Author Subject: my brakes are wobbling again
russbez
I am having an issue when braking
This is my second set of brembos, red ones I still have I haven
My Rallye project thread
Posted 1st Apr 2010 at 19:00
could be bent mounting bolts or lugs.
Posted 1st Apr 2010 at 19:19
driveshaft?
Posted 1st Apr 2010 at 19:20
cosmic spanner
Moral objector
Just out of interest, do your discs have the small locating grub screws? Sounds crazy, as I know the wheel nuts should be holding everything together, but just wondering as I've noticed something myself with these...
As for uneven pad contact, I would also check that the pistons, particularly on that side it would be the smaller one at the top, are clean and moving freely.
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 1st Apr 2010 at 19:43
Check the calipers are sitting flush on the mounts and not on a bit of rust, etc. Tend to get that when they're not set square.
russbez
reasonable suggestions! the short drive shaft (passenger side) is a reasonably new one from a local iirc
and theres little of no wobble through steering wheel or gear stick when accelerating atm
bolts have been on and off a few times, its just 406 coupe brembos bolted straight on
never really looked at the bolts
Hmm
i do have the locating grub screw, i only put one of them in, just so am not arsing around taking wheels on and off trying to get everything to line up. I never tighten them up too much as I have had issues getting them out in the past
had the said calliper off last night, pistons came out quiet nicely and callipers are in very good nick
I squeezed them onto a block of wood, cleaned everything up and re-bled the passenger side calliper
Posted 1st Apr 2010 at 19:58
iplay
If a disc warps and is driven for even a short distance the pads take on an uneven shape.
Replacing the warped disc and using the same pads will warp a new disc in very little time.
Even if the pad is slightly uneven the pressure exerted by the pads and heat generated by the discs is enough to warp.
Posted 2nd Apr 2010 at 01:48
tvrfan007
Was the hub flange thoroughly cleaned?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 2nd Apr 2010 at 12:51
russbez
iirc... no
but all i done was remove old calipers and fit the newer ones i had, will have wire brush to had to will look properly when i take them off again
Posted 2nd Apr 2010 at 16:24
russbez
okay
clean everything up and buy more pads and discs? will i bother getting disc machined?
Posted 2nd Apr 2010 at 13:56
russbez
anyone tell me if there is any reason why i should be my old discs machined straight? they might not actually be badly out of shape, but I can get it done at work very accurately
these discs are barely 2000 mile old iirc
I have bought new pads
Posted 9th Apr 2010 at 19:56
