when all the tires are on the verge of it's grip just before sliding ,
violating the front/rear balance by applying more power to the front ,leads to locking the front tires before the rear ones exploit there full grip potential and since 4 tires participate in the breaking you loose in the total sum when the rear contribute less.
Posted 14th Apr 2010 at 03:24
t0mt0m
and even if they did why would you want to fit them??
1997 Diablo Red 1.6 xs! crashed and scrapped!
1998 Nile blue Gti 6
1999 Yamaha R6! maybe for sale soonish still in two minds!
mxcrazy
Ahh, thats buggers that thought then.LOL i just ebay search for the discs and the pics came up with normal looking discs.
Posted 14th Apr 2010 at 03:25
mxcrazy
oldbrownshoe wrote:
Read this
in a nutshell :
Yep, thats what i though, hence the reason to try and even the bias up between front and rear.
Posted 14th Apr 2010 at 03:26
simonjames
i have the 290mm 406 v6 coupe rear disc, calipers i just need to trial fit then decide if i put the 406 drum for handbrake or alter the caliper somehow
MY EBAY ITEMS
07943066306
Posted 14th Apr 2010 at 03:27
mxcrazy
Because they are bigger diameter, 290 as opposed to 247, more 'leverage' action hence less effort required to slow/lock the wheel.
mxcrazy
Is it a single disc then and separate drum?
Posted 14th Apr 2010 at 03:29
oldbrownshoe
mxcrazy wrote:
oldbrownshoe wrote:
Read this
in a nutshell :
if you upgrade to more powerful front brakes and
then weakens it to balance front/rear ,you'v just wasted a loads of money and added weight.
Posted 14th Apr 2010 at 03:32
cress87
They might be but I seem to remember the disc being offset inboard and the drum effectively being the 'inside' of the disc, if you see what I mean.
Posted 14th Apr 2010 at 03:36
oldbrownshoe wrote:
Read this
in a nutshell :
Unfortunately, tyres have progressed a long way since the 306 was designed, and anyone running uprated brakes is also liable to be running on track on a grippy surface - where they have a lot more weight transfer to the front - so uprating the rear isn't always needed.
Posted 14th Apr 2010 at 03:37
mxcrazy
It is a mis-conception that bigger discs are better for braking, if you can lock the brakes with stock brakes then you are getting more than maximum stopping power, however by using larger discs, multi piston calipers, better pads, you are reducing the effort needed to get maximum braking effect, and reducing fade from heat, if the brakes dont have to work as hard to get maximum braking effect it is easier on you and the brake components.
Agree?
Bigger discs are only needed if:
a) You don't have enough thermal capacity with the stock discs - they're running too hot to be safe any more
b: You can't get more leverage by any other method.
c) Your wear rates are far too high on smaller discs.
Posted 14th Apr 2010 at 03:40
simonjames
yeah iirc the disc sits over the drum
MY EBAY ITEMS
07943066306
Posted 14th Apr 2010 at 03:51
miles
You can fit vented and slightly larger ones off the shelf all Pug parts too,
www.pugracing.com
Posted 14th Apr 2010 at 07:29
simonjames
using s16 front discs yeah?
MY EBAY ITEMS
07943066306
Posted 14th Apr 2010 at 14:19
velar
Front discs on 306/406 are not very well vented, so overheat in track use.
I run an ex BTCC 406 coupe, with had standard 406 V6 discs (305mm) and they overheated within a couple of laps( with just a standard GTI6 engine.)
Upgraded the front discs to 324mm( with much better internal venting), and they now last over 25 laps with no heating issues.I can also get away with much cheaper brak pads( £50 a go instead of £120)
The standard 406 rear discs are 290mm but are really heavy due to the internal handbrake. I changed them to 280mm with Ap twin pot calipers, and use a brake balance bar on the car.
I am putting the same brake setup on the GTI6Roll eyes Roll eyes
Posted 19th Apr 2010 at 23:52
simonjames
Ha i tried the 406 1s on today and they would need to be spaced out about 3-4 inches to fit so not gonna bother with them LOL
MY EBAY ITEMS
07943066306
Posted 20th Apr 2010 at 00:45
MCH_GTi6
formerly mch
do tell Happy
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 20th Apr 2010 at 00:51
