How the feck do I adjust the doors without removing the front wing?
| Author | Subject: Adjusting Doors |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
The title should read Adjusting doors when slightly feck faced!How the feck do I adjust the doors without removing the front wing? |
Big hammer.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
iplay
phillipm wrote: Big hammer. that is about as much help as my wife who said 'i told you so! referring to the big sign which she wrote in the garage saying no car work before dark! |
iplay
Ok so this morning I have to use the passenger door to enter/exit! Clearly out of my depth so nothing new there.can anyone tell me the correct way to get the door aligned and the hinges true (so the door opens and closes smoothly)? Do I need to take the front wing off and adjust the hinges with the door in a closed position? or can it be done with the door open? seems a bit hit and miss and then to get the hinges aligned seems even harder! |
CUJ
Seasoned Pro Location: Southampton Registered: 18 Apr 2006 Posts: 22,218 Status: Offline |
What have you done to the door?!Mech Repairs adjusted mine as it wasn't aligned; he just opened the door and applied his weight to the frame, bending it back down ![]() ________________________________________ 340 horses |
sixygti2
Seasoned Pro Location: Tunbridge Wells Registered: 21 Apr 2007 Posts: 2,778 Status: Offline |
Work out how it needs to be adjusted first. Whip the door off and adjust hinges to suit, re attach door and voila!! Think thats how I did mine anyway ![]() ________________________________________ Still watching you... |
jimbobewob
Newbie Location: st ives Registered: 22 Jan 2008 Posts: 9 Status: Offline |
thats what i done. |
iplay
sixygti2 wrote: Work out how it needs to be adjusted first. Whip the door off and adjust hinges to suit, re attach door and voila!! Think thats how I did mine anyway ![]() I don't see how you can adjust the hinges to the correct position without having the door on? Is it possible to adjust the hinges from behind if the front wheel arch liner is taken out? |
rich-6
Seasoned Pro Location: Bottoming out! Registered: 06 May 2007 Posts: 5,306 Status: Offline |
CUJ wrote: Mech Repairs adjusted mine as it wasn't aligned; he just opened the door and applied his weight to the frame, bending it back down ![]() This! What people dont realise Doors Tailgates etc have to be given a bif of persuasion now and then to fit right ________________________________________ ![]() RIP Pete Sims |
sixygti2
iplay wrote: sixygti2 wrote: Work out how it needs to be adjusted first. Whip the door off and adjust hinges to suit, re attach door and voila!! Think thats how I did mine anyway ![]() I don't see how you can adjust the hinges to the correct position without having the door on? Is it possible to adjust the hinges from behind if the front wheel arch liner is taken out? Well as i said, before removing the door, you need to check how the door is sitting. From that you can guess how the hinges need adjusting, then take the door off... With my door, it was dropping slightly, so the top corner of the door was scrapping against the rear framework, so it needed lifting. All i did was remove the door, loosen the top hinge and move it further towards the front of the car, re-tighten, and this would mean it would pull the door to the correct position, and now it sits fine and doesn't rub! Hope that makes sense ________________________________________ Still watching you... |
jord294
sixygti2 wrote: Work out how it needs to be adjusted first. Whip the door off and adjust hinges to suit, re attach door and voila!! Think thats how I did mine anyway ![]() so your saying that the actual part of the hinge that bolts to chassis, has elongated holes to slide hinge either backwards or forwards ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
smegal
If it isn't that far out bending it is actually the easiest way of getting it spot on.________________________________________ Ex SC-6Now in a Megane R26 |
sixygti2
jord294 wrote: sixygti2 wrote: Work out how it needs to be adjusted first. Whip the door off and adjust hinges to suit, re attach door and voila!! Think thats how I did mine anyway ![]() so your saying that the actual part of the hinge that bolts to chassis, has elongated holes to slide hinge either backwards or forwards Cant remember if they were elongated, but there was enough movement to adjust and suit my needs! ________________________________________ Still watching you... |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
iplay wrote: Is it possible to adjust the hinges from behind if the front wheel arch liner is taken out? Thats the way to do it,remove wheel and arch liner,close the door then loosen the bolts through the arch holding the hindges, then line up the door and retighten the bolts.If you cant get a good fit you can then loosen the bolts holding the hinges on the door for aditional adjustment. I new those 9 days in bed reading the haynes manual would come in handy at some point ![]() ________________________________________ pet hate, the cat |
russbez
anyone else done the above? my doors have been off and i dont think they are lined up straight ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
smegal
If they aren't far out, strategically applied force really is the easiest way. Adjusting hinges is a pig.________________________________________ Ex SC-6Now in a Megane R26 |
russbez
i think iv already made a balls of adjusting the hinges via the 4 No. 13mm bolts.Bending them seems a bit permanent if i f**k it up ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
smegal
Bend em back. It does depends on how bad we are talking. banding is a minor adjustment method only really.________________________________________ Ex SC-6Now in a Megane R26 |
