displaying posts 26 to 50 of 375
Pages (15): 1 [2] 3 .. last
Author Subject: Tea Boy's 6
tea boy
mechanical_repairs wrote:
quote:
[quote="thugpuggin
Looking at the sticker on the cross member you can see it's already been replaced once.
They all have that, its the smaller parts sticker that gives the game away, come on Jon, thats a barcode style sticker, unsure what its for though.
Carl
Carl is right, barcode sticker on original crossmember.
The whack on the N/S was quite hard, so the chances of it not affecting the O/S were slim.
It did not show up in the pictures I have but the chassis was creased with a bulge on both sides and the front bent down.
I thought the best plan would be to cut out the bulged bit,
Straighten it out,
Then 'jig' the chassis back into shape.
My 'jig' is a trolley jack and a lump of wood
Then weld it back in.
I have not done any welding for months, so it is a bit rough looking.
It will look better when I have linished it off and painted it.
I tried on a few panels to check that it all still fitted together. (BTW this was before I jacked up the driver's side)
When I'm done it should look just like it did before I startedRoll eyes
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 25th May 2010 at 23:23
tea boy wrote:
daveyboy wrote:
Might be an idea to check your chassis/engine mount cup while its easy.
Smile
Do you recommend 'fixing' it even if it is not yet broken?
Personally I would as it will never get any easier to do than it is now, but you may get away with it, the thing is it may already be partially cracked underneath and you just can't tell. Personally, I think it would be a sensible precaution as it's such an easy job to do with all the room you have to work with at the moment.
Posted 25th May 2010 at 23:56
tea boy
daveyboy wrote:
Personally I would as it will never get any easier to do than it is now.
Another job for the list then.
Make tea, not war.
Posted 26th May 2010 at 00:41
mechanical_repairs
Doing a cracking job there. Fair play
carl
Posted 26th May 2010 at 00:53
tea boy
carl
Wow, my car carries the C.G. Cars seal of approval.
No higher praise in the land.
Thanks Carl. (cheque is in the postWink )
Make tea, not war.
Posted 26th May 2010 at 01:06
tea boy
I had a bit of a setback.
I got everything lined up perfectly and started welding it up.
Checked it a few times it was all nice.
I then had to take the wing & slam panel off to get at it.
When I offered the stuff back up, the front end of the N/S chassis leg had pulled in towards the centre of the car by about 6mm.
I knew it was going to pull and thought I had allowed for it.
Obviously didn't allow enough Doh
I know that is not a massive ammount, but the whole point of the job was to sort out the chassis leg alignment.
What I needed was to push the chassis leg outwards whilst the top slam panel mount and bottom rad crossmember remained in the same place.
some kind of jig for me to jack against.
I needed a type of 'strut brace' that went between the slam panel mounts
That also secured to the bottom near the rad crossmember
With something to jack against
That was strong enough
To take the load applied by the screw jack
It may well end up the right shape when it is done after all. Wink
Make tea, not war.
Posted 28th May 2010 at 16:47
berger
You've been busy steaming through this at a rate of knots!
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 28th May 2010 at 20:02
tea boy
The pressure is on now mate, Mrs Tea is losing her sense of humour about the house being full of car bits.
Make tea, not war.
Posted 29th May 2010 at 02:40
Nice thread and quality workmanship. Subscribed Thumbs up
Posted 29th May 2010 at 02:47
tea boy
Post #35
I was hoping to get all the welding over and done with today.
I put on the new N/S front bit.
I started drilling out the welds on the O/S.
To be honest, the O/S was only a little bit bent and it would probably have been easy enough to straighten out.
The part was cheap enough though.
Infact, after ten years of buying Porshe parts most things seem to be cheap, and whilst you are in there......
Sadly that is about as far as I got, it pi55ed down for the rest of the day Sad
Make tea, not war.
Posted 30th May 2010 at 03:29
tea boy
Post #36
It was rain stopped play over the weekend, other stuff on Monday and rain again last night.
Sun was shining when I got home today so I had to do a little bit.
weld through primer
Stuck it on
so the inner wing is looking like this
the chassis legs are nearly done
I will have to paint it soon.
Make tea, not war.
Posted 3rd Jun 2010 at 03:29
ballardpaul
Post #37
Hey quick question. I might have missed the point here, but why didnt you just buy a 306 that was straight and true?
Nissan 350Z (300 BHP)
Posted 3rd Jun 2010 at 03:32
tea boy
Post #38
Have you have been put up to this by Mrs Tea Whistle
Getting a straight one would have been too easy.
Real reason is that I bought a lemon.
I didn't realise it was bent until I started taking it to bits.Sad
Make tea, not war.
Posted 3rd Jun 2010 at 03:54
Post #39
Teaboy you are a true legend with the dedication and skill you are showing in this build.
You deserve a cuppa! LOL
Posted 3rd Jun 2010 at 04:12
tea boy
Post #40
Cheers mate, I'll put the kettle onBig grin
Make tea, not war.
Posted 3rd Jun 2010 at 04:16
mart.h.
Post #41
you dont hang about do you!
i know where to go to get the welding done on my rear turrets now Big grin
keep up the good work
oh enjoy your brew Smile
[ url=http://www.google.com]Click Me[ /url]
Posted 3rd Jun 2010 at 04:41
mnpr4
Post #42
Excellent work mate Thumbs up
I bet you cannot wait till this is done. Keep up the good work and all the best.
VW Bora TDi 130
Ex Bianca White Gti6
Ex Team China Blue 6
Ex 406 Coupe 3.0 V6
Posted 3rd Jun 2010 at 05:02
tea boy
Post #43
I have done a bit more.
I put the holes back in the chassis leg, can't remember what they are for Unsure
replaced a couple of snapped studs, this one for the harness trunking and one on the other side for the washer bottle.
Drilled them out & tapped the hole
Then cut the head off a 6mm bolt which I can screw into the hole and plug weld from the back.
The past few days I have given it a good going over with deox gel then hydrate 80.
I thought I better get a bit of paint on to protect it so I have put on some zinc phosphate primer.
It wants another coat then flatting off for a bit of black.
I picked up a better slam panel yesterday, so I dropped that off at the powdercoaters today.
It should be done early next week.
If it is dry, I might be able to get a bit more done tomorrow.
I want this on the road soon, been in bits too long now.
Next time I am getting a straight one.Whistle
Make tea, not war.
Posted 5th Jun 2010 at 00:36
Post #44
that's quite epic, I've never seen anyone use their skills to this extent on a 306 before, many an old VW BMW or Vauxhall, Ford and Mini, the odd 205 etc.
what is your trade by the way?
those holes on the n/s chassis leg might be for the airbox?
fancy welding my 205 when you're done? pretty simple stuff compared to this LOL
Posted 5th Jun 2010 at 01:00
mechanical_repairs
Post #45
Have to say you have done a great job and attention to detail is second to none, the holes you have put back in are to secure the airbox.
Carl
Posted 5th Jun 2010 at 01:03
tea boy
Post #46
Carl
Thanks Carl.
It didn't have an airbox on when I got it, but it will when it is done.
Sorry welshpug, I need to get on with the 911 when I've done this.
BTW, I am a crocodile wrangler by dayWhistle
Make tea, not war.
Posted 5th Jun 2010 at 01:17
mechanical_repairs
Post #47
I welded them holes up when I did the rallye. As for your job your name says it all.
Carl LOL
Carl
Thanks Carl.
Posted 5th Jun 2010 at 02:42
tea boy
Post #48
Carl LOL
My reputation precedes meBig grin
Make tea, not war.
Posted 5th Jun 2010 at 02:54
tea boy
Post #49
Got my slam panel back from the powder coaters today.
Had to stick it on to see what it looked like.
Done satin black.
I could do with a new one of those Total stickers to go on it.
Can you get them anywhere?
Make tea, not war.
Posted 9th Jun 2010 at 22:49
Post #50
Carls the man for the sticker
Posted 9th Jun 2010 at 23:12
